Hi there,
My smoke detector - which works fine in Xiaomi Home App - doesn’t show up in vsCode.
(I’m running oH2.4 on Raspi3b with Xiaomi-Binding in connection with original Xiaomi-Gateway)
And thus not in sitemap:
All other Xiaomi devices are working fine …
I use text based configuration
xiaomi.things (excerpt)
Bridge mihome:bridge:xyz "Xiaomi Gateway" [ serialNumber="xyz", ipAddress="192.168.178.69", port=9898, key="mykey", pollingInterval=6000 ] {
Things:
gateway xyz "Xiaomi: Mi Smart Home Gateway" [itemId="xyz"]
sensor_plug 158d000xxxx "Xiaomi: Zwischenstecker 1" [itemId="158d000xxxx"]
sensor_smoke 158d000yyyy "Xiaomi: Rauchmelder 1" [itemId="158d000yyyy"]
xiaomi.items
Number XiaomiRauchmelder1_Density "Xiaomi Rauchmelder 1 - Particle Density" <fire> {channel="mihome:smoke:xyz:158d000yyyy:density"}
Switch XiaomiRauchmelder1_Alarm "Xiaomi Rauchmelder 1 - Smoke detected" <fire> {channel="mihome:smoke:xyz:158d000yyyy:alarm"}
String XiaomiRauchmelder1_Status "Xiaomi Rauchmelder 1 - Status" <fire> {channel="mihome:smoke:xyz:158d000yyyy:status"}
Number XiaomiRauchmelder1_BatteryLevel "Xiaomi Rauchmelder 1 - Batterieladung" <fire> {channel="mihome:smoke:xyz:158d000yyyy:batteryLevel"}
Switch XiaomiRauchmelder1_LowBattery "Xiaomi Rauchmelder 1 - Niedriger Batteriestatus" <fire> {channel="mihome:smoke:xyz:158d000yyyy:lowBattery"}
The device does show up in paper ui inbox
But I want to use only text files on my system.
Any ideas?
