In the PaperUI it looks like this:
Do you mean the indentifier “Yeelight1-5” in the PaperUI?
okay, and for the device that you want to send the color command to…
if click the edit button you can see the model. You can also override it there
Oh, you mean the ModelID? interesting, but how do I send RGB values while runtime within the rules to them?
I see…
I never tried it, but I think there are 2 ways with rules:
you can try something like
var HSB_WARM_WHITE = new HSBType(new DecimalType(30), new PercentType(20), new PercentType(100))
sendcommand ( lightthing, HSB_WARM_WHITE)
I really like it. It almost silent up to 60% of power, have some nice features like "natural wind " - when it simulates wind by oscillating speed and other features you could see in parameters. As always with xiaomi it looks way better than generic el-cheapo ones.
I’ve bought it for 179$ on ali with free shipping via UPS to Czech Republic and without any customs. (send from UK or EU I think).
hardwareVersion | MW300 |
modelId | zhimi.fan.v3 |
I have the same problem. Every time I do a scheduled cleanup, the map is different. Sometimes the map is even upside down! From what I’ve read in different forums there are 2 possible ways to deal with it:
I, for one, have given up on zone cleanup for now. I hope Xiaomi will release a new firmware which will fix the problem I have with solution 1.
Regards,
Thorsten
Same issues here.
The robot seems to act very stupid in “zoned cleanup”. For this reason I will wait (hope) for a relieable solution.
Thanks to the developer(s) anyway! Good job!
Yes I also noticed that when I start a zoned cleanup it acts very weird compared to a normal cleanup. It always stucks on places where in a normal cleanup has zero issues…
Hope this is just temporaly. My vacuum is not so old, and I know this zoned cleanup thing is introduced in the latest update (I have the v1 vacuum), so I’m hoping that this will improve!
Hello! Does this plugin/addon support Xiaomi Yeelight RGB bulb? Thanks
Yes, most functions are supported for the regular RGB model.
Hello guys,
As u noticed i’m new on oh and i will like to know if is possible to
P.S.
from basic ui i can start stop and dock
Yes, you can send any command through the command channel (unhide it in paperui as it an advanced channel)
Look on my github page for the command to add a schedule
THX.
Dude ur awesome.
.things:
Thing miio:basic:MyLight "My Light" [ host="192.168.178.78", token="token" ]
.items:
String MyLight_ActionCommands "Action Commands" {channel="miio:basic:MyLight:actions#commands"}
.rules:
var vHSBType = new HSBType(new DecimalType(30), new PercentType(20), new PercentType(100))
sendcommand(MyLight_ActionCommands, vHSBType)
logs:
logreader:reader:e21bd3bb:newErrorEvent triggered 2018-06-09 08:25:17.842 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule '7 Farben auswählen': The name 'MyLight_ActionsCommands' cannot be resolved to an item or type; line 40, column 17, length 23
So logs say the variable or thing isn’t defined at all, what am I doing wrong?
Your are sending a HSBType into String : not possible.
In the MyLight_ActionCommands, you should only send String according to the Yeelight spec.
Yeah I was aware of this, but I don’t even know which datatype you should use for a HSB Type lol
Thank you Ill check it out
Probably Color when I think about it
Try to create a string with the set_hsv function (concatenate string and int values from HSBType).
sendCommand(MyLight_ActionsCommands, 'set_hsv[245, 55, "smooth", 2000]')
Then do the same with set_bright for the brightness part of HSBType.
Note : I have not tested this solution.
Anyone else lost access to everything on mi home app since last night?
Is the “Xiaomi Mijia Smart LED Desk Lamp” (MJTD01YL) also supported? See https://www.mi.com/en/smartlamp/
