Xiaomi Mi Infrared Remote Control
Hello everyone,
I have got this device working.
But have one remaining problem.
I use this device to controle my radio and created a couple of virtual switches to activate functions like the volume.
The switches triggers rules that sends the correct code to the Xiaomi device.
This workes correct. But only when I press the “volume button” very slowly.
But when I press a switch a few times fast, I notice a annoying lag.
At first I thougt it was the Xiaomi device or maybe my wifi.
But when I test simular functions on the app “my home” (supplied by Xiaomi) de device works relatively fast (sometimes 1 or 2 seconds of delay, but nothing realy disturbing).
I have attaced some logging.
In this test case I have pressed the volume button"(switch) 15 times, in about 5 seconds.
The first 5 commands where processed relatively fast, but then the lagging starts en it takes almost a minute to process the lot. (as can be seen in the logging)
I have noticed that the first 5 commands seem to be processed serial. But then they seem to be queued (or something).
I have increased the thread pool to a higher value
editing /etc/openhab2/service/runtime.cfg and adding line
(org.eclipse.smarthome.threadpool:RuleEngine=10)
But this did not seem to help in my case.
I have experimented by adding a timer delay. But to now reveale.
https://community.openhab.org/t/why-have-my-rules-stopped-running-why-thread-sleep-is-a-bad-idea/47695.
I am new to the software and don’t realy know how te proceed.
Any help would be greately appreciated.
rules:
rule “Volume”
when Item Volume_media received command
then if (receivedCommand == ON){
createTimer(now, [|
MIio_executeCmnd.sendCommand(‘miIO.ir_play {“freq”: 38400, “code”:“nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4NngIOEr4MfgMeCV4MlgI3MIAA=”}’)
Volume_media.postUpdate(NULL)
else if (receivedCommand == OFF){
createTimer(now, [|
MIio_executeCmnd.sendCommand(‘miIO.ir_play {“freq”: 38400, “code”:“nE5mcwlk0mk3mEsms1mEsmM2nABDgItNZsAP4A/gc+AQ4EMTkAMpkBTYLVzQCjwIKAI8EPwhvBs8B/wnfBj4Pr5hAA==”}’)
items:
Group Media
Switch Power_media “ON OF Switch”
Switch Volume_media “Volume up down” {autoupdate=“false”}
Switch Mute_media “Mute” {autoupdate=“false”}
Number Source_media “Source Channel”
String MIio_executeCmnd “Mi IO Execute Command” { channel=“miio:generic:07682051:actions#commands” }
events.log
2020-01-05 20:57:41.336 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:41.340 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:41.342 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":217,"result":["ok"]} to miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9>
2020-01-05 20:57:41.991 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4NngIOEr4>
2020-01-05 20:57:41.992 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":217,"result":["ok"]} to {"id":227,"result":["ok"]}
2020-01-05 20:57:42.414 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:42.425 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:42.428 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:42.429 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":227,"result":["ok"]} to miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9>
2020-01-05 20:57:42.930 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4NngIOEr4>
2020-01-05 20:57:42.932 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":227,"result":["ok"]} to {"id":228,"result":["ok"]}
2020-01-05 20:57:43.516 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:43.524 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:43.529 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:43.533 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":228,"result":["ok"]} to miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9>
2020-01-05 20:57:43.752 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4NngIOEr4>
2020-01-05 20:57:43.753 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":228,"result":["ok"]} to {"id":229,"result":["ok"]}
2020-01-05 20:57:44.903 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:44.911 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:44.913 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:44.914 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":229,"result":["ok"]} to miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9>
2020-01-05 20:57:45.391 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4NngIOEr4>
2020-01-05 20:57:45.392 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":229,"result":["ok"]} to {"id":230,"result":["ok"]}
2020-01-05 20:57:46.570 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:46.581 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:46.585 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:46.587 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":230,"result":["ok"]} to miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9>
2020-01-05 20:57:49.642 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:49.650 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:49.651 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:50.116 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:50.125 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:50.128 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:50.574 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:50.577 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:50.580 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:51.049 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:51.090 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:51.094 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:51.591 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:51.595 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:51.597 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:52.057 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:52.061 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:52.062 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:52.563 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:52.566 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:52.567 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:53.091 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:53.096 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:53.097 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:53.603 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:53.607 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:53.609 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:57:54.140 [ome.event.ItemCommandEvent] - Item 'Volume_media' received command ON
2020-01-05 20:57:54.145 [ome.event.ItemCommandEvent] - Item 'MIio_executeCmnd' received command miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1e>
2020-01-05 20:57:54.146 [nt.ItemStatePredictedEvent] - MIio_executeCmnd predicted to become miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4N>
2020-01-05 20:58:02.372 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from miIO.ir_play {"freq": 38400, "code":"nE5mkwlk0mk3mEsms2mEsmM2AI8ANJqAGwB9gD8Bz4GtAW2BTYEHg1eCl4NngIOEr4>
2020-01-05 20:58:02.375 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":230,"result":["ok"]} to {"id":232,"result":["ok"]}
2020-01-05 20:58:33.352 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":232,"result":["ok"]} to {"id":234,"result":["ok"]}
2020-01-05 20:58:33.353 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":232,"result":["ok"]} to {"id":234,"result":["ok"]}
2020-01-05 20:58:33.481 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":234,"result":["ok"]} to {"id":235,"result":["ok"]}
2020-01-05 20:58:33.482 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":234,"result":["ok"]} to {"id":235,"result":["ok"]}
2020-01-05 20:58:33.763 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":235,"result":["ok"]} to {"id":237,"result":["ok"]}
2020-01-05 20:58:33.764 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":235,"result":["ok"]} to {"id":237,"result":["ok"]}
2020-01-05 20:58:36.629 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":237,"result":["ok"]} to {"id":238,"result":["ok"]}
2020-01-05 20:58:36.630 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":237,"result":["ok"]} to {"id":238,"result":["ok"]}
2020-01-05 20:58:36.950 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":238,"result":["ok"]} to {"id":239,"result":["ok"]}
2020-01-05 20:58:36.951 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":238,"result":["ok"]} to {"id":239,"result":["ok"]}
2020-01-05 20:58:37.151 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":239,"result":["ok"]} to {"id":240,"result":["ok"]}
2020-01-05 20:58:37.152 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":239,"result":["ok"]} to {"id":240,"result":["ok"]}
2020-01-05 20:58:37.332 [vent.ItemStateChangedEvent] - MIio_executeCmnd changed from {"id":240,"result":["ok"]} to {"id":241,"result":["ok"]}
2020-01-05 20:58:37.334 [vent.ItemStateChangedEvent] - MiIO_ExecuteCommand changed from {"id":240,"result":["ok"]} to {"id":241,"result":["ok"]}
