Sorry, I did not realize there was PR open for review.
Will check tonight.
Wrt your question: normally there should be no need for an update for these kinds of PR’s
ok, I got it working by applying the above PR changes to the main branch + adding test device database information for roborock.vacuum.a27.json. I copied the resulting jar to the addons folder, but add to add a vacuum thing manually.
Question: Could I observe status and filling of the fresh and dirty water tanks. This would be an important feature to say “Hey Markus, the fresh water tank needs a refill or empty the dirty water tank”
I assume you see such a level in the mihome app, right?
If there is not such a channel already available (I thought there is a waterbox status channel), can you share the (debug log) response of full refresh esp the response to get_status is to be double checked as it may have changed again for your model.
It may also be interesting to see the response to get_fw_features for this model. note: this is only executed if you enable the info#fw_features channel.
I don’t think you need a db file for this model. The database is used for miio:basic, miio:gateway & miio:lumi. It is not used for miio:unsupported & miio:vacuum. The latter is what is driving your vacuum I expect.
Alternative way (until the PR is included, or on older OH versions) to enable your device is to override the model in the config with one of the supported rockrobo models like e.g. roborock.vacuum.a15
Not me. I was able to map certain coordinates and to issue a command that sends the robot to certain rooms, or in a specific situation, to the bin. But nothing like pin and go. I need to find the exact coordinates beforehand.
ok, rooms etc. is also working for me.
But i want the robo to go to an place an stay there till i clean sensors etc.
or even make it smart if sensor etc is full or dirty go to point XY
Not sure what you exactly look for. You can indeed goto a location. The robot will ‘fall asleep’ if no further commands are given.
You can use this little addon to find the location coordinates. Xiaomi Vacuum Map Viewer (to find coordinates for zone cleaning)
Ooooh I like that. Hadn’t thought of automatically sending the robot somewhere when cleaning is needed. But yes it’s quite easy to do.
Map all of the sensors to items and create a rule: when they reach the threshold, send to “place to be cleaned”.
The user above has shared what I used to map the coordinates.
Just define a specific place (I used the garbage bin) pick the coordinates and send it there.
I’m using Network Binding to ping my robot to detect if it’s online or not, but it does not seem a decent way. Is there another way to check the device’s online/offline status?
In PiotrMachowski integration though he took indeed the cloud integration & map parsing based on the miio binding, he also extended it with parsing of the map formats for viomi, ro & dreame.
The miio binding only supports roborock map format. Hence it is why it does not work for your vacuum.
It would require some development to build such support also in the miio binding.
