Hey Dexter,
good job mate.
Did you figure our how to issue a command, to, say, a wall switch?
Cheers!
Hey Dexter,
good job mate.
Cheers!
Hi there. Iâm trying to use this binding on my installation. Iâm on 3.2.0 and when I put this binding in addons folder I get this error:
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.xiaomigatewayv3 [303]
Unresolved requirement: Import-Package: javax.measure; version="[1.0.0,2.0.0)"
Can you help me to find the solution? Thanks
Sorry, been busy for a while.
Now I have some time to continue with this project.
As for now, I know how to receive data from the gateway. This is actually the first step - to add passive sensors. Itâs quite tricky to add a new one to the existing binding, however after some changes it should be easier.
Can you tell me what kind of switch you are talking about? I thought they can only send data.
Thank you, I will look into it. I am still on 3.0.
Hi Dexter, good to hear.
Well, thereâs a bunch of wall switches and power sockets, which can be controlled remotely. Such as
ZNCZ02LM, QBKG12LM, QBKG11LM, QBKG03LM, QBKG04LM etc.
Thanks, Eugene.
Ok. Thanks. IĂ ve also tried on 3.10 and it was not working. I could try to install a second instance with 3.0 on another PC and check if it works.
No need if you have time to wait. I used another binding as a starting point and probably havenât removed this requirement.
as I received a donated gateway unit (thanks @rvalle), last week I spend some time in making the existing miio binding ready for the gateways. See the preliminary results here
[miio] implement lumi devices support for gateways reading only
Adding (experimental) support for the following models:
parrallel I submitted some PRs that build the necessary functionality to also control lumi devices.
As @moody_blue shared some of his devices in the mihome app, I hope to add those next week as well.
Ok Iâll wait. Thanks for adviceâŠ
For those that want to try the binding with lumi/gateway support, please find it here
https://verpaalen.com/openhab2/org.openhab.binding.miio-3.2.0-SNAPSHOT.jar
Adding support for the following models:
* Aqara LED Light Bulb (Tunable White) (modelId: lumi.light.aqcn02)
* IKEA E27 white spectrum opal (modelId: ikea.light.led1545g12)
* IKEA E27 white spectrum clear (modelId: ikea.light.led1546g12)
* IKEA E14 white spectrum (modelId: ikea.light.led1536g5)
* IKEA GU10 white spectrum (modelId: ikea.light.led1537r6)
* IKEA E27 warm white (modelId: ikea.light.led1623g12)
* IKEA GU10 warm white (modelId: ikea.light.led1650r5)
* IKEA E14 warm white (modelId: ikea.light.led1649c5)
* Door lock (modelId: lumi.lock.v1)
* Aqara Door Lock (modelId: lumi.lock.aq1)
* Aqara Door Lock S2 (modelId: lumi.lock.acn02)
* Aqara Door lock S2 Pro (modelId: lumi.lock.acn03)
* Mi Smart Plug (Zigbee) (modelId: lumi.plug.mmeu01)
* Mi Temperature and Humidity Sensor (modelId: lumi.sensor_ht.v1)
* Mi Window and Door Sensor (modelId: lumi.sensor_magnet.v2)
* Mi Motion Sensor (modelId: lumi.sensor_motion.v2)
* Water Leak Sensor (modelId: lumi.sensor_wleak.aq1)
* Aqara Temperature and Humidity Sensor (modelId: lumi.weather.v1)
Source here
Notes:
For the device logs, you can use the below code to render the log similar as the images in the previous post (in the developer tools menu (in the right side navigator), click widget and add widget. There paste below code in the widget editor)
uid: datatab
tags: []
props:
parameters:
- context: item
description: Log Item
label: log
required: false
type: TEXT
- default: Events
description: An item to control
label: Header Text
required: false
type: TEXT
- default: '{"event.plug_detection": "Appliance Event","prop.channel_0": "Power","event.leak": "Leak", "event.no_leak": "No Leak", "event.motion": "Motion" , "event.open": "Open" , "event.close": "Close"}'
description: Mapping of values
label: Mapping
required: false
type: TEXT
- default: '{"on": "f7:power","off": "f7:power"}'
description: Mapping of icons to values
label: Icons
required: false
type: TEXT
timestamp: Jul 19, 2021, 8:33:12 PM
component: f7-card
title: =props.header
slots:
default:
- component: oh-list
slots:
default:
- component: oh-repeater
for: eventLines
in: =JSON.parse(items[props.logArray].state)
fragment: true
slots:
default:
- component: oh-list-item
icon: '=(JSON.parse(props.icons)[loop.eventLines[1][1]] == undefined ? "f7:calendar_today" : JSON.parse(props.icon)[loop.eventLines[1][1]] )'
title: =dayjs(loop.eventLines[0]*1000 ).format("DD-MM-YYYY HH:mm") + " " + (loop.eventLines[1][1] == "" ? " " :JSON.parse(props.mapping)[loop.eventLines[1][0]] )
badge: '=(loop.eventLines[1][1] == "") ? JSON.parse(props.mapping)[loop.eventLines[1][0]] : loop.eventLines[1][1]'
badgeColor: '=(loop.eventLines[1][1] == "on") ? "green" : (loop.eventLines[1][1] == "off") ? "red" : "blue"'
after: =( JSON.parse(props.mapping)[loop.eventLines[1][0]] == undefined ? loop.eventLines[1][0] :null)
tooltip: =loop.eventLines[1]
style:
--f7-list-item-after-font-weight: bold
@Murazor If you are still interested - Iâve compiled it for 3.1.0 Release beta - v04 · hubaksis/org.openhab.binding.xiaomigatewayv3 · GitHub
@marcel_verpaalen Youâve done a great job implementing miio binding, so probably itâs a good place to continue development there.
A couple of questions:
Also I have an issue setting up the door sensor.
I set up the bridge - gateway (by entering the token and IP address) - it works fine. Then I tried to setup a door sensor (lumi.sensor_magnet.v2
I tried using Device ID in different formats: 158dxxxxxxxx59, 0x00158dxxxxxxxx59 - and received errors in logs: {"code":-5015,"message":"device not found"}
Then I modified code a bit to get device list by binding and got this response (part of it):
{"did":"lumi.158dxxxxxxxx59","model":"lumi.sensor_magnet.v2","num":1,"total":5}
I used the string lumi.158dxxxxxxxx59
for the Device Id - and now I receive an error
{"code":-4003,"message":"prop or action not exist"}
Any ideas why this is happening and how to fix it?
I use the cloud discovery for that purpose as the newer gateway donât provide this info via the local (miio) interface.
This is something I (still) donât fully know. Iâm sure the device does not provide an event directly via the miio interface (as I think it does with the telnet interface?), but it seems possible to somehow subscribe to the events via the cloud.
I can imagine we merge indeed your telnet interface somehow so we can get to the events in an easier way (without neededing the cloud)
Yes, as you may have seen, in the recent changes in the miio binding I changed to the did as it is provided from Xiaomi, hence the full string lumi.158dxxxxxxxx59
. If it does not directly discover it, you can look at the /userdata/miio folder to the json files.
I did not see the {"code":-4003,"message":"prop or action not exist"}
do you know which is the problematic property that gives this error? Maybe there is a difference between the various gateways, as the one I have always seem to give a response, even if the requested property is actually invalid
Telnet is used for enabling MQTT, then everything works with MQTT. So itâs immediate notification about status changes.
I think itâs possible to use both approaches and have new settings for some devices something like âmqtt supportâ with parameters.
Property 'open'
received miio:gateway:xiaomi-gateway-v3 command from miio:lumi:xiaomi-gateway-v3:4axxxx347 : get_device_prop_exp - [["lumi.158dxxxxxxxx59","open"]]
Command added to Queue {"id":1347,"method":"get_device_prop_exp","params":[["lumi.158dxxxxxxxx59","open"]]} -> 192.168.1.168 (Device: 40xxxxx65 token: 73545250XXXXXXXXXXXXXXXX577A6B6A Queue: 1).
Error received for command '{"id":1349,"method":"get_device_prop_exp","params":[["lumi.158dxxxxxxxx59","open"]]}': {"code":-4003,"message":"prop or action not exist"}.
By the way, should device ids be kept secret? Token for the gateway should definitely be, may be there is no reason to hide deviceIds?
Yes fully agree. Does it require a modded gateway or any gateway model has this? ( I was under the impression it requires specific models/firmware mods)
Once Iâm back from holidays and some time, ill give your binding a try to understand what/how it is communicating.
To my knowledge there is nothing one could do with just the deviceId, Iâm not keeping mine secret.
In the miio logs I donât show the token as the combination of did+token MAY allow for some level of control over the device.(even that Iâm not confident, if it allows remote control, just local I think. Normal remote control requires the device being shared with you in the mihome app, but in that case no need for the token)
Everything Iâve done is based on this home assistant project. It has some requirements regarding the version but not sure if itâs strict. After enabling telnet on the device itâs possible to do everything automatically (enable public MQTT, install updated bluetooth module, etc. if required).
What is the latest code I can use? Is it only in the miio-lumiGatewayDevicesv3
tree or somewhere in the main branch?
The miio-lumiGatewayDevicesv3
is indeed the last published one.
As you can see it mainly reuses existing code from the binding. But did require some structure changes (like did format) that in the meantime have been merged
Iâm just trying this. I get that âAutoDiscovery: model lumi.sensor_motion.v2 is not yet supportedâ so it is sad for me as I have 3 of this.
And also my 3 âmiaomiaoce.sensor_ht.t2â are not yet supported
I have 3 âmiaomiaoce.sensor_ht.t2â that are not yet in the database. And also my âlumi.sensor_motion.v2â is not working well⊠I didnât get changes for log or movement.
Is it âXiaomi Motion Sensor RTCGQ01LMâ or âAqara Motion Sensor RTCGQ11LMâ?
To be able to get log or movement immediately after it happened some changes need to be made to the system. Working on it.
Hi there, they are âXiaomi Motion Sensor RTCGQ01LMâ.
