Xiaomi Mi IO Binding - Error logging on to Xiaomi cloud
Hi, actually when I revisit the binding, the username and password are still there. I cannot remove them. So, I delete them, click save, everything seems fine, but then I go back in, they are still input there. but if I change the server (like, cn,sg) that works, it remains saved.
So it seems my issues have nothing to do with adding/removing credentials because I cannot remove them. Now I suspect the issue may be happening due to the fact that the binding keeps retrying the cloud login endlessly…
I tried restarting the binding, disable/enable the thing, but now I keep getting these errors that usually show only once during startup of openhab. but now i keep getting them every 20-30min.
Maybe i will have to reboot the entire openhab but I hate doing that unless absolutely forced :slight_smile:
2025-09-25 10:49:05.193 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:0351C576' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 10:49:05.231 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:0351C576': {thing/channel=Type description miio:ZHIMI_AIRMONITOR_V1_power for miio:generic:0351C576:power not found, although we checked the presence before.}
2025-09-25 10:49:05.317 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:12F48BA7' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 10:49:05.325 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:12F48BA7': {thing/channel=Type description miio:MIJIA_VACUUM_V2_vacuumaction for miio:generic:12F48BA7:vacuumaction not found, although we checked the presence before.}
2025-09-25 11:13:14.915 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:0351C576' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 11:13:14.980 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:0351C576': {thing/channel=Type description miio:ZHIMI_AIRMONITOR_V1_power for miio:generic:0351C576:power not found, although we checked the presence before.}
2025-09-25 11:13:15.047 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:12F48BA7' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 11:13:15.057 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:12F48BA7': {thing/channel=Type description miio:MIJIA_VACUUM_V2_vacuumaction for miio:generic:12F48BA7:vacuumaction not found, although we checked the presence before.}
2025-09-25 11:50:30.930 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:12F48BA7' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 11:50:31.001 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:12F48BA7': {thing/channel=Type description miio:MIJIA_VACUUM_V2_vacuumaction for miio:generic:12F48BA7:vacuumaction not found, although we checked the presence before.}
2025-09-25 11:50:33.071 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:0351C576' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 11:50:33.080 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:0351C576': {thing/channel=Type description miio:ZHIMI_AIRMONITOR_V1_power for miio:generic:0351C576:power not found, although we checked the presence before.}
2025-09-25 12:14:44.352 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:0351C576' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 12:14:44.397 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:0351C576': {thing/channel=Type description miio:ZHIMI_AIRMONITOR_V1_power for miio:generic:0351C576:power not found, although we checked the presence before.}
2025-09-25 12:14:44.456 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:12F48BA7' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 12:14:44.462 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:12F48BA7': {thing/channel=Type description miio:MIJIA_VACUUM_V2_vacuumaction for miio:generic:12F48BA7:vacuumaction not found, although we checked the presence before.}
2025-09-25 13:33:16.235 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:0351C576' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 13:33:16.364 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:0351C576': {thing/channel=Type description miio:ZHIMI_AIRMONITOR_V1_power for miio:generic:0351C576:power not found, although we checked the presence before.}
2025-09-25 13:33:18.749 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:12F48BA7' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2025-09-25 13:33:18.834 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'miio:generic:12F48BA7': {thing/channel=Type description miio:MIJIA_VACUUM_V2_vacuumaction for miio:generic:12F48BA7:vacuumaction not found, although we checked the presence before.}
I’m afraid to delete and recreate the thing, as I’m not sure will it work without cloud connection.
If you delete it, you need to make a note of the token. Without the token you won’t be able to communicate with the thing.
I never tried to delete userId/pass, as that is not really handled by the binding, more by the openhab framework. You can always try to delete them from the files openhab creates, and restart.
Anyway, sometimes a real restart of openhab solves issues…
Yep…all good after reboot
