openhab> feature:install openhab-transport-serial
Error executing command: Error restarting bundles:
Could not resolve module: org.openhab.binding.zwave [213]
Another singleton bundle selected: osgi.identity; type=“osgi.bundle”; version:Version=“2.4.0.201807161952”; osgi.identity=“org.openhab.binding.zwave”; singleton:=“true”
This usually means you have two versions of the same binding installed. Don’t install the binding through PaperUI and don’t make an entry in addons.cfg, if you are dropping it into addons.
does this log mean that its still not seeing it in the DB?..
2018-07-18 22:16:53.520 [ERROR] [serialmessage.SetSucNodeMessageClass] - NODE 0: SetSucNodeID command failed.
2018-07-18 22:16:53.523 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 0129:0066:0000::14.32
Yes, it looks like there’s a bit of a mixup with the update.
@mhilbush it seems you added 6600:0000 to a device - but possibly not the right one?
Ugh. Sorry.
No - it’s not… You entered 6600 - not 0066. I’m also not convinced that this is the right device based on the comment at the top which states it is ASSA ABLOY Yale Smart Door Lock Z-Wave Module?
i have a pic of the module if you would like me to post?
Yes, I sure did! Totally missed the 0066 versus 6600.
So at this point, I’m not sure which device to edit, or whether this is a new device that needs to be added to the DB.
@itezcouk Do you have a manual for the device, and can you post a link?
the device is a yale conexis lock (https://www.yale.co.uk/en/yale/couk/products/smart-living/smart-door-locks/conexis-l1-smart-door-lock/) with this z-wave module installed ASSA ABLOY RFHX-YZW10-00
@mhilbush I think the device you updated might be fine. I’m not 100% sure, but I get the impression that these modules report different codes depending on what lock they are in (I think I have the same module in my Yale lock). I’m therefore not a fan of a general “module” device, but prefer to have separate product entries.
Agreed.
There’s no maybe . You entered 6600, and it should be 0066.
I’m heading off to bed, but will do another update tomorrow evening if you can swap the IDs around (and thanks Mark).
thanks for your help all. have learned a lot over past day… snapshot version, console commands and logs. all a good learning curve
It might be fixed now.
@itezcouk Sorry for the screw up. Hopefully this will resolve the discovery issue.
no worries… do i just wait for the link to be updated here…
and then download the latest jar file to my addons folder?
Yes, exactly. It’s much easier compared to the first time.
Just make sure there’s only ever one zwave jar file in addons
. For example, when I download the binding using my Mac, the Mac thinks it knows better than me and wants to change the name of the file so as to not conflict with the one that’s there…
sure, do i then need to restart OH the service? ( i have the windows service setup with my install)
There’s no need, but you could shutdown OH, copy it, then restart to make sure it all goes cleanly. Or copy it in while OH is running, and the binding will restart itself. That directory is being monitored by OH.
I just want to say that I admire and appreciate your perseverance here. Unfortunately, you ended up facing one of the more challenging problems with OH as a new user and instead of complaining and ranting and giving up you have persisted. It’s greatly appreciated. I wish you luck!
Hi Mark,
When do you think you might be able to update the DB?
Thanks,
Darren
