i have OH2 2.2 under docker running - and a MiHomeGateway2 implemented via PaperUI and the MiHomeBinding.
Work good since month - have connected 2 Temp Sensors and one Water Leak Sensor.
Since a few days the waterleak sensor doesnt appaer in OH anymore - I can see it as online under MiHomeApp but not under OH.
I have removed it from MiHomeApp and connect it new but it also doesnt appear in inbox - tried to add it manualy in OH but i cant find the correct thing for it if i try manual add it
What to do here ?
PS.: It worked now months and was added via paper ui - now its gone and cant be added anymore - only my self created item is still there
yep in MiHome app all is working good - just in OH it wont appear - also as i said i cant add it manualy by ID because the Water Leak Sensor are not listed in the menu of paper UI
hi @black0r1337, can you verify which OH and binding version you use? The water leak sensor shows up in PaperUI for me. I use 2.4.0.M6
@psyciknz, if your sensor still is alive but doesn’t report values then check your network config. for automatic updates your OH instance has to be able to receive multicast messages.
