I am using Yeelight Ceiling Light with Xiaomi Mi IO binding, however the device stay ‘offline’.
I have configured the device per documentation as follow :
Find the model and token using mitoolkit, and got following data (scrapped last 3 chars of token)
yeelink.light.ceiling1 - Ceiling light - da9ae49750ea4e202857e2d4c1c8bxxx - 192.168.1.2
Find the device ID using miio discover and got the info as follows : Device ID: 53990702 Model info: Unknown Address: 192.168.1.2 Token: ??? Support: Unknown
I converted the device ID from DEC to HEX.
Then insert the data into things in openhabian 2.4.0 with xiaomi mi io v2.4.0 :
When I started checking on this again, there are all “ONLINE” now. So the token seems to be correct, not sure why they stays offline for first few days.
maybe somebody has an idea, why both my yeelights are online but only the officeyeelight reacts on the power-commands???
This is my thing-file:
Thing miio:basic:lamp_sz “YeelightSZ” [ host=“192.168.xxx.xxx”, token=“ffedc8b1c9d28f10a79f51xxxxx”, deviceId=“77192xxxx”, model=“yeelink.light.ceiling3”, communication=“direct” ]
Thing miio:basic:lamp_office “YeelightOffice” [ host=“192.168.xxx.xxx”, token=“6c1db6a08bafafa4ea58aa23xxxxx”, deviceId=“5624xxxx”, model=“yeelink.light.ceiling1”, communication=“direct” ]
and my item-file:
Switch sz_light “Schlafzimmer-Licht” (gOG,gLight) {alexa=“Light”, channel=“miio:basic:lamp_sz:power”}
Switch office_light “Bürolampe” (gOG,gLight) {alexa=“Light”, channel=“miio:basic:lamp_office:power”}
I am sure, the token and device-id is correct. Checked and bot lamps has been working with my old openhab 2.x-configuration. I changed now to openhab 3.2. Any ideas???
