Hi there
I would like to know what is wrong with my configuration. Astro is working fine.
Weather I got only temperature, humidity and pressure
Here is my things file:
yahooweather:weather:ossy [ location=â5*****â ]
astro:sun:home [ geolocation=".,.***",interval=60 ]
astro:moon:home [ geolocation=".****,.***",interval=60 ]
and here my items file:
/Astro/
DateTime Astro_Sunrise_Time âSunrise [%1$tH:%1$tM]â (gAstro) { channel=âastro:sun:home:rise#startâ }
DateTime Astro_Sunset_Time âSunset [%1$tR]â (gAstro) { channel=âastro:sun:home:set#startâ }
Number Astro_Azimuth âAzimuthâ (gAstro) { channel=âastro:sun:home:position#azimuthâ }
Number Astro_Elevation âElevationâ (gAstro) { channel=âastro:sun:home:position#elevationâ }
String Astro_MoonPhase âMoonPhase [MAP(moon.map):%s]â (gAstro) { channel=âastro:moon:home:phase#nameâ }
String Astro_Sign âSigne [MAP(zodiac.map):%s]â (gAstro) { channel=âastro:sun:home:zodiac#signâ }
String Astro_Season âSaison [MAP(season.map):%s]â (gAstro) { channel=âastro:sun:home:season#nameâ }
/*Group gWeather */
Number Weather_Temperature âTemperature exterieure [%.1f °C]â (gWeather) { channel=âyahooweather:weather:ossy:temperatureâ }
Number Weather_Humidity âHumiditĂ© exterieure [%.1f %%]â (gWeather) { channel=âyahooweather:weather:ossy:humidityâ }
Number Weather_Pressure âPressure exterieure [%.1f hPa]â <weather_barometric_pressure> (gWeather) { channel=âyahooweather:weather:ossy:pressureâ }
Number Weather_Rain âRain [%.2f mm/h]â (gWeather) { channel=âyahooweather:weather:ossy:rainâ }
Number Weather_Precip_Total âPrecip total [%d mm]â (gWeather) { channel=âyahooweather:weather:ossy:totalâ }
Number Weather_Snow âSnow [%.2f mm/h]â (gWeather) { channel=âyahooweather:weather:ossy:snowâ }
Number Weather_Wind_Speed âWind speed [%.2f km/h]â (gWeather) { channel=âyahooweather:weather:ossy:speedâ }
String Weather_Wind_Direction âWind direction [%s]â (gWeather) { channel=âyahooweather:weather:ossy:directionâ }
Number Weather_UV_Index âUV Index [%.1f]â (gWeather) { channel=âyahooweather:weather:ossy:uvIndexâ }
DateTime Weather_LastUpdate âDern. MAJ [%1$ta %1$tR]â (gWeather) { channel=âyahooweather:weather:ossy:lastUpdateâ }
String Weather_Temp_MinMax âTodays Min/Max [%s °C]â (gWeather) { channel=âyahooweather:weather:ossy:minMaxâ }
Number Weather_Clouds âClouds [%.0f %%]â (gWeather) { channel=âyahooweather:weather:ossy:percentâ }
Here is my second try and here only temperature is showing.
Number Weather_Temperature âTemperature exterieure [%.1f °C]â (gWeather) { channel=âyahooweather:weather:ossy:temperature#currentâ }
Number Weather_Humidity âHumiditĂ© exterieure [%.1f %%]â (gWeather) { channel=âyahooweather:weather:ossy:atmosphere#humidityâ }
Number Weather_Pressure âPressure exterieure [%.1f hPa]â <weather_barometric_pressure> (gWeather) { channel=âyahooweather:weather:ossy:atmosphere#pressureâ }
Number Weather_Rain âRain [%.2f mm/h]â (gWeather) { channel=âyahooweather:weather:ossy:precipitation#rainâ }
Number Weather_Precip_Total âPrecip total [%d mm]â (gWeather) { channel=âyahooweather:weather:ossy:precipitation#totalâ }
Number Weather_Snow âSnow [%.2f mm/h]â (gWeather) { channel=âyahooweather:weather:ossy:precipitation#snowâ }
Number Weather_Wind_Speed âWind speed [%.2f km/h]â (gWeather) { channel=âyahooweather:weather:ossy:wind#speedâ }
String Weather_Wind_Direction âWind direction [%s]â (gWeather) { channel=âyahooweather:weather:ossy:wind#directionâ }
Number Weather_UV_Index âUV Index [%.1f]â (gWeather) { channel=âyahooweather:weather:ossy:atmosphere#uvIndexâ }
DateTime Weather_LastUpdate âDern. MAJ [%1$ta %1$tR]â (gWeather) { channel=âyahooweather:weather:ossy:condition#lastUpdateâ }
String Weather_Temp_MinMax âTodays Min/Max [%s °C]â (gWeather) { channel=âyahooweather:weather:ossy:temperature#minMaxâ }
Number Weather_Clouds âClouds [%.0f %%]â (gWeather) { channel=âyahooweather:weather:ossy:clouds#percentâ }
Thanks in advance for your help.
Best regards
Ossy
