I have an issue with an XPATH transformation that I can’t solve. The xpath transformation doesn’t match any element while I’ve tested with an online validator (and applied my own common sense). Probably something specific to the Openhab path transformation that I’m missing.
Input xml:
<CurrentURIMetaData>
<?xml version="1.0" encoding="UTF-8"?>
<DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:song="www.wiimu.com/song/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/">
<upnp:class>object.item.audioItem.musicTrack</upnp:class>
<item id="0">
<song:subid>Continuum</song:subid>
<song:description>un_known</song:description>
<song:skiplimit>0</song:skiplimit>
<song:id>0</song:id>
<song:like>0</song:like>
<song:singerid>0</song:singerid>
<song:albumid>0</song:albumid>
<res protocolInfo="http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;" duration="00:03:21.000">spotify:track:5imShWWzwqfAJ9gXFpGAQh</res>
<dc:title>Waiting On the World to Change</dc:title>
<dc:creator>John Mayer</dc:creator>
<upnp:artist>John Mayer</upnp:artist>
<upnp:album>Continuum</upnp:album>
<upnp:albumArtURI>http://i.scdn.co/image/ab67616d0000b2737af5fdc5ef048a68db62b85f</upnp:albumArtURI>
</item>
</DIDL-Lite>
</CurrentURIMetaData>
The following rule triggers the xpath transformation:
rule "begin your execution"
Item media_upnp_mediainfoxml changed
val track_name = transform("XPATH", "/*[name()='CurrentURIMetaData']/*[name()='DIDL-Lite' and namespace-uri()='urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/']/*[name()='item' and namespace-uri()='urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/']/*[name()='dc:title' and namespace-uri()='http://purl.org/dc/elements/1.1/']/text()",
media_upnp_mediainfoxml.state.toString )
media_upnp_trackname.postUpdate(track_name)
Log output:
Formatting of the output is terrible, basically the log states that pre-updae value is same as post-update value from which I conclude that the xpath didn’t match
<item id="0">
</item>
</DIDL-Lite>
and the rule:
"/[name()='CurrentURIMetaData']/[name()='DIDL-Lite' and namespace-uri()='urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/']/[name()='item' and namespace-uri()='urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/']/[name()='dc:title' and namespace-uri()='http://purl.org/dc/elements/1.1/']/text()",
media_upnp_mediainfoxml.state.toString)
The xpath expression doesn’t look correct to me, but I maybe wrong here.
Sorry, kind of new to the community and didn’t go over posting guidelines. I was looking for the code fence option in the editor but couldn’t find it. Found them now and fixed my first post. Increases readability a lot Thank for reminding me.
Given the XML from the first message, the following xpath expressions are tested using https://www.freeformatter.com/xpath-tester.html (the one mentioned on the xpath transformation page):
The initial one that just follows the document structure results in 'Text=‘Waiting On the World to Change’
A second one that includes the various namespaces used, also results in 'Text=‘Waiting On the World to Change’
/text()
What do you believe is wrong with the shown xpath? I’ve been going at this for a while now and can’t figure it out.
