Xiaomi Mi Smart Home Binding no heartbeats, do updates of data from sensors
I have problem with Xiaomi Mi Smart Home Binding.
It looks like there is no heartbears send from my servev with OH2 to Xiaomi gateway.
My things:
Bridge mihome:bridge:7811dcb7e00d "Xiaomi Gateway" @ "Xiaomi" [ serialNumber="7811dcb7e00d", ipAddress="192.168.20.10", port=9898, key="za2dc6vavygwp5al", pollingInterval=6000 ] {
   Thing mihome:gateway:7811dcb7e00d "Xiaomi Mi Smart Home Gateway" @ "Xiaomi"  [itemId="7811dcb7e00d"]
   Thing mihome:sensor_weather_v1:158d0001f508a6 "Xiaomi Aqara Temperature, Humidity & Pressure Sensor TH1" @ "Xiaomi" [itemId="158d0001f508a6"]
   Thing mihome:sensor_weather_v1:158d0001fa5b23 "Xiaomi Aqara Temperature, Humidity & Pressure Sensor TH2" @ "Xiaomi" [itemId="158d0001fa5b23"]
My items:
Number Xiaomi_TH2_Temperature "Temperatura [%.1f °C]" <temperature> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001fa5b23:temperature" }
Number Xiaomi_TH2_Humidity "Wilgotność [%.1f %%]" <humidity> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001fa5b23:humidity" }
Number Xiaomi_TH2_Pressure "Ciśnienie [%.1f kPa]" <pressure> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001fa5b23:pressure" }
Number Xiaomi_TH2_Battery_Level "Poziom baterii [%d %%]" <battery> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001fa5b23:batteryLevel" }
Switch Xiaomi_TH2_Low_Battery "Niski poziom baterii [MAP(xiaomi_low_bat.map):%s]" (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001fa5b23:lowBattery" }
Number Xiaomi_TH1_Temperature "Temperatura [%.1f °C]" <temperature> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001f508a6:temperature" }
Number Xiaomi_TH1_Humidity "Wilgotność [%.1f %%]" <humidity> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001f508a6:humidity" }
Number Xiaomi_TH1_Pressure "Ciśnienie [%.1f kPa]" <pressure> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001f508a6:pressure" }
Number Xiaomi_TH1_Battery_Level "Poziom baterii [%d %%]" <battery> (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001f508a6:batteryLevel" }
Switch Xiaomi_TH1_Low_Battery "Niski poziom baterii [MAP(xiaomi_low_bat.map):%s]" (gXiaomi) { channel="mihome:sensor_weather_v1:158d0001f508a6:lowBattery" }
I enable TRACE for Mihome bindings.
Every time when i restart bundle:
openhab> bundle:list  |grep Xia
290 │ Active   │  80 │ 2.2.0                  │ Xiaomi Mi Smart Home Binding
openhab> bundle:restart 290
I got update of values of my sensors.
Here are logs:
2018-02-23 10:21:34.967 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={component.name=org.openhab.binding.mihome.discovery.bridge, component.id=254, service.id=399, service.bundleid=290, service.scope=bundle} - org.openhab.binding.mihome
2018-02-23 10:21:34.970 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001fa5b23' changed from ONLINE to UNINITIALIZED
2018-02-23 10:21:34.971 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Handler disposes. Unregistering listener
2018-02-23 10:21:34.974 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001fa5b23' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-23 10:21:34.975 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Handler disposes. Unregistering listener
2018-02-23 10:21:34.975 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001f508a6' changed from ONLINE to UNINITIALIZED
2018-02-23 10:21:34.978 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001f508a6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-23 10:21:34.979 [hingStatusInfoChangedEvent] - 'mihome:gateway:7811dcb7e00d' changed from ONLINE to UNINITIALIZED
2018-02-23 10:21:34.979 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Handler disposes. Unregistering listener
2018-02-23 10:21:34.982 [hingStatusInfoChangedEvent] - 'mihome:gateway:7811dcb7e00d' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-23 10:21:34.983 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - dispose
2018-02-23 10:21:34.983 [hingStatusInfoChangedEvent] - 'mihome:bridge:7811dcb7e00d' changed from ONLINE to UNINITIALIZED
2018-02-23 10:21:34.985 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Interrupting Thread Thread[Thread-88,5,main]
2018-02-23 10:21:34.985 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Closing socket java.net.MulticastSocket@529cc001
2018-02-23 10:21:34.986 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Receiver thread was interrupted
2018-02-23 10:21:34.986 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Receiver thread ended
2018-02-23 10:21:34.988 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=401, service.bundleid=290, service.scope=singleton} - org.openhab.binding.mihome
2018-02-23 10:21:34.990 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=402, service.bundleid=290, service.scope=singleton} - org.openhab.binding.mihome
2018-02-23 10:21:34.992 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=binding.mihome, component.id=255, service.id=400, service.bundleid=290, service.scope=bundle} - org.openhab.binding.mihome
2018-02-23 10:21:34.992 [hingStatusInfoChangedEvent] - 'mihome:bridge:7811dcb7e00d' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2018-02-23 10:21:34.999 [DEBUG] [org.openhab.binding.mihome          ] - BundleEvent STOPPING - org.openhab.binding.mihome
2018-02-23 10:21:35.002 [DEBUG] [org.openhab.binding.mihome          ] - BundleEvent STOPPED - org.openhab.binding.mihome
2018-02-23 10:21:35.002 [DEBUG] [org.openhab.binding.mihome          ] - BundleEvent STARTING - org.openhab.binding.mihome
2018-02-23 10:21:35.009 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={component.name=org.openhab.binding.mihome.discovery.bridge, component.id=256, service.id=403, service.bundleid=290, service.scope=bundle} - org.openhab.binding.mihome
2018-02-23 10:21:35.012 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=binding.mihome, component.id=257, service.id=404, service.bundleid=290, service.scope=bundle} - org.openhab.binding.mihome
2018-02-23 10:21:35.014 [DEBUG] [org.openhab.binding.mihome          ] - BundleEvent STARTED - org.openhab.binding.mihome
2018-02-23 10:21:35.054 [me.event.ThingUpdatedEvent] - Thing 'mihome:bridge:7811dcb7e00d' has been updated.
2018-02-23 10:21:35.056 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Having 1 Item Discovery listeners
2018-02-23 10:21:35.056 [me.event.ThingUpdatedEvent] - Thing 'mihome:gateway:7811dcb7e00d' has been updated.
2018-02-23 10:21:35.056 [me.event.ThingUpdatedEvent] - Thing 'mihome:sensor_weather_v1:158d0001f508a6' has been updated.
2018-02-23 10:21:35.056 [me.event.ThingUpdatedEvent] - Thing 'mihome:sensor_weather_v1:158d0001fa5b23' has been updated.
2018-02-23 10:21:35.057 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=405, service.bundleid=290, service.scope=singleton} - org.openhab.binding.mihome
2018-02-23 10:21:35.060 [DEBUG] [org.openhab.binding.mihome          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=406, service.bundleid=290, service.scope=singleton} - org.openhab.binding.mihome
2018-02-23 10:21:35.063 [hingStatusInfoChangedEvent] - 'mihome:bridge:7811dcb7e00d' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2018-02-23 10:21:35.063 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Init socket on Port: 9898
2018-02-23 10:21:35.064 [DEBUG] [e.internal.socket.XiaomiBridgeSocket] - Setup socket
2018-02-23 10:21:35.064 [DEBUG] [e.internal.socket.XiaomiBridgeSocket] - Initialized socket to null:-1 on 0.0.0.0/0.0.0.0:9898
2018-02-23 10:21:35.065 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - There are 1 open sockets: {9898=java.net.MulticastSocket@26fa671a}
2018-02-23 10:21:35.065 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Adding socket listener org.openhab.binding.mihome.handler.XiaomiBridgeHandler@35970d25
2018-02-23 10:21:35.065 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Staring reveicer thread for socket on port 9898
2018-02-23 10:21:35.067 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-97,5,main] waiting for data on port 9898
2018-02-23 10:21:35.069 [hingStatusInfoChangedEvent] - 'mihome:gateway:7811dcb7e00d' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2018-02-23 10:21:35.070 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001f508a6' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2018-02-23 10:21:36.066 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Triggered discovery
2018-02-23 10:21:36.066 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dcb7e00d: {"cmd": "get_id_list"}
2018-02-23 10:21:36.066 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {"cmd": "get_id_list"} to /192.168.20.10:9898
2018-02-23 10:21:36.070 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.20.10:9898 on Port 9898
2018-02-23 10:21:36.071 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"get_id_list_ack","sid":"7811dcb7e00d","token":"Yq6IIDco2cft9Dic","data":"[\"158d0001f508a6\",\"158d0001fa5b23\"]"}
2018-02-23 10:21:36.071 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 7811dcb7e00d
2018-02-23 10:21:36.071 [hingStatusInfoChangedEvent] - 'mihome:bridge:7811dcb7e00d' changed from INITIALIZING to ONLINE
2018-02-23 10:21:36.075 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dcb7e00d: {"cmd": "read", "sid": "158d0001f508a6"}
2018-02-23 10:21:36.077 [hingStatusInfoChangedEvent] - 'mihome:gateway:7811dcb7e00d' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2018-02-23 10:21:36.077 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Adding item listener for device 7811dcb7e00d
2018-02-23 10:21:36.077 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Having 1 Item listeners
2018-02-23 10:21:36.078 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {"cmd": "read", "sid": "158d0001f508a6"} to /192.168.20.10:9898
2018-02-23 10:21:36.078 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dcb7e00d: {"cmd": "read", "sid": "158d0001fa5b23"}
2018-02-23 10:21:36.078 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {"cmd": "read", "sid": "158d0001fa5b23"} to /192.168.20.10:9898
2018-02-23 10:21:36.078 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Send to bridge mihome:bridge:7811dcb7e00d: {"cmd": "read", "sid": "7811dcb7e00d"}
2018-02-23 10:21:36.079 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Sending message: {"cmd": "read", "sid": "7811dcb7e00d"} to /192.168.20.10:9898
2018-02-23 10:21:36.079 [hingStatusInfoChangedEvent] - 'mihome:gateway:7811dcb7e00d' changed from INITIALIZING to ONLINE
2018-02-23 10:21:36.079 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-02-23 10:21:36.079 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-97,5,main] waiting for data on port 9898
2018-02-23 10:21:36.080 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001f508a6' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2018-02-23 10:21:36.080 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Adding item listener for device 158d0001f508a6
2018-02-23 10:21:36.080 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Having 2 Item listeners
2018-02-23 10:21:36.080 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001fa5b23' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2018-02-23 10:21:36.081 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Adding item listener for device 158d0001fa5b23
2018-02-23 10:21:36.081 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Having 3 Item listeners
2018-02-23 10:21:36.081 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001f508a6' changed from INITIALIZING to OFFLINE
2018-02-23 10:21:36.082 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001f508a6 on channel mihome:sensor_weather_v1:158d0001f508a6:temperature received command REFRESH
2018-02-23 10:21:36.082 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001fa5b23' changed from INITIALIZING to OFFLINE
2018-02-23 10:21:36.082 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001f508a6 on channel mihome:sensor_weather_v1:158d0001f508a6:humidity received command REFRESH
2018-02-23 10:21:36.082 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.20.10:9898 on Port 9898
2018-02-23 10:21:36.083 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"read_ack","model":"weather.v1","sid":"158d0001f508a6","short_id":27058,"data":"{\"voltage\":3045,\"temperature\":\"2324\",\"humidity\":\"3385\",\"pressure\":\"101480\"}"}
2018-02-23 10:21:36.083 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 158d0001f508a6
2018-02-23 10:21:36.083 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001f508a6 on channel mihome:sensor_weather_v1:158d0001f508a6:pressure received command REFRESH
2018-02-23 10:21:36.083 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Device 158d0001f508a6 honored read request
2018-02-23 10:21:36.083 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"read_ack","model":"weather.v1","sid":"158d0001f508a6","short_id":27058,"data":"{\"voltage\":3045,\"temperature\":\"2324\",\"humidity\":\"3385\",\"pressure\":\"101480\"}"}
2018-02-23 10:21:36.084 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-02-23 10:21:36.084 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-97,5,main] waiting for data on port 9898
2018-02-23 10:21:36.084 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.20.10:9898 on Port 9898
2018-02-23 10:21:36.084 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"read_ack","model":"weather.v1","sid":"158d0001fa5b23","short_id":13787,"data":"{\"voltage\":3075,\"temperature\":\"2265\",\"humidity\":\"2798\",\"pressure\":\"101439\"}"}
2018-02-23 10:21:36.085 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 158d0001fa5b23
2018-02-23 10:21:36.085 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Device 158d0001fa5b23 honored read request
2018-02-23 10:21:36.085 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"read_ack","model":"weather.v1","sid":"158d0001fa5b23","short_id":13787,"data":"{\"voltage\":3075,\"temperature\":\"2265\",\"humidity\":\"2798\",\"pressure\":\"101439\"}"}
2018-02-23 10:21:36.085 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001f508a6 on channel mihome:sensor_weather_v1:158d0001f508a6:batteryLevel received command REFRESH
2018-02-23 10:21:36.086 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Update Item 158d0001f508a6 with retented message
2018-02-23 10:21:36.086 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"read_ack","model":"weather.v1","sid":"158d0001f508a6","short_id":27058,"data":"{\"voltage\":3045,\"temperature\":\"2324\",\"humidity\":\"3385\",\"pressure\":\"101480\"}"}
2018-02-23 10:21:36.086 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001f508a6 on channel mihome:sensor_weather_v1:158d0001f508a6:lowBattery received command REFRESH
2018-02-23 10:21:36.087 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-02-23 10:21:36.087 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-97,5,main] waiting for data on port 9898
2018-02-23 10:21:36.087 [DEBUG] [.mihome.internal.socket.XiaomiSocket] - Received Datagram from 192.168.20.10:9898 on Port 9898
2018-02-23 10:21:36.087 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Received message {"cmd":"read_ack","model":"gateway","sid":"7811dcb7e00d","short_id":0,"data":"{\"rgb\":0,\"illumination\":1292,\"proto_version\":\"1.0.9\"}"}
2018-02-23 10:21:36.087 [TRACE] [g.mihome.handler.XiaomiBridgeHandler] - Updated "last time seen" for device 7811dcb7e00d
2018-02-23 10:21:36.088 [DEBUG] [g.mihome.handler.XiaomiBridgeHandler] - Device 7811dcb7e00d honored read request
2018-02-23 10:21:36.088 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"read_ack","model":"gateway","sid":"7811dcb7e00d","short_id":0,"data":"{\"rgb\":0,\"illumination\":1292,\"proto_version\":\"1.0.9\"}"}
2018-02-23 10:21:36.088 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001fa5b23 on channel mihome:sensor_weather_v1:158d0001fa5b23:temperature received command REFRESH
2018-02-23 10:21:36.089 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001fa5b23 on channel mihome:sensor_weather_v1:158d0001fa5b23:humidity received command REFRESH
2018-02-23 10:21:36.089 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001fa5b23 on channel mihome:sensor_weather_v1:158d0001fa5b23:pressure received command REFRESH
2018-02-23 10:21:36.090 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001fa5b23 on channel mihome:sensor_weather_v1:158d0001fa5b23:batteryLevel received command REFRESH
2018-02-23 10:21:36.091 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001f508a6' changed from OFFLINE to ONLINE
2018-02-23 10:21:36.091 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Device 158d0001fa5b23 on channel mihome:sensor_weather_v1:158d0001fa5b23:lowBattery received command REFRESH
2018-02-23 10:21:36.093 [vent.ItemStateChangedEvent] - Xiaomi_TH1_Humidity changed from 35.720001220703125 to 33.849998474121094
2018-02-23 10:21:36.093 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Update Item 158d0001fa5b23 with retented message
2018-02-23 10:21:36.093 [DEBUG] [home.handler.XiaomiDeviceBaseHandler] - Item got update: {"cmd":"read_ack","model":"weather.v1","sid":"158d0001fa5b23","short_id":13787,"data":"{\"voltage\":3075,\"temperature\":\"2265\",\"humidity\":\"2798\",\"pressure\":\"101439\"}"}
2018-02-23 10:21:36.094 [hingStatusInfoChangedEvent] - 'mihome:sensor_weather_v1:158d0001fa5b23' changed from OFFLINE to ONLINE
2018-02-23 10:21:36.094 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Data received and notified 1 listeners
2018-02-23 10:21:36.095 [TRACE] [.mihome.internal.socket.XiaomiSocket] - Thread Thread[Thread-97,5,main] waiting for data on port 9898
2018-02-23 10:21:36.098 [vent.ItemStateChangedEvent] - Xiaomi_TH1_Temperature changed from 23.3700008392334 to 23.239999771118164
2018-02-23 10:21:36.098 [vent.ItemStateChangedEvent] - Xiaomi_TH1_Pressure changed from 101.46900177001953 to 101.4800033569336
I add multicast routing:
$ netstat  -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
224.0.0.0       0.0.0.0         240.0.0.0       U         0 0          0 eth0
But there is nothing in tcpdump besides 3 packet at the begginig (after bundle:restart)
$ sudo tcpdump -n -i eth0 -s0 -vv net 224.0.0.0/4 | egrep -v -e "192.168.199.24[67]"
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
12:37:40.683206 IP (tos 0xc0, ttl 1, id 0, offset 0, flags [DF], proto IGMP (2), length 40, options (RA))
    192.168.199.251 > 224.0.0.22: igmp v3 report, 1 group record(s) [gaddr 224.0.0.50 to_in { }]
12:37:40.723203 IP (tos 0xc0, ttl 1, id 0, offset 0, flags [DF], proto IGMP (2), length 40, options (RA))
    192.168.199.251 > 224.0.0.22: igmp v3 report, 1 group record(s) [gaddr 224.0.0.50 to_ex { }]
12:37:41.187268 IP (tos 0xc0, ttl 1, id 0, offset 0, flags [DF], proto IGMP (2), length 40, options (RA))
But there are no further debug messages from the binding. Total silence, no interaction between the binding and the gateway, and no heartbeats. Nothing in tcpdump. Nothing in localhost:8080/rest/events.
I need help. What I am doing wrong?
it’s problem of my network configuration. When I put Xiaomi Gateway in the same network as OH2 -> everything is OK.
I have Cisco ASA 5505 as my firewall/router and I have problem with multicast routing between two VLANs. It’s not problem of add-on.
18:46:28.963199 IP (tos 0xc0, ttl 1, id 0, offset 0, flags [DF], proto IGMP (2), length 40, options (RA))
18:46:29.755230 IP (tos 0xc0, ttl 1, id 0, offset 0, flags [DF], proto IGMP (2), length 40, options (RA))
18:46:32.947451 IP (tos 0x0, ttl 255, id 1430, offset 0, flags [none], proto UDP (17), length 166)
    192.168.199.204.4321 > 224.0.0.50.9898: [udp sum ok] UDP, length 138
18:46:42.929347 IP (tos 0x0, ttl 255, id 1432, offset 0, flags [none], proto UDP (17), length 166)
18:46:52.911422 IP (tos 0x0, ttl 255, id 1434, offset 0, flags [none], proto UDP (17), length 166)
At the begining OH2 send IGMP v3 packet with Multicast Group address of 224.0.0.50. It is equal to:
iperf -s -u -B 224.0.0.50 -i 1
After that Xiaomi Gateway join Multicast group and send hearbeats to this address to udp/9898 port.
