Works perfectly that way. Thanks a lot!
hi, I also have an S12, can you explain the configuration better? Thank you
I managed to get everything to work, one question… is it possible to know when the water tank is empty?
always me…I managed to get everything to work, but I can’t get the map. I have read tons of posts, but without finding the solution. If I run the command: openhab:send (item) get_map I get nothing…any suggestions? I attach my thing
Amministrazione
Things
Loading...
Label of the thing
status badge
This contains the thing UID
Label of the thing
status badge
Label of the thing
status badge
Label of the thing
status badge
Label of the thing
status badge
Label of the thing
status badge
Label of the thing
status badge
Label of the thing
status badge
Label of the thing
status badge
Label of the thing
status badge
Unsupported Xiaomi Mi Device
1
UID: miio:unsupported:ce7d0d494e
2
label: Unsupported Xiaomi Mi Device
3
thingTypeUID: miio:basic
4
configuration:
5
cloudServer: de
6
refreshInterval: 30
7
host: 192.168.1.xxx
8
model: xiaomi.vacuum.b106eu
9
communication: cloud
10
deviceId: "xxxxxx"
11
timeout: 15000
12
token: xxxxxxxxxxxxxxx
13
14
channels:
15
- id: network#ssid
16
channelTypeUID: miio:ssid
17
label: SSID
18
description: null
19
configuration: {}
20
- id: network#bssid
21
channelTypeUID: miio:bssid
22
label: BSSID
23
description: null
24
configuration: {}
25
- id: network#rssi
26
channelTypeUID: miio:rssi
27
label: RSSI
28
description: null
29
configuration: {}
30
- id: network#life
31
channelTypeUID: miio:life
32
label: Life
33
description: null
34
configuration: {}
35
- id: actions#commands
36
channelTypeUID: miio:commands
37
label: Execute Command
38
description: null
39
configuration: {}
40
- id: actions#rpc
41
channelTypeUID: miio:rpc
42
label: Execute RPC (cloud) Command
43
description: null
44
configuration: {}
45
- id: actions
46
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_actions
47
label: Actions
48
description: null
49
configuration: {}
50
- id: status
51
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_status
52
label: Robot Cleaner - Status
53
description: null
54
configuration: {}
55
- id: fault
56
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_fault
57
label: Robot Cleaner - Device Fault
58
description: null
59
configuration: {}
60
- id: mode
61
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_mode
62
label: Robot Cleaner - Mode
63
description: null
64
configuration: {}
65
- id: sweep_type
66
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_sweep_type
67
label: Robot Cleaner - Sweep Type
68
description: null
69
configuration: {}
70
- id: restricted_walls
71
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_restricted_walls
72
label: Robot Cleaner - Restricted Walls
73
description: null
74
configuration: {}
75
- id: battery_level
76
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_battery_level
77
label: Battery - Battery Level
78
description: null
79
configuration: {}
80
- id: alarm
81
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_alarm
82
label: Alarm - Alarm
83
description: null
84
configuration: {}
85
- id: volume
86
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_volume
87
label: Alarm - Volume
88
description: null
89
configuration: {}
90
- id: repeat_state
91
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_repeat_state
92
label: Sweep - Repeat State
93
description: null
94
configuration: {}
95
- id: door_state
96
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_door_state
97
label: Sweep - Door State
98
description: null
99
configuration: {}
100
- id: cloth_state
101
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_cloth_state
102
label: Sweep - Cloth State
103
description: null
104
configuration: {}
105
- id: suction_state
106
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_suction_state
107
label: Sweep - Suction State
108
description: null
109
configuration: {}
110
- id: water_state
111
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_water_state
112
label: Sweep - Water State
113
description: null
114
configuration: {}
115
- id: mop_route
116
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_mop_route
117
label: Sweep - Mop Route
118
description: null
119
configuration: {}
120
- id: side_brush_life
121
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_side_brush_life
122
label: Sweep - Side Brush Life
123
description: null
124
configuration: {}
125
- id: side_brush_hours
126
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_side_brush_hours
127
label: Sweep - Side Brush Hours
128
description: null
129
configuration: {}
130
- id: main_brush_life
131
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_main_brush_life
132
label: Sweep - Main Brush Life
133
description: null
134
configuration: {}
135
- id: main_brush_hours
136
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_main_brush_hours
137
label: Sweep - Main Brush Hours
138
description: null
139
configuration: {}
140
- id: hypa_life
141
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_hypa_life
142
label: Sweep - Hypa Life
143
description: null
144
configuration: {}
145
- id: hypa_hours
146
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_hypa_hours
147
label: Sweep - Hypa Hours
148
description: null
149
configuration: {}
150
- id: mop_life
151
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_mop_life
152
label: Sweep - Mop Life
153
description: null
154
configuration: {}
155
- id: mop_hours
156
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_mop_hours
157
label: Sweep - Mop Hours
158
description: null
159
configuration: {}
160
- id: direction
161
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_direction
162
label: Sweep - Direction
163
description: null
164
configuration: {}
165
- id: time_zone
166
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_time_zone
167
label: Sweep - Time Zone
168
description: null
169
configuration: {}
170
- id: cur_lang
171
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_cur_lang
172
label: Sweep - Cur Lang
173
description: null
174
configuration: {}
175
- id: cleaning_time
176
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_cleaning_time
177
label: Sweep - Cleaning Time
178
description: null
179
configuration: {}
180
- id: cleaning_area
181
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_cleaning_area
182
label: Sweep - Cleaning Area
183
description: null
184
configuration: {}
185
- id: dirt_recognize
186
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_dirt_recognize
187
label: Sweep - Dirt Recognize
188
description: null
189
configuration: {}
190
- id: pet_recognize
191
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_pet_recognize
192
label: Sweep - Pet Recognize
193
description: null
194
configuration: {}
195
- id: ai_recognize
196
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_ai_recognize
197
label: Sweep - Ai Recognize
198
description: null
199
configuration: {}
200
- id: carpet_booster
201
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_carpet_booster
202
label: Sweep - Carpet Booster
203
description: null
204
configuration: {}
205
- id: multi_prop_vacuum
206
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_multi_prop_vacuum
207
label: Sweep - Multi Prop Vacuum
208
description: null
209
configuration: {}
210
- id: carpet_avoid
211
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_carpet_avoid
212
label: Sweep - Carpet Avoid
213
description: null
214
configuration: {}
215
- id: tank_shake
216
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_tank_shake
217
label: Sweep - Tank Shake
218
description: null
219
configuration: {}
220
- id: shake_shift
221
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_shake_shift
222
label: Sweep - Shake Shift
223
description: null
224
configuration: {}
225
- id: map_encrypt
226
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_map_encrypt
227
label: Sweep - Map Encrypt
228
description: null
229
configuration: {}
230
- id: order_id
231
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_order_id
232
label: Order - Order Id
233
description: null
234
configuration: {}
235
- id: enable
236
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_enable
237
label: Order - Enable
238
description: null
239
configuration: {}
240
- id: day
241
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_day
242
label: Order - Day
243
description: null
244
configuration: {}
245
- id: hour
246
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_hour
247
label: Order - Hour
248
description: null
249
configuration: {}
250
- id: minute
251
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_minute
252
label: Order - Minute
253
description: null
254
configuration: {}
255
- id: repeat
256
257
label: Order - Repeat
258
description: null
259
configuration: {}
260
- id: clean_way
261
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_clean_way
262
label: Order - Clean Way
263
description: null
264
configuration: {}
265
- id: suction
266
267
label: Order - Suction
268
description: null
269
configuration: {}
270
- id: water
271
272
label: Order - Water
273
description: null
274
configuration: {}
275
- id: twice_clean
276
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_twice_clean
277
label: Order - Twice Clean
278
description: null
279
configuration: {}
280
- id: mapid
281
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_mapid
282
label: Order - Mapid
283
description: null
284
configuration: {}
285
- id: room_count
286
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_room_count
287
label: Order - Room Count
288
description: null
289
configuration: {}
290
- id: room_data
291
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_room_data
292
label: Order - Room Data
293
description: null
294
configuration: {}
295
- id: time_zone1
296
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_time_zone1
297
label: Order - Time Zone
298
description: null
299
configuration: {}
300
- id: all_enable_count
301
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_all_enable_count
302
label: Order - All Enable Count
303
description: null
304
configuration: {}
305
- id: zone_points
306
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_zone_points
307
label: Point Zone - Zone Points
308
description: null
309
configuration: {}
310
- id: restrict_points
311
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_restrict_points
312
label: Point Zone - Restrict Points
313
description: null
314
configuration: {}
315
- id: target_point
316
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_target_point
317
label: Point Zone - Target Point
318
description: null
319
configuration: {}
320
- id: remember_state
321
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_remember_state
322
label: Map - Remember State
323
description: null
324
configuration: {}
325
- id: cur_map_id
326
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_cur_map_id
327
label: Map - Cur Map Id
328
description: null
329
configuration: {}
330
- id: map_num
331
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_map_num
332
label: Map - Map Num
333
description: null
334
configuration: {}
335
- id: cur_cleaning_path
336
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_cur_cleaning_path
337
label: Map - Cur Cleaning Path
338
description: null
339
configuration: {}
340
- id: build_map
341
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_build_map
342
label: Map - Build Map
343
description: null
344
configuration: {}
345
- id: has_new_map
346
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_has_new_map
347
label: Map - Has New Map
348
description: null
349
configuration: {}
350
- id: map_uploads
351
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_map_uploads
352
label: Map - Map Uploads
353
description: null
354
configuration: {}
355
- id: dnd_enable
356
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_dnd_enable
357
label: Disturb - Dnd Enable
358
description: null
359
configuration: {}
360
- id: dnd_start_hour
361
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_dnd_start_hour
362
label: Disturb - Dnd Start Hour
363
description: null
364
configuration: {}
365
- id: dnd_start_minute
366
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_dnd_start_minute
367
label: Disturb - Dnd Start Minute
368
description: null
369
configuration: {}
370
- id: dnd_end_hour
371
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_dnd_end_hour
372
label: Disturb - Dnd End Hour
373
description: null
374
configuration: {}
375
- id: dnd_end_minute
376
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_dnd_end_minute
377
label: Disturb - Dnd End Minute
378
description: null
379
configuration: {}
380
- id: multi_prop_dnd
381
channelTypeUID: miio:XIAOMI_VACUUM_B106EU_multi_prop_dnd
382
label: Disturb - Multi Prop Dnd
383
description: null
384
configuration: {}
385
Standard Library (Cells)
Personal Widgets
Maps are currently only supported on roborock vacuums.
I have the problem that the cleaning#last_clean_end_time
channel is no longer updated on my Roborock S5 Max. And the channel cleaning#last_clean_start_time
shows the end time instead.
I am using the stable release 4.1.2.
I have downgraded to the binding of version 4.0.4 org.openhab.binding.miio-4.0.4.jar
, so it works perfectly. Presumably there has been an error here from 4.0 to 4.1?
Here is an excerpt from the log after a short cleaning:
2024-04-28 17:21:40.556 [DEBUG] [nal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":2430,"method":"get_clean_record","params":[1714317639]} -> 192.168.86.111 (Device: 261660045 token: 6B4C6233XXXXXXXXXXXXXXXX6F737A4D Queue: 5).
2024-04-28 17:21:40.683 [DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for device 0F989D8D type: CLEAN_RECORD_GET, result: [[1714317639,1714317694,55,1142500,0,0,2,3,60]], fullresponse: {"result":[[1714317639,1714317694,55,1142500,0,0,2,3,60]],"id":2430}
Edit 01.06.2024: I have seen that this is already fixed in 4.2.0.M1: 16388
hi ,is there a way to find out the room numbers that my S5 assign every time the map changes?
Hey there,
can somebody tell me if the dreame ls10 ultra works with the binding or maybe even the dreame ls10 ultra heat?
Thanks a lot
They should begin at number 16, go from there and check which room the vaccum goes to.
Hi all,
can someone tell me how I can get the error ids of e.g. dreame.vacuum.r2228o and what the numbers mean.
BR Andreas
Hi everyone,
I can’t get my dreame.vacuum.p2150b connected to the binding. From what I have seen it is not supported either, is there a solution for this?
Greetings
Daniel
Did you try the create experimental support switch.
Old try
You could try look at the definitions for some of the other dreame models.
If i recall right there are descriptions. ( Look in the readme or on openhab GitHub miio binding database
