Let me know the one that works best, and your original model and I add it to the database
how do I extract the token on android, all the successful guides above were made for ios users.thanks
Is someone running this Binding on OH 2.4 Milestone build ?
I Updated from 2.3 to Milestone and the Mi io Binding is gone. Cant Install it from Papier ui or habmin because its missing in the add ons too. Any Idea ?
@mr.mixx Please make sure you have installed the “Eclipse IoT Market” in Misc-Section and change the setting to “Alpha” under Configuration -> System.
If this doesn’t work:
You can download the jar-File directly from here and place it in the addons-Folder:
btw. If you can’t see the bindings from the Marketplace, there has been a problem with the Marketplace over the last few days.
There is a fix described in this thread.
https://community.openhab.org/search?q=Failed%20downloading%20Marketplace%20entries
Thx for your Help @michaeljoos and @ John.
It was the Problem with the Marketplace. Following the instructions in the topic solved the Problem.
hey, could you add a working link please? your link brings me to the search page of openhab with a bunch of different topics, but not no a related problem solving help… many thanks!
Sorry try this
I have added th following thing to .things:
Thing miio:vacuum:0XXXXXXX “Xiaomi Robot Vaccum Cleaner” [ host=“192.168.0.xxx”, token=“xxxxxxxxxxxxxxxx” ]
Currently I am getting “Configuration Error”. The token i used worked for me, but now I have change to this binding, update the Mi Home App and updated the robot software. Might be that the token is no more valid?
Also,
Should I use miio:vacuum or miio:generic?
[Edited]
1. It was an issue with the token. I have extracted the token again and now it works
2. I use miio:vacuum and it seems to work fine
Thx for any help
Thank you for this great binding,
I’m using it for the Xiaomi PHILIPS Zhirui Smart LED Bulb E14 Candle Lamp.
https://www.gearbest.com/candle-bulbs/pp_1645206.html
can you please add the device string philips.light.candle so it isnt detected as unsupported device ?
I’ve set it up as basic device with device model string philips.light.bulb and can confirm all channels are working.
Edit:
Ok not all channels are working DV and SwitchScene return
Error received: {"code":-10000,"message":"Method not found."}
Thank @Ilias as it is somewhat different, I’ll make a copy and remove those properties.
I’m on holidays at the moment, will do when I’m back
Hi, can someone give me example of miio.thinks file for Philips ZhiRui bedside lamp?
I tryed
Thing miio:lumi-gateway-v3_miio80945609:0444589 “Philips ZhiRui bedside lamp” [ host=“192…”, token=“xxx” ]
Thing miio:generic:0444589 “Philips ZhiRui bedside lamp” [ host=“192…”, token=“xxx” ]
but seems not working …
or
Thing miio:unsupported:0444589 “Philips ZhiRui bedside lamp” [ host=“192…”, token=“xxx” ]
(with this “unsupported” show online but only items power and command …)
The number is MAC of the lamp wifi internaface or something else?
also miio.items file will be handy
Thnx
Your device is not yet supported.
Try as thing miio:basic
Than change in the config the model to philips.light.bulb
For example item file look in the readme
Hi Marcel, you are so good, reply even from holifday
Means:
Thing miio:basic:ZZZ “Philips ZhiRui bedside lamp” [ host=“192…”, token=“xxx” ]
what to use as ZZZ? random 7digit number?
What you mean by changing model in config? Means add items into miio.items file like this?
Switch power “Power” {channel=“miio:basic:ZZZ:power”}
Number brightness “Brightness” {channel=“miio:basic:ZZZ:brightness”}
Number cct “Correlated Color Temperature” {channel=“miio:basic:ZZZ:cct”}
Number scene “Scene” {channel=“miio:basic:ZZZ:scene”}
Number dv “DV” {channel=“miio:basic:ZZZ:dv”}
Switch switchscene “Switch Scene” {channel=“miio:basic:ZZZ:switchscene”}
Switch delayoff “Delay Off” {channel=“miio:basic:ZZZ:delayoff”}
Switch toggle “Toggle” {channel=“miio:basic:ZZZ:toggle”}
In Inbox I see 2 items (after i added binding and try discovery - without items and thinks files)
Xiaomi Mi IO Device 04D37F89 (80969609) lumi-gateway-v3_miio80969609 (miio:unsupported:04D37F89)
and
Xiaomi Mi IO Device 0533726B (87257707) (miio:generic:0533726B)
Readme is very vell done!
If I like you help add this lamp into your Binding, what you need from me to investigate?
Enjoy holiday!
Based on what your discovery have I guess
Device 0533726B is your light (unless you have other Xiaomi devices as well)
When adding by file I think you can give it any Id, not even need to be 0533726B. This is is just the Id the device gives itself.
Any way with model I mean something like this
Thing miio:basic:0533726B “Philips ZhiRui bedside lamp” [ host=“192…”, token=“xxx” ,model="philips.light.bulb"]
To add it as supported device, please check if it is like any of the existing Phillips light devices (by testing the various Phillips lamp model strings)
Than let me know what is your model and which device it is similar to. I can then add it to the database. If too different, a new database needs to be created... You'll need than to scout the internet for info for for device
I have an issue with the Yeelight LED Ceiling Lamp v4 (JIAOYUE 650 RGB)
When I want to change the brightness of the lamp it does not work.
Changing ambient brightness works and changing night brightness works only the normal brightness channel is not working. (miio:generic:0456E259:brightness)
I can change the value of the item attached to it to what ever I want but there is no reaction, also there is nothing in the logs when turning on the lamp. Normally it should log the change in brightness value then right ?
What can I do to fix it?
@marcel_verpaalen could you advise on that?
Is there a full list of error states? Want to use a german map transformation for the “error string”.
For status string i use:
String statusStatus “Status [MAP(xiaomistatus.map):%s]” (gVacStat) {channel=“miio:vacuum:XXX:status#state”}
xiaomistatus.map
Idle=Einsatzbereit
Sleeping=Ruhemodus
Cleaning=am Saugen
Paused=Pause
Returning Dock=zurück zum Dock
Charging=Lädt
But not sure if this is really the full list.
For the list of errors see here
However I think you need this list
