Ok answered it myself…I made a backup of the token and deleted the cleaner in OpenHAB. Then, I tried to discover the cleaner, found it and inserted the saved token. Voila, cleaner available in OpenHAB again.
I have a yeelight light strip rgb. It is wokring with this binding.
Can i disbale internet access for this inside my router (so only lan connection is possible) or will this light strip stop working after that?
I can see many connections to xiaomi servers.
The first version of the vacuum cleaner supports zone cleaning since a couple of days. Any plans to extend the binding accordningly?
Here is a discussion for ioBroker (in German): https://forum.iobroker.net/viewtopic.php?p=138421
Yes, probably at some point when the coordinate stuff is better understood.
Note that you can obviously already use the command using the command channel
You talk about this? https://github.com/marcelrv/XiaomiRobotVacuumProtocol/blob/master/app_zoned_clean.md
Do you have an example how to execute such a command?
Ah, seems to be miio:vacuum:{thingId}:actions#commands
yes, indeed… might need bit of experimenting with the exact format.
based on the stuff I’ve seen I expect you need to send like app_zoned_clean[[26234,26042,27284,26642,2]]
What is the status of this issue (the threading issue Xiaomi Robot Vacuum Binding) ? Is this being tracked in an issue somewhere.
I’d like to help if its not been fixed.
super. great work.
Yes, it is fixed, thanks to @mhilbush!
I got a new vacuum (version 1) and want to connect it to OH2 without going to the cloud, but I struggle to get the token.
My computer is connected to my ‘normal’ network via LAN to have access to OH2 and to the vacuum via WiFi. The binding is installed.
When I start the recovery, no vacuum is found by OH2.
What is my mistake?!
Thanks for help!
@Budo possibly try to ping your robot to ensure you have good connectivity to it.
note that getting the vacuum to work without cloud access is still somewhat tricky.
check out https://github.com/dgiese/dustcloud.git
It has an alternative cloud implementation. You would need to root your device for it, and it is still quite alpha status
didnt try with zoned cleanup, but goto works
rule "test"
Item test received command
if (receivedCommand==ON){
sendCommand(RoborockVacuumS5Miio74478323_ActionsCommands,"app_goto_target[20000,25000]" )
Thanks for the fast answer! I did not get it working without registering via app. Two Mi Robots are working like a charm.
Thanks for the great binding!
i have a problem with the MiIoAsyncCommunication every 3 - 5 days.
Every 30 seconds i see this in the openhab.log
2018-04-26 18:17:46.430 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
2018-04-26 18:17:46.441 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
2018-04-26 18:17:46.451 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
2018-04-26 18:17:46.463 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
2018-04-26 18:18:16.525 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
2018-04-26 18:18:16.535 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
2018-04-26 18:18:16.544 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
2018-04-26 18:18:16.552 [INFO ] [nal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
I can not see the current values from my vacuum robot…
When i restart openhab, the communication is ok again.
Does anyone have an idea?
Does it help to restart the xiaomi device that is causing this?
What you can try to do is to edit the vacuum settings (any change will do), or restart the binding itself.
If that does the trick somehow this can be narrowed down to the binding.
In that case, please change the log settings to debug to see the detailed communication. Maybe that tells some more
What version is your firmware ? What is the hardware you are running this on?
I had the binding working perfectly with my Roborock 2 but then I updated the firmware to 3.3.9_001228. Now I get Communication error. Is there anyone else having this trouble?
Thanks for a great binding
Hey Ellis,
thanks for the wrap up and special thanks to @marcel_verpaalen. I know the main language of the community is english. But maybe you are able to follow the german Tutorial on YouTube. I am going step by step through the integration of the yeelight. 30 Minutes
Have a nice weekend.
Best regards
Thomas
Hi everyone,
This rule works for zone cleanup:
rule "Staubi_Esstisch"
Item StaubiEsstisch received command
if (receivedCommand==ON) {
sendCommand(actionCommand,"app_zoned_clean[[26063,25178,28863,29278,1]]"
Thread::sleep(10)
StaubiEsstisch.postUpdate(OFF)
You can use the latest build of the Flole app to get the coordinates for the desired zone!
https://xiaomi.flole.de
Best regards
Thorsten
