Xiaomi Mi binding: regular issues with Yeelight ceiling light showing offline
Good morning together,
I have regular issues with my Yeelight ceiling light going and staying offline in openhab for example after is shortly loses wifi connection or after I restart the router
Typically in those cases, powering off and on the light solves the issue, but I don’t have a physical switch for it and it happens rather often (once every one or two weeks) to me.
The light is connected to the EU server, lan control is switched on, token and IP address are correct and the Yeelight app itself is working. Binding is set to control the lights locally.
The light is connected to my router directly, the openhab server is in the same network, but behind a repeater.
I couldn’t find information on this being a general problem and only fixes such as “reconnect”, “check token" etc.
Has anyone a more concrete idea, what I could try changing in this setup?
I could share some log data tomorrow. When the light is shown as offline in openhab, log states that it would not be reachable. My router logs confirm that the device would be available with it’s defined IP address.
Other wifi devices in my setup don’t suffer from that problem.
Thanks in advance, best,
Christian
