i finally found the openhab node for my unrecognized device and got permission to upload the xml file to the cd jackson website. however looking at my node i see that it does not have any information on manifactur or device id. i did find an xml file for the product here. https://products.z-wavealliance.org/products/2905 and it seemed similar and had more information. however i tried to upload it and it said error parsing xml. so my question is do i have to upload the node generated from openhab with out editing or should i edit it and how much. should i try to make the product xml work. what do you think the best option is.
You can’t upload that file, you need to use the xml file from your /zwave
folder.
If you have any problems, please post the xml file.
i tried upoading the raw unedited node file from open hab and it still said error parsing xml. here is the node file from openhab
<?xml version="1.0"?>-
0xd3a42f2e
2
4
0x7fffffff
0x7fffffff
0x7fffffff
false
true
true
false
true
40000
1000
COMMAND_CLASS_ZWAVEPLUS_INFO
COMMAND_CLASS_TRANSPORT_SERVICE
COMMAND_CLASS_SECURITY
COMMAND_CLASS_SECURITY_2
0
BASIC_TYPE_ROUTING_SLAVE
GENERIC_TYPE_ENTRY_CONTROL
SPECIFIC_TYPE_SECURE_KEYPAD_DOOR_LOCK
0
COMMAND_CLASS_NO_OPERATION
-<COMMAND__CLASS__NO__OPERATION>
1
1
false
1
</COMMAND__CLASS__NO__OPERATION>
COMMAND_CLASS_BASIC
-<COMMAND__CLASS__BASIC>
0
1
false
0
true
</COMMAND__CLASS__BASIC>
-<COMMAND__CLASS__ZWAVEPLUS__INFO>
0
1
false
0
1
ROLE_TYPE_SLAVE_SLEEPING_LISTENING
NODE_TYPE_ZWAVEPLUS_NODE
true
</COMMAND__CLASS__ZWAVEPLUS__INFO>
-<COMMAND__CLASS__SECURITY>
0
1
false
0
</COMMAND__CLASS__SECURITY>
2019-01-17 01:17:44.680 UTC
Either you’ve forgotten to use code fences, or that’s not xml.
