Im on openhab2-offline and installed the Yahoo Weather Binding under addons.
Whenever I try to add the yahoo weather thing though it shows:
and the log says:
2017-01-14 12:40:59.101 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while registering the handler for thing 'yahooweather:weather:775155c1' using factory 'org.eclipse.smarthome.binding.yahooweather.internal.YahooWeatherHandlerFactory@1c5a0cc': java.lang.NoSuchMethodError: com.google.common.cache.CacheBuilder.maximumSize(I)Lcom/google/common/cache/CacheBuilder;
java.util.concurrent.ExecutionException: java.lang.NoSuchMethodError: com.google.common.cache.CacheBuilder.maximumSize(I)Lcom/google/common/cache/CacheBuilder;
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_111]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_111]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:978)
at org.eclipse.smarthome.core.thing.internal.ThingManager.thingAdded(ThingManager.java:459)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:218)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:137)
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1)
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:123)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:51)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:70)
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:74)
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.add(AbstractManagedProvider.java:61)
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.add(AbstractRegistry.java:177)
at org.eclipse.smarthome.io.rest.core.thing.ThingResource.create(ThingResource.java:193)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_111]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_111]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_111]
at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_111]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)[157:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154)[158:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228)[155:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76)[10:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[79:org.eclipse.jetty.security:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.Server.handle(Server.java:499)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[72:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_111]
Caused by: java.lang.NoSuchMethodError: com.google.common.cache.CacheBuilder.maximumSize(I)Lcom/google/common/cache/CacheBuilder;
at org.eclipse.smarthome.binding.yahooweather.handler.YahooWeatherHandler.<init>(YahooWeatherHandler.java:177)
at org.eclipse.smarthome.binding.yahooweather.internal.YahooWeatherHandlerFactory.createHandler(YahooWeatherHandlerFactory.java:42)
at org.eclipse.smarthome.core.thing.binding.BaseThingHandlerFactory.registerHandler(BaseThingHandlerFactory.java:98)
at org.eclipse.smarthome.core.thing.internal.ThingManager.doRegisterHandler(ThingManager.java:593)
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerHandler(ThingManager.java:572)
at org.eclipse.smarthome.core.thing.internal.ThingManager.access$29(ThingManager.java:568)
at org.eclipse.smarthome.core.thing.internal.ThingManager$17.call(ThingManager.java:981)
at org.eclipse.smarthome.core.thing.internal.ThingManager$17.call(ThingManager.java:1)
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_111]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_111]
... 1 more
Im guessing I have a newer or older version of com.google.common.cache.CacheBuilder?
Anyone have clue on how to fix this?
