Eugene,
Indeed that model is not yet in the database.
The workaround is:
Add it as a basic thing, override the model in the configuration to zhimi.airpurifier.m1 or zhimi.airpurifier.v1 or zhimi.airpurifier.v6
This will allow you to send the commands like the defined model.
I already tried with zhimi.airpurifier.m1 (because zhimi.airpurifier.v1 & zhimi.airpurifier.v6 is not supported Database entry for model 'zhimi.airpurifier.v6' cannot be found ),
but,
still all numbers and strings are - / 0.
Switch is a type of OnOffType.
So as you see very strangeā¦ but i can not see any other errros in the logs.
V1 and v6 should be supported. Are you using the latest version of the binding? (You can uninstall and reā-install it) the latest version is of today.
Can somebody explain how should behave some items. If I proper understand:
filtermaxlife - constant value, maximum lifetime of a filter (in hours)
filterlife - max filter life in percent (100% and decreasing)
filterhours - in hours? (still shows 0)
usedhours - runtime of a purifier (in hours)
Hi all, had the same like Eugenā¦ tried this too. Looked initially OK from PaperUI, it showed all the commands, but in my logs I get this:
2018-02-19 21:38:24.856 [WARN ] [nal.transport.MiIoAsyncCommunication] - Send command '{"id":121,"method":"miIO.info","params":[]}' -> 192.168.178.34 (Device: 036CCC63) gave error Given f$
$2.168.178.34 (Device: 036CCC63) gave error Given final block not properly padded
I donāt know what that means
Before it has discovered it as M1 but if I took the autodiscovered and entered the token, it only showed 5 commands like SSID etc. nothing that looked connected to a air purifier. So I deleted thing and tried this manual way.
I just downloaded the last version and use OH 2.2 - the other xiaomi devices and sensors on the gateway work from OHā¦
@solarspion
Your error typically is shown when the token is wrong (but was before valid).
In that case the device responds, (compared to a completely wrong token which gives no response at all) but the response canāt be decrypted with the provided token.
Would suggest to try to extract the token once more from the xiaomi app
thanks for the help. I tried this and it was indeed correct. To be sure, I generated a new token and entered it in all the Xiaomi things.
Still looks the same unfortunately.
[20:28:03] openhabian@openHABianPi:/var/log/openhab2$ tail openhab.log
2018-02-21 20:27:40.186 [INFO ] [inding.miio.handler.MiIoBasicHandler] - Channel 'led' for thing miio:basic:033E41AA already exist... removing
2018-02-21 20:27:40.191 [INFO ] [inding.miio.handler.MiIoBasicHandler] - Channel 'act_det' for thing miio:basic:033E41AA already exist... removing
2018-02-21 20:27:40.197 [INFO ] [inding.miio.handler.MiIoBasicHandler] - Channel 'buzzer' for thing miio:basic:033E41AA already exist... removing
2018-02-21 20:27:40.202 [INFO ] [inding.miio.handler.MiIoBasicHandler] - Channel 'filtermaxlife' for thing miio:basic:033E41AA already exist... removing
2018-02-21 20:27:40.207 [INFO ] [inding.miio.handler.MiIoBasicHandler] - Channel 'filterlive' for thing miio:basic:033E41AA already exist... removing
2018-02-21 20:27:40.350 [WARN ] [nal.transport.MiIoAsyncCommunication] - Send co mmand '{"id":837,"method":"miIO.info","params":[]}' -> 192.168.178.35 (Device: 033E41AA) gave error Given final block not properly padded
2018-02-21 20:27:40.370 [WARN ] [nal.transport.MiIoAsyncCommunication] - Send co mmand '{"id":838,"method":"get_prop","params":["power","mode","humidity","aqi"," bright"]}' -> 192.168.178.35 (Device: 033E41AA) gave error Given final block no t properly padded
2018-02-21 20:27:40.389 [WARN ] [nal.transport.MiIoAsyncCommunication] - Send co mmand '{"id":839,"method":"get_prop","params":["led","act_det","buzzer","f1_hour ","filter1_life"]}' -> 192.168.178.35 (Device: 033E41AA) gave error Given final block not properly padded
2018-02-21 20:27:40.409 [WARN ] [nal.transport.MiIoAsyncCommunication] - Send co mmand '{"id":840,"method":"get_prop","params":[]}' -> 192.168.178.35 (Device: 0 33E41AA) gave error Given final block not properly padded
2018-02-21 20:27:46.613 [WARN ] [nal.transport.MiIoAsyncCommunication] - Send co mmand '{"id":14,"method":"miIO.info","params":[]}' -> 192.168.178.34 (Device: 0 36CCC63) gave error Given final block not properly padded
