Hey there,
today I received my vacuum robot. It’s a “Xiaomi Vacuum Cleaner G1 Mijia Robot” (aliexpress)
The binding adds it as a “unsupported device”, the network-channels are working. actions are NOT working.
if I manually add a vacuum robot none of the channels are working.
so: any chance to get support for that device?
Info for mijia.vacuum.v2
Properties: power -> 5, aqi -> 6, battery -> 7, usb_state -> 8, time_state -> 9, night_state -> 10, night_beg_time -> 11, night_end_time -> 12, pm25 -> 13, co2e -> 14, tvoc -> 15, humidity -> 16, temperature -> 17, co2 -> 18, mode -> 19, limit_hum -> 20, trans_level -> 21, led_b -> 22, buzzer -> 23, depth -> 24, dry -> 25, use_time -> 26, speed -> 27, temp_dec -> 28, child_lock -> 29, bright -> 30, led -> 31, act_det -> 32, f1_hour -> 33, filter1_life -> 34, average_aqi -> 35, f1_hour_used -> 36, motor1_speed -> 37, favorite_level -> 38, purify_volume -> 39, volume -> 40, motor2_speed -> 41, ptc_on -> 42, ptc_level -> 43, ptc_status -> 44, screen_direction -> 45, display -> 46, sound -> 47, control_speed -> 48, favourite_speed -> 49, temperature_outside -> 50, filter_intermediate -> 51, filter_inter_day -> 52, filter_efficient -> 53, filter_effi_day -> 54, filter_rate -> 55, filter_day -> 56, angle_enable -> 57, angle -> 58, poweroff_time -> 59, speed_level -> 60, natural_level -> 61, ac_power -> 62, bat_charge -> 63, roll -> 64, roll_angle -> 65, timer_off -> 66, beep_sound -> 67, light -> 68, doorbell_volume -> 69, gateway_volume -> 70, alarming_volume -> 71, doorbell_push -> 72, motor -> 73, drytime -> 74, airer_location -> 75, disinfect -> 76, distime -> 77, ambstatus -> 78, ambvalue -> 79, dvalue -> 80, eyecare -> 81, bl -> 82, cct -> 83, snm -> 84, dv -> 85, pow -> 86, sw -> 87, ms -> 88, ac -> 89, mb -> 90, cid -> 91, get_switch_en -> 92, flm -> 93, scene_num -> 94, wifi_led -> 95, on -> 96, usb_on -> 97, power_consume_rate -> 98, power_price -> 99, current -> 100, run_state -> 101, err_state -> 102, battery_life -> 103, box_type -> 104, mop_type -> 105, s_time -> 106, s_area -> 107, suction_grade -> 108, water_grade -> 109, remember_map -> 110, has_map -> 111, is_mop -> 112, has_newmap -> 113, switch1 -> 114, switchname1 -> 115, switch2 -> 116, switchname2 -> 117, switch3 -> 118, switchname3 -> 119, run_status -> 120, rinse -> 121, tds_in -> 122, tds_out -> 123, f1_totalflow -> 124, f1_totaltime -> 125, f1_usedflow -> 126, f1_usedtime -> 127, f2_totalflow -> 128, f2_totaltime -> 129, f2_usedflow -> 130, f2_usedtime -> 131, f3_totalflow -> 132, f3_totaltime -> 133, f3_usedflow -> 134, f3_usedtime -> 135, seat_temp -> 136, status_seatheat -> 137, water_temp_t -> 138, fan_temp -> 139, status_led -> 140, delayoff -> 141, ct -> 142, color_mode -> 143, toggle -> 144, rgb -> 145, name -> 146, bh_mode -> 147, nl_br -> 148, bg_bright -> 149, bg_power -> 150, bg_rgb -> 151, bg_ct -> 152, bg_lmode -> 153, target_temperature -> 154, brightness -> 155, relative_humidity -> 156, theqmostat -> 157,
{“life”:11522,“uid”:1632462069,“model”:“mijia.vacuum.v2”,“ipflag”:1,“fw_ver”:“2.0.8”,“mcu_fw_ver”:“6138”,“miio_ver”:“0.0.8”,“hw_ver”:“esp32”,“mmfree”:64416,“wifi_fw_ver”:“cef6c09-dirty”,“netif”:{“localIp”:“192.168.178.29”,“mask”:“255.255.255.0”,“gw”:“192.168.178.1”}}
{“id”:4,“method”:“miIO.info”,“params”:[]} -> {“id”:4,“result”:{“life”:11522,“uid”:1632462069,“model”:“mijia.vacuum.v2”,“ipflag”:1,“fw_ver”:“2.0.8”,“mcu_fw_ver”:“6138”,“miio_ver”:“0.0.8”,“hw_ver”:“esp32”,“mmfree”:64416,“wifi_fw_ver”:“cef6c09-dirty”,“netif”:{“localIp”:“192.168.178.29”,“mask”:“255.255.255.0”,“gw”:“192.168.178.1”}},“exe_time”:40}
{“id”:5,“method”:“get_prop”,“params”:[“power”]} -> {“id”:5,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:180}
{“id”:6,“method”:“get_prop”,“params”:[“aqi”]} -> {“id”:6,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:7,“method”:“get_prop”,“params”:[“battery”]} -> {“id”:7,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:8,“method”:“get_prop”,“params”:[“usb_state”]} -> {“id”:8,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:9,“method”:“get_prop”,“params”:[“time_state”]} -> {“id”:9,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:140}
{“id”:10,“method”:“get_prop”,“params”:[“night_state”]} -> {“id”:10,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:11,“method”:“get_prop”,“params”:[“night_beg_time”]} -> {“id”:11,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:12,“method”:“get_prop”,“params”:[“night_end_time”]} -> {“id”:12,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:13,“method”:“get_prop”,“params”:[“pm25”]} -> {“id”:13,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:240}
{“id”:14,“method”:“get_prop”,“params”:[“co2e”]} -> {“id”:14,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:15,“method”:“get_prop”,“params”:[“tvoc”]} -> {“id”:15,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:16,“method”:“get_prop”,“params”:[“humidity”]} -> {“id”:16,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:17,“method”:“get_prop”,“params”:[“temperature”]} -> {“id”:17,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:18,“method”:“get_prop”,“params”:[“co2”]} -> {“id”:18,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:19,“method”:“get_prop”,“params”:[“mode”]} -> {“id”:19,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:20,“method”:“get_prop”,“params”:[“limit_hum”]} -> {“id”:20,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:21,“method”:“get_prop”,“params”:[“trans_level”]} -> {“id”:21,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:22,“method”:“get_prop”,“params”:[“led_b”]} -> {“id”:22,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:23,“method”:“get_prop”,“params”:[“buzzer”]} -> {“id”:23,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:24,“method”:“get_prop”,“params”:[“depth”]} -> {“id”:24,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:25,“method”:“get_prop”,“params”:[“dry”]} -> {“id”:25,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:26,“method”:“get_prop”,“params”:[“use_time”]} -> {“id”:26,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:27,“method”:“get_prop”,“params”:[“speed”]} -> {“id”:27,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:28,“method”:“get_prop”,“params”:[“temp_dec”]} -> {“id”:28,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:29,“method”:“get_prop”,“params”:[“child_lock”]} -> {“id”:29,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:30,“method”:“get_prop”,“params”:[“bright”]} -> {“id”:30,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:190}
{“id”:31,“method”:“get_prop”,“params”:[“led”]} -> {“id”:31,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:32,“method”:“get_prop”,“params”:[“act_det”]} -> {“id”:32,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:33,“method”:“get_prop”,“params”:[“f1_hour”]} -> {“id”:33,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:80}
{“id”:34,“method”:“get_prop”,“params”:[“filter1_life”]} -> {“id”:34,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:35,“method”:“get_prop”,“params”:[“average_aqi”]} -> {“id”:35,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:36,“method”:“get_prop”,“params”:[“f1_hour_used”]} -> {“id”:36,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:37,“method”:“get_prop”,“params”:[“motor1_speed”]} -> {“id”:37,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:38,“method”:“get_prop”,“params”:[“favorite_level”]} -> {“id”:38,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:200}
{“id”:39,“method”:“get_prop”,“params”:[“purify_volume”]} -> {“id”:39,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:40,“method”:“get_prop”,“params”:[“volume”]} -> {“id”:40,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:41,“method”:“get_prop”,“params”:[“motor2_speed”]} -> {“id”:41,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:42,“method”:“get_prop”,“params”:[“ptc_on”]} -> {“id”:42,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:43,“method”:“get_prop”,“params”:[“ptc_level”]} -> {“id”:43,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:44,“method”:“get_prop”,“params”:[“ptc_status”]} -> {“id”:44,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:130}
{“id”:45,“method”:“get_prop”,“params”:[“screen_direction”]} -> {“id”:45,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:46,“method”:“get_prop”,“params”:[“display”]} -> {“id”:46,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:47,“method”:“get_prop”,“params”:[“sound”]} -> {“id”:47,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:48,“method”:“get_prop”,“params”:[“control_speed”]} -> {“id”:48,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:49,“method”:“get_prop”,“params”:[“favourite_speed”]} -> {“id”:49,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:50,“method”:“get_prop”,“params”:[“temperature_outside”]} -> {“id”:50,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:230}
{“id”:51,“method”:“get_prop”,“params”:[“filter_intermediate”]} -> {“id”:51,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:52,“method”:“get_prop”,“params”:[“filter_inter_day”]} -> {“id”:52,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:53,“method”:“get_prop”,“params”:[“filter_efficient”]} -> {“id”:53,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:60}
{“id”:54,“method”:“get_prop”,“params”:[“filter_effi_day”]} -> {“id”:54,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:55,“method”:“get_prop”,“params”:[“filter_rate”]} -> {“id”:55,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:80}
{“id”:56,“method”:“get_prop”,“params”:[“filter_day”]} -> {“id”:56,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:57,“method”:“get_prop”,“params”:[“angle_enable”]} -> {“id”:57,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:58,“method”:“get_prop”,“params”:[“angle”]} -> {“id”:58,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:59,“method”:“get_prop”,“params”:[“poweroff_time”]} -> {“id”:59,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:230}
{“id”:60,“method”:“get_prop”,“params”:[“speed_level”]} -> {“id”:60,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:61,“method”:“get_prop”,“params”:[“natural_level”]} -> {“id”:61,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:62,“method”:“get_prop”,“params”:[“ac_power”]} -> {“id”:62,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:63,“method”:“get_prop”,“params”:[“bat_charge”]} -> {“id”:63,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:64,“method”:“get_prop”,“params”:[“roll”]} -> {“id”:64,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:65,“method”:“get_prop”,“params”:[“roll_angle”]} -> {“id”:65,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:66,“method”:“get_prop”,“params”:[“timer_off”]} -> {“id”:66,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:67,“method”:“get_prop”,“params”:[“beep_sound”]} -> {“id”:67,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:68,“method”:“get_prop”,“params”:[“light”]} -> {“id”:68,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:69,“method”:“get_prop”,“params”:[“doorbell_volume”]} -> {“id”:69,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:230}
{“id”:70,“method”:“get_prop”,“params”:[“gateway_volume”]} -> {“id”:70,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:71,“method”:“get_prop”,“params”:[“alarming_volume”]} -> {“id”:71,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:180}
{“id”:72,“method”:“get_prop”,“params”:[“doorbell_push”]} -> {“id”:72,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:73,“method”:“get_prop”,“params”:[“motor”]} -> {“id”:73,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:74,“method”:“get_prop”,“params”:[“drytime”]} -> {“id”:74,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:75,“method”:“get_prop”,“params”:[“airer_location”]} -> {“id”:75,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:76,“method”:“get_prop”,“params”:[“disinfect”]} -> {“id”:76,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:77,“method”:“get_prop”,“params”:[“distime”]} -> {“id”:77,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:78,“method”:“get_prop”,“params”:[“ambstatus”]} -> {“id”:78,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:130}
{“id”:79,“method”:“get_prop”,“params”:[“ambvalue”]} -> {“id”:79,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:80,“method”:“get_prop”,“params”:[“dvalue”]} -> {“id”:80,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:81,“method”:“get_prop”,“params”:[“eyecare”]} -> {“id”:81,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:82,“method”:“get_prop”,“params”:[“bl”]} -> {“id”:82,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:83,“method”:“get_prop”,“params”:[“cct”]} -> {“id”:83,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:84,“method”:“get_prop”,“params”:[“snm”]} -> {“id”:84,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:85,“method”:“get_prop”,“params”:[“dv”]} -> {“id”:85,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:86,“method”:“get_prop”,“params”:[“pow”]} -> {“id”:86,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:87,“method”:“get_prop”,“params”:[“sw”]} -> {“id”:87,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:88,“method”:“get_prop”,“params”:[“ms”]} -> {“id”:88,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:89,“method”:“get_prop”,“params”:[“ac”]} -> {“id”:89,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:90,“method”:“get_prop”,“params”:[“mb”]} -> {“id”:90,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:60}
{“id”:91,“method”:“get_prop”,“params”:[“cid”]} -> {“id”:91,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:92,“method”:“get_prop”,“params”:[“get_switch_en”]} -> {“id”:92,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:93,“method”:“get_prop”,“params”:[“flm”]} -> {“id”:93,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:94,“method”:“get_prop”,“params”:[“scene_num”]} -> {“id”:94,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:180}
{“id”:95,“method”:“get_prop”,“params”:[“wifi_led”]} -> {“id”:95,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:96,“method”:“get_prop”,“params”:[“on”]} -> {“id”:96,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:97,“method”:“get_prop”,“params”:[“usb_on”]} -> {“id”:97,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:98,“method”:“get_prop”,“params”:[“power_consume_rate”]} -> {“id”:98,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:99,“method”:“get_prop”,“params”:[“power_price”]} -> {“id”:99,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:100,“method”:“get_prop”,“params”:[“current”]} -> {“id”:100,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:101,“method”:“get_prop”,“params”:[“run_state”]} -> {“id”:101,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:102,“method”:“get_prop”,“params”:[“err_state”]} -> {“id”:102,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:103,“method”:“get_prop”,“params”:[“battery_life”]} -> {“id”:103,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:104,“method”:“get_prop”,“params”:[“box_type”]} -> {“id”:104,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:230}
{“id”:105,“method”:“get_prop”,“params”:[“mop_type”]} -> {“id”:105,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:106,“method”:“get_prop”,“params”:[“s_time”]} -> {“id”:106,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:107,“method”:“get_prop”,“params”:[“s_area”]} -> {“id”:107,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:108,“method”:“get_prop”,“params”:[“suction_grade”]} -> {“id”:108,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:109,“method”:“get_prop”,“params”:[“water_grade”]} -> {“id”:109,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:240}
{“id”:110,“method”:“get_prop”,“params”:[“remember_map”]} -> {“id”:110,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:111,“method”:“get_prop”,“params”:[“has_map”]} -> {“id”:111,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:130}
{“id”:112,“method”:“get_prop”,“params”:[“is_mop”]} -> {“id”:112,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:130}
{“id”:113,“method”:“get_prop”,“params”:[“has_newmap”]} -> {“id”:113,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:130}
{“id”:114,“method”:“get_prop”,“params”:[“switch1”]} -> {“id”:114,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:115,“method”:“get_prop”,“params”:[“switchname1”]} -> {“id”:115,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:116,“method”:“get_prop”,“params”:[“switch2”]} -> {“id”:116,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:117,“method”:“get_prop”,“params”:[“switchname2”]} -> {“id”:117,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:118,“method”:“get_prop”,“params”:[“switch3”]} -> {“id”:118,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:119,“method”:“get_prop”,“params”:[“switchname3”]} -> {“id”:119,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:120,“method”:“get_prop”,“params”:[“run_status”]} -> {“id”:120,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:130}
{“id”:121,“method”:“get_prop”,“params”:[“rinse”]} -> {“id”:121,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:122,“method”:“get_prop”,“params”:[“tds_in”]} -> {“id”:122,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:123,“method”:“get_prop”,“params”:[“tds_out”]} -> {“id”:123,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:180}
{“id”:124,“method”:“get_prop”,“params”:[“f1_totalflow”]} -> {“id”:124,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:250}
{“id”:125,“method”:“get_prop”,“params”:[“f1_totaltime”]} -> {“id”:125,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:126,“method”:“get_prop”,“params”:[“f1_usedflow”]} -> {“id”:126,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:127,“method”:“get_prop”,“params”:[“f1_usedtime”]} -> {“id”:127,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:180}
{“id”:128,“method”:“get_prop”,“params”:[“f2_totalflow”]} -> {“id”:128,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:129,“method”:“get_prop”,“params”:[“f2_totaltime”]} -> {“id”:129,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:130,“method”:“get_prop”,“params”:[“f2_usedflow”]} -> {“id”:130,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:131,“method”:“get_prop”,“params”:[“f2_usedtime”]} -> {“id”:131,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
{“id”:132,“method”:“get_prop”,“params”:[“f3_totalflow”]} -> {“id”:132,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:80}
{“id”:133,“method”:“get_prop”,“params”:[“f3_totaltime”]} -> {“id”:133,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:134,“method”:“get_prop”,“params”:[“f3_usedflow”]} -> {“id”:134,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:60}
{“id”:135,“method”:“get_prop”,“params”:[“f3_usedtime”]} -> {“id”:135,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:210}
{“id”:136,“method”:“get_prop”,“params”:[“seat_temp”]} -> {“id”:136,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:137,“method”:“get_prop”,“params”:[“status_seatheat”]} -> {“id”:137,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:138,“method”:“get_prop”,“params”:[“water_temp_t”]} -> {“id”:138,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:190}
{“id”:139,“method”:“get_prop”,“params”:[“fan_temp”]} -> {“id”:139,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:140,“method”:“get_prop”,“params”:[“status_led”]} -> {“id”:140,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:141,“method”:“get_prop”,“params”:[“delayoff”]} -> {“id”:141,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:120}
{“id”:142,“method”:“get_prop”,“params”:[“ct”]} -> {“id”:142,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:143,“method”:“get_prop”,“params”:[“color_mode”]} -> {“id”:143,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:90}
{“id”:144,“method”:“get_prop”,“params”:[“toggle”]} -> {“id”:144,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:210}
{“id”:145,“method”:“get_prop”,“params”:[“rgb”]} -> {“id”:145,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:220}
{“id”:146,“method”:“get_prop”,“params”:[“name”]} -> {“id”:146,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:140}
{“id”:147,“method”:“get_prop”,“params”:[“bh_mode”]} -> {“id”:147,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:148,“method”:“get_prop”,“params”:[“nl_br”]} -> {“id”:148,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:140}
{“id”:149,“method”:“get_prop”,“params”:[“bg_bright”]} -> {“id”:149,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:170}
{“id”:150,“method”:“get_prop”,“params”:[“bg_power”]} -> {“id”:150,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:151,“method”:“get_prop”,“params”:[“bg_rgb”]} -> {“id”:151,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:150}
{“id”:152,“method”:“get_prop”,“params”:[“bg_ct”]} -> {“id”:152,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:153,“method”:“get_prop”,“params”:[“bg_lmode”]} -> {“id”:153,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:110}
{“id”:154,“method”:“get_prop”,“params”:[“target_temperature”]} -> {“id”:154,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:100}
{“id”:155,“method”:“get_prop”,“params”:[“brightness”]} -> {“id”:155,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:160}
{“id”:156,“method”:“get_prop”,“params”:[“relative_humidity”]} -> {“id”:156,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:250}
{“id”:157,“method”:“get_prop”,“params”:[“theqmostat”]} -> {“id”:157,“error”:{“code”:-9999,“message”:“undefined command”},“exe_time”:70}
Responsive properties
Device Info: {“life”:11522,“uid”:1632462069,“model”:“mijia.vacuum.v2”,“ipflag”:1,“fw_ver”:“2.0.8”,“mcu_fw_ver”:“6138”,“miio_ver”:“0.0.8”,“hw_ver”:“esp32”,“mmfree”:64416,“wifi_fw_ver”:“cef6c09-dirty”,“netif”:{“localIp”:“192.168.178.29”,“mask”:“255.255.255.0”,“gw”:“192.168.178.1”}}No supported channels found.
