Just updated from the standalone Binding for the Robot to the Mi-IO Binding and got the same Problem as in a previous Version in the standalone-Binding that my two robots are Offline after a short time period.
The Thing Status is only: “OFFLINE - CONFIGURATION_ERROR” without any further Information.
I´ve set the log-level to verbose:
08:36:33.348 [DEBUG] [miio.internal.discovery.MiIoDiscovery] - No token discovered for device 03D87B3E. To discover token reset your device & connect to it's wireless network and re-run discovery. Read readme f or other options.
08:36:33.370 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":244,"method":"get_clean_summary","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Q ueue: 1)
08:36:33.665 [DEBUG] [miio.internal.discovery.MiIoDiscovery] - Discovered Mi IO Device 034D720F at 10.0.0.91 as miio:generic:034D720F
08:36:33.666 [DEBUG] [miio.internal.discovery.MiIoDiscovery] - No token discovered for device 034D720F. To discover token reset your device & connect to it's wireless network and re-run discovery. Read readme f or other options.
08:36:33.673 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":245,"method":"get_status","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 2 )
08:36:33.892 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":246,"method":"get_consumable","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queu e: 3)
08:36:33.906 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: DND_GET, result: [{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}], fullresponse: { "result":[{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}],"id":243}
08:36:34.423 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CLEAN_SUMMARY_GET, result: [320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505 800800,1505714400]], fullresponse: {"result":[320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505800800,1505714400]],"id":244}
08:36:35.038 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: GET_STATUS, result: [{"msg_ver":5,"msg_seq":78,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_c ode":0,"map_present":0,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}], fullresponse: {"result":[{"msg_ver":5,"msg_seq":78,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_code":0,"map_present":0, "in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":245}
08:36:35.050 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CONSUMABLES_GET, result: [{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":3203 01,"sensor_dirty_time":64809}], fullresponse: {"result":[{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":320301,"sensor_dirty_time":64809}],"id":246}
08:37:04.034 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Periodic update for 'miio:generic:034D720F' (miio:vacuum)
08:37:04.034 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":247,"method":"get_dnd_timer","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue : 1)
08:37:04.802 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":248,"method":"get_clean_summary","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Q ueue: 1)
08:37:05.775 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":249,"method":"get_status","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 2 )
08:37:05.930 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: DND_GET, result: [{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}], fullresponse: { "result":[{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}],"id":247}
08:37:15.930 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:37:15.966 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":250,"method":"get_consumable","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queu e: 3)
08:37:16.347 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CLEAN_SUMMARY_GET, result: [320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505 800800,1505714400]], fullresponse: {"result":[320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505800800,1505714400]],"id":248}
08:37:16.474 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: GET_STATUS, result: [{"msg_ver":5,"msg_seq":79,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_c ode":0,"map_present":0,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}], fullresponse: {"result":[{"msg_ver":5,"msg_seq":79,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_code":0,"map_present":0, "in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":249}
08:37:16.707 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CONSUMABLES_GET, result: [{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":3203 01,"sensor_dirty_time":64809}], fullresponse: {"result":[{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":320301,"sensor_dirty_time":64809}],"id":250}
08:37:37.772 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Skipping periodic update for 'miio:vacuum:03D87B3E'. Thing Status
08:37:37.773 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":62,"method":"miIO.info","params":[]} -> 10.0.0.92 (Device: 03D87B3E token: 627xxxHIDDENxxxx74F Queue: 1)
08:37:46.174 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Periodic update for 'miio:generic:034D720F' (miio:vacuum)
08:37:46.174 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":251,"method":"get_dnd_timer","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue : 1)
08:37:47.879 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.92: Receive timed out
08:37:47.879 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - No response from device 03D87B3E at 10.0.0.92 for command {"id":62,"method":"miIO.info","params":[]}.
08:37:47.879 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 03D87B3E type: MIIO_INFO, result: null, fullresponse: {"error":"No Response"}
08:37:47.879 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "No Response"
08:37:56.185 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:38:06.191 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:38:06.388 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":252,"method":"get_clean_summary","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Q ueue: 1)
08:38:06.401 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":253,"method":"get_status","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 2 )
08:38:06.407 [INFO ] [rnal.transport.MiIoAsyncCommunication] - Received message is invalid JSON:
08:38:06.408 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: DND_GET, result: null, fullresponse: {"error":"Received message is invalid JSON"}
08:38:06.408 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "Received message is invalid JSON"
08:38:10.667 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CLEAN_SUMMARY_GET, result: [320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505 800800,1505714400]], fullresponse: {"result":[320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505800800,1505714400]],"id":252}
08:38:12.210 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":254,"method":"get_consumable","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queu e: 2)
08:38:12.257 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: GET_STATUS, result: [{"msg_ver":5,"msg_seq":80,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_c ode":0,"map_present":0,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}], fullresponse: {"result":[{"msg_ver":5,"msg_seq":80,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_code":0,"map_present":0, "in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":253}
08:38:12.279 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CONSUMABLES_GET, result: [{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":3203 01,"sensor_dirty_time":64809}], fullresponse: {"result":[{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":320301,"sensor_dirty_time":64809}],"id":254}
08:38:42.234 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Periodic update for 'miio:generic:034D720F' (miio:vacuum)
08:38:42.234 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":255,"method":"get_dnd_timer","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue : 1)
08:38:42.384 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":256,"method":"get_clean_summary","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Q ueue: 1)
08:38:42.430 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":257,"method":"get_status","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 2 )
08:38:42.444 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: DND_GET, result: [{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}], fullresponse: { "result":[{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}],"id":255}
08:38:42.599 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":258,"method":"get_consumable","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queu e: 3)
08:38:42.840 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CLEAN_SUMMARY_GET, result: [320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505 800800,1505714400]], fullresponse: {"result":[320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505800800,1505714400]],"id":256}
08:38:43.151 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: GET_STATUS, result: [{"msg_ver":5,"msg_seq":81,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_c ode":0,"map_present":0,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}], fullresponse: {"result":[{"msg_ver":5,"msg_seq":81,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_code":0,"map_present":0, "in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":257}
08:38:43.248 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CONSUMABLES_GET, result: [{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":3203 01,"sensor_dirty_time":64809}], fullresponse: {"result":[{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":320301,"sensor_dirty_time":64809}],"id":258}
08:39:12.731 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Periodic update for 'miio:generic:034D720F' (miio:vacuum)
08:39:12.731 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":259,"method":"get_dnd_timer","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue : 1)
08:39:13.723 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":260,"method":"get_clean_summary","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Q ueue: 1)
08:39:13.750 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":261,"method":"get_status","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 2 )
08:39:13.764 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":262,"method":"get_consumable","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queu e: 3)
08:39:13.876 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: DND_GET, result: [{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}], fullresponse: { "result":[{"start_hour":22,"start_minute":0,"end_hour":8,"end_minute":0,"enabled":1}],"id":259}
08:39:13.934 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CLEAN_SUMMARY_GET, result: [320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505 800800,1505714400]], fullresponse: {"result":[320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505800800,1505714400]],"id":260}
08:39:13.952 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: GET_STATUS, result: [{"msg_ver":5,"msg_seq":82,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_c ode":0,"map_present":0,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}], fullresponse: {"result":[{"msg_ver":5,"msg_seq":82,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_code":0,"map_present":0, "in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":261}
08:39:14.600 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CONSUMABLES_GET, result: [{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":3203 01,"sensor_dirty_time":64809}], fullresponse: {"result":[{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":320301,"sensor_dirty_time":64809}],"id":262}
08:39:37.789 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Skipping periodic update for 'miio:vacuum:03D87B3E'. Thing Status
08:39:37.789 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":63,"method":"miIO.info","params":[]} -> 10.0.0.92 (Device: 03D87B3E token: 627xxxHIDDENxxxx74F Queue: 1)
08:39:43.894 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Periodic update for 'miio:generic:034D720F' (miio:vacuum)
08:39:43.894 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":263,"method":"get_dnd_timer","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue : 1)
08:39:47.909 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.92: Receive timed out
08:39:47.910 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - No response from device 03D87B3E at 10.0.0.92 for command {"id":63,"method":"miIO.info","params":[]}.
08:39:47.910 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 03D87B3E type: MIIO_INFO, result: null, fullresponse: {"error":"No Response"}
08:39:47.910 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "No Response"
08:39:53.905 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:39:54.381 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":264,"method":"get_clean_summary","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Q ueue: 1)
08:40:04.388 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:40:04.608 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":265,"method":"get_status","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 2 )
08:40:06.364 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":266,"method":"get_consumable","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queu e: 3)
08:40:16.371 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:40:26.823 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:40:26.823 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - No response from device 034D720F at 10.0.0.91 for command {"id":263,"method":"get_dnd_timer","params":[]}.
08:40:26.823 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: DND_GET, result: null, fullresponse: {"error":"No Response"}
08:40:26.823 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "No Response"
08:40:36.827 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:40:36.828 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - No response from device 034D720F at 10.0.0.91 for command {"id":264,"method":"get_clean_summary","params":[]}.
08:40:36.828 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CLEAN_SUMMARY_GET, result: null, fullresponse: {"error":"No Response"}
08:40:36.828 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "No Response"
08:40:46.817 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Periodic update for 'miio:generic:034D720F' (miio:vacuum)
08:40:46.818 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":267,"method":"get_dnd_timer","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue : 2)
08:40:46.838 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:40:46.838 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - No response from device 034D720F at 10.0.0.91 for command {"id":265,"method":"get_status","params":[]}.
08:40:46.838 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: GET_STATUS, result: null, fullresponse: {"error":"No Response"}
08:40:46.839 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "No Response"
08:40:56.841 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:40:56.841 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - No response from device 034D720F at 10.0.0.91 for command {"id":266,"method":"get_consumable","params":[]}.
08:41:08.223 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:41:08.864 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":268,"method":"get_clean_summary","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Q ueue: 2)
08:41:18.874 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:41:19.661 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":269,"method":"get_status","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 3 )
08:41:19.720 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":270,"method":"get_consumable","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queu e: 4)
08:41:19.732 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CONSUMABLES_GET, result: null, fullresponse: {"error":"No Response"}
08:41:19.732 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "No Response"
08:41:29.741 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Communication error for Mi IO device at 10.0.0.91: Receive timed out
08:41:29.742 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - No response from device 034D720F at 10.0.0.91 for command {"id":267,"method":"get_dnd_timer","params":[]}.
08:41:30.404 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: DND_GET, result: null, fullresponse: {"error":"No Response"}
08:41:30.404 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Error received: "No Response"
08:41:31.590 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CLEAN_SUMMARY_GET, result: [320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505 800800,1505714400]], fullresponse: {"result":[320301,4912707500,218,[1506232800,1506146400,1506060000,1505973600,1505887200,1505800800,1505714400]],"id":268}
08:41:32.277 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: GET_STATUS, result: [{"msg_ver":5,"msg_seq":83,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_c ode":0,"map_present":0,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}], fullresponse: {"result":[{"msg_ver":5,"msg_seq":83,"state":8,"battery":100,"clean_time":11,"clean_area":0,"error_code":0,"map_present":0, "in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":269}
08:41:32.566 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: CONSUMABLES_GET, result: [{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":3203 01,"sensor_dirty_time":64809}], fullresponse: {"result":[{"main_brush_work_time":320301,"side_brush_work_time":320301,"filter_work_time":320301,"sensor_dirty_time":64809}],"id":270}
08:41:37.908 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Skipping periodic update for 'miio:vacuum:03D87B3E'. Thing Status
08:41:37.909 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":64,"method":"miIO.info","params":[]} -> 10.0.0.92 (Device: 03D87B3E token: 627xxxHIDDENxxxx74F Queue: 1)
08:41:38.132 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 03D87B3E type: MIIO_INFO, result: {"hw_ver":"Linux","fw_ver":"3.3.9_003077","ap":{"ssid":"HIDDEN-SSID","bssid":"F2:9F:C2:7A:2C :0E","rssi":-64},"netif":{"localIp":"10.0.0.92","mask":"255.255.255.0","gw":"10.0.0.1"},"model":"rockrobo.vacuum.v1","mac":"34:CE:00:E8:28:BC","token":"627xxxHIDDENxxxx74F","life":19179}, fullrespo nse: {"partner_id":"","id":64,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003077","ap":{"ssid":"HIDDEN-SSID","bssid":"F2:9F:C2:7A:2C:0E","rssi":-64},"netif":{"localIp":"10.0.0.92","mask":" 255.255.255.0","gw":"10.0.0.1"},"model":"rockrobo.vacuum.v1","mac":"34:CE:00:E8:28:BC","token":"627xxxHIDDENxxxx74F","life":19179}}
08:41:49.736 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Skipping periodic update for 'miio:generic:034D720F'. Thing Status
08:41:49.736 [DEBUG] [rnal.transport.MiIoAsyncCommunication] - Command added to Queue {"id":271,"method":"miIO.info","params":[]} -> 10.0.0.91 (Device: 034D720F token: 333xxxHIDDENxxxxD42 Queue: 1)
08:41:51.850 [DEBUG] [ding.miio.handler.MiIoAbstractHandler] - Received response for 034D720F type: MIIO_INFO, result: {"hw_ver":"Linux","fw_ver":"3.3.9_003077","ap":{"ssid":"HIDDEN-SSID","bssid":"F2:9F:C2:7A:2C :0E","rssi":-62},"netif":{"localIp":"10.0.0.91","mask":"255.255.255.0","gw":"10.0.0.1"},"model":"rockrobo.vacuum.v1","mac":"28:6C:07:F7:72:A0","token":"333xxxHIDDENxxxxD42","life":17355}, fullrespo nse: {"partner_id":"","id":271,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003077","ap":{"ssid":"HIDDEN-SSID","bssid":"F2:9F:C2:7A:2C:0E","rssi":-62},"netif":{"localIp":"10.0.0.91","mask": "255.255.255.0","gw":"10.0.0.1"},"model":"rockrobo.vacuum.v1","mac":"28:6C:07:F7:72:A0","token":"333xxxHIDDENxxxxD42","life":17355}}
08:42:21.295 [DEBUG] [inding.miio.handler.MiIoVacuumHandler] - Skipping periodic update for 'miio:generic:034D720F'. Thing Status
or other options.
