I encounter a problem with my Xiaomi Mi smart home devices.
Hardware:
Xiaomi Aqara gateway V2 Gateway
Xiaomi Aqara temperature and humidity sensor
Binding used:
Xiami Mi Smart home Binding
I did the modification in the gateway in order to open the port and the communication is ok. I receive the information in openhab.
But after a delay 2-3 minutes. The communication shutdown
This is the message received in logs:
Blockquote
2019-07-27 11:26:35.255 [hingStatusInfoChangedEvent] - ‘mihome:bridge:7cxxxxxxxxxx’ changed from ONLINE to OFFLINE
2019-07-27 11:26:35.258 [hingStatusInfoChangedEvent] -
‘mihome:sensor_weather_v1:7cxxxxxxxxxx:158dyyyyyyyyyy’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-07-27 11:26:35.262 [hingStatusInfoChangedEvent] -
‘mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
These are the status in my PaperUi/things:
Xiaomi Gateway Z1 : Offline
Salon - Xiaomi Mi Smart Home Gateway : Offline - Bridge_Offline
Salon - Xiaomi Aqara Temp, Hum and Press Sensor : Offline - Bridge_Offline
Things file - xiaomi_smart_home.things
Blockquote
Bridge mihome:bridge:7cxxxxxxxxxx “Xiaomi Gateway Z1” [ serialNumber=“dddddddd”, ipAddress=“192.168.aaa.bbb”, port=9898, key=“cccccccccccccccccc”, pollingInterval=6000 ] {
Things:
gateway 7cxxxxxxxxxx “Salon - Xiaomi Mi Smart Home Gateway” [itemId=“7cxxxxxxxxxx”]
sensor_weather_v1 158dyyyyyyyyyy “Salon - Xiaomi Aqara Temp, Hum and Press Sensor” [itemId=“158dyyyyyyyyyy”]
Items file - xiaomi_smart_home.items
Blockquote
// Replace with itemId of gateway from Things file
// Replace with itemId of item from Things file
// Gateway
Switch Gateway_LightSwitch { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:brightness” }
Dimmer Gateway_Brightness { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:brightness” }
Color Gateway_Color { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:color” }
Dimmer Gateway_ColorTemperature { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:colorTemperature” }
Number Gateway_AmbientLight { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:illumination” }
Number Gateway_Sound { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:sound” }
Switch Gateway_SoundSwitch <soundvolume_mute> { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:enableSound” }
Dimmer Gateway_SoundVolume { channel=“mihome:gateway:7cxxxxxxxxxx:7cxxxxxxxxxx:volume” }
// Aqara Temperature, Humidity and pressure Sensor
Number:Temperature XiaomiTpHum_Z1_Tp { channel=“mihome:sensor_weather_v1:7cxxxxxxxxxx:158dyyyyyyyyyy:temperature” }
Number:Dimensionless XiaomiTpHum_Z1_Hum { channel=“mihome:sensor_weather_v1:7cxxxxxxxxxx:158dyyyyyyyyyy:humidity” }
Number:Pressure XiaomiTpHum_Z1_P { channel=“mihome:sensor_weather_v1:7cxxxxxxxxxx:158dyyyyyyyyyy:pressure” }
Number XiaomiTpHum_Z1_Battery { channel=“mihome:sensor_weather_v1:7cxxxxxxxxxx:158dyyyyyyyyyy:batteryLevel” }
Switch XiaomiTpHum_Z1_BatteryLow { channel=“mihome:sensor_weather_v1:7cxxxxxxxxxx:158dyyyyyyyyyy:lowBattery” }
Feel free to ask more informations.
Thank for your help
