Xiaomi Robot Vacuum Binding
Ok the exact model string is roborock.vacuum.s4
and I sent you a message with a link to the files and a screenshot of the mihome app map.
Thanks :slightly_smiling_face:
Now i get the map, it’s almost perfect as you can see, the only thing missing is the lines showing progress
great job thanks :muscle:
I think it is a problem of the line colour rather than it missing… I made the colour white for the S5 map (v1.1) but yours is a v1.0 map and it gets the colour from the regular vacuums that is almost matching the colour of the room…
For the next release I’ll see if I can change it to be more pronounced
I noticed that on my roborock thing the hours left for consumables are not populated as channels. Is that by design for this particular model?
I see there are some values in the event object in the JSON response, under the consumable_item_prop_cache field but these are not meaningful for me. Tried if they’re millis but they do not match the value in their UI.
I can attach the response if you think it can help in any way… I didn’t see any passwords inside so I guess you’ve fixed the secure logging already. :slight_smile:
Cheers,
Konstantin
Yes, that will be helpful. I think the newer models have different response than the older ones causing this.
and yes… I took out the passwd indeed after I added the necessary checks that they were present and log messages if they were not.
Hi Marcel,
here you are. Only the event, I guess the rest is not needed: event.json (2.6 KB)
Thanks for doing this for us ! :slight_smile:
Cheers,
Konstantin
@marcel_verpaalen thnx mate for ur work,i have roborock s5 ,tried to test new map feature but never got any map.I uninstalled the old binding ,add new jar in addons folder.No change at my vaccum’s channels.I removed vacuum thing and rediscovered it and i got new map channel,but vaccum cant get token from cloud.I config the binding settings with my account user,pass and country (gr) but no token.Only if i add token manually i get the vacuum “online” but still no map.I tried other eu countries but no luck.Do i have to reset my vacuum and add it again?i use the latest firmware with the new map-rooms feature.
Pls try to do Discovery with leaving the country setting empty. This will try all known servers.
You can see the response files in the user data/miio folder. You can open them to see if your device is defined in multiple servers. What may cause wrong tokens during discovery.
For EU the server is normally ‘de’
@marcel_verpaalen i do Discovery with leaving the country setting empty and i get this error
2020-04-01 16:47:37.693 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler MiIoVacuumHandler of thing miio:vacuum:05C2F417 tried updating channel consumables#consumable_reset although the handler was already disposed.
2020-04-01 16:47:37.699 [hingStatusInfoChangedEvent] - 'miio:vacuum:05C2F417' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_REGISTERING_ERROR)
2020-04-01 16:47:37.698 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while calling thing handler factory 'org.openhab.binding.miio.internal.MiIoHandlerFactory@19fe391': null
	at org.openhab.binding.miio.internal.handler.MiIoAbstractHandler.tokenCheckPass(MiIoAbstractHandler.java:128) ~[?:?]
	at org.openhab.binding.miio.internal.handler.MiIoAbstractHandler.getConnection(MiIoAbstractHandler.java:282) ~[?:?]
	at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.initializeData(MiIoVacuumHandler.java:400) ~[?:?]
	at org.openhab.binding.miio.internal.handler.MiIoVacuumHandler.<init>(MiIoVacuumHandler.java:88) ~[?:?]
	at org.openhab.binding.miio.internal.MiIoHandlerFactory.createHandler(MiIoHandlerFactory.java:87) ~[?:?]
	at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:126) ~[bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.doRegisterHandler(ThingManagerImpl.java:587) [bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.registerHandler(ThingManagerImpl.java:564) [bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.registerAndInitializeHandler(ThingManagerImpl.java:1056) [bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.thingAdded(ThingManagerImpl.java:445) [bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:211) [bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:131) [bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1) [bundleFile:?]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:157) [bundleFile:?]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:1) [bundleFile:?]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:56) [bundleFile:?]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:75) [bundleFile:?]
	at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:79) [bundleFile:?]
	at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.add(AbstractManagedProvider.java:64) [bundleFile:?]
	at org.eclipse.smarthome.core.common.registry.AbstractRegistry.add(AbstractRegistry.java:325) [bundleFile:?]
	at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.addThingSafely(PersistentInbox.java:630) [bundleFile:?]
	at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.approve(PersistentInbox.java:203) [bundleFile:?]
	at org.eclipse.smarthome.io.rest.core.internal.discovery.InboxResource.approve(InboxResource.java:104) [bundleFile:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
	at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [bundleFile:?]
	at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [bundleFile:?]
	at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [bundleFile:?]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
	at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
	at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
	at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
	at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
and at thing status i get
Status: UNINITIALIZED - HANDLER_REGISTERING_ERROR
I tried to replicate the issue with current binding… For me was working without error
I made significant updates the last 2 days based on the review feedback.
I uploaded the latest (link is the same) just now.
Maybe give that a try, there is a good chance that it was fixed in my update.
To replace, remove the old one first, than load the updated one.
thnx i got the map ,i added the token manually and then i config the binding using “de” as country code.Can we crop somehow the blue background so the map looks bigger at Habpanel?
Hello @marbon87 and @marcel_verpaalen
Could you share me your experiences?
Now, I’m also trying to integrate roborock s5 into OH2.4. However, I cannot control it.
The log always shows like those:
[DEBUG] [ing.miio.handler.MiIoAbstractHandler] - Received response for 07090C00 type: DND_GET, result: null, fullresponse: {“error”:“No Response”}
[DEBUG] [ing.miio.handler.MiIoAbstractHandler] - Error received: “No Response”
Thank you in advance,
no response = wrong token.
Try to get a correct token. You may want to try the experimental binding from a few topics up as that one gets the tokens from the cloud,. Otherwise see first topic for suggestions on how to get the token
I’m confusing that how it can ONLINE with a wrong token.
Yes, that’s the way I originally developed it… if the thing is responding to a ping I told it is online…
It will change to offline with configuration error if you wait a while.
I intend to change the behaviour to avoid the confusion in the future
with the “new” jar i get this when i change country at binding config.
2020-04-01 20:39:05.187 [ERROR] [org.openhab.binding.miio            ] - bundle org.openhab.binding.miio:2.5.4.202004011447 (283)[org.openhab.binding.miio.internal.MiIoHandlerFactory(268)] : The activate method has thrown an exception
	at org.openhab.binding.miio.internal.cloud.MiCloudConnector.loginStep1(MiCloudConnector.java:325) ~[?:?]
	at org.openhab.binding.miio.internal.cloud.MiCloudConnector.loginRequest(MiCloudConnector.java:286) ~[?:?]
	at org.openhab.binding.miio.internal.cloud.MiCloudConnector.login(MiCloudConnector.java:268) ~[?:?]
	at org.openhab.binding.miio.internal.cloud.CloudConnector.logon(CloudConnector.java:177) ~[?:?]
	at org.openhab.binding.miio.internal.cloud.CloudConnector.setCredentials(CloudConnector.java:163) ~[?:?]
	at org.openhab.binding.miio.internal.MiIoHandlerFactory.activate(MiIoHandlerFactory.java:67) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
	at java.security.AccessController.doPrivileged(Native Method) [?:1.8.0_222]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [bundleFile:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:734) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:673) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:435) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:316) [bundleFile:?]
	at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$2.configurationEvent(RegionConfigurationSupport.java:118) [bundleFile:?]
	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:1709) [bundleFile:?]
	at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:1651) [bundleFile:?]
	at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [bundleFile:?]
	at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [bundleFile:?]
and my 4 yeelights and my roborock goes
Status: UNINITIALIZED - HANDLER_MISSING_ERROR
I appreciate your suggestion,
I could get token from this comment:
Token
To have a working binding, a little difficult step needs to be done to retrieve the vacuum token.
The easiest way to obtain tokens is to browse through log files of the Mi Home app version 5.4.49 for Android. It seems that version was released with debug messages turned on by mistake. An APK file with the old version can be easily found using one of the popular web search engines. After downgrading use a file browser to navigate to directory SmartHome/logs/plug_DeviceManager , then open the most recent file and search for the token. When finished, use Google Play to get the most recent version back.
now I can receive below response even though it’s another problem
[DEBUG] [internal.handler.MiIoAbstractHandler] - Received response for 07090C00 type: DND_GET, result: {}, fullresponse: {“error”:“maximum number of DatagramSockets reached”}
Though I can’t replicate the issue you saw (tried on my system few times to add & remove countries, but did not see this), I did make small fix to avoid the ungraceful error you see and to avoid that the error is preventing the binding from starting up.
I uploaded it once more
what version of the binding are you using? Would you mind trying the new uploaded one, as one of the things it is suppose to solve is that datagram issue.
If you are already using it… I have a problem :slight_smile:
Hi Marcel,
I tried latest build minutes ago. Hours for S5 are calculated just fine now. Thank you for making this !
Out of curiosity…what stays behind the values in the JSON? Is it millis or something else?
Cheers,
Konstantin
