Thanks for your work, works fine so far
I added the âreceivingâ commands, otherwise openhab would not be updated if something got changed on for example the remote control of the av.
Added Inputselection aswell.
Hi @BeanzBE,
first of all many many thanks for your work Last weekend i tested the last beta with openhab 3.0.1, but the addons isnt recognized by openhab. Itâs neither shown in the webfrontend nor with bundle:list.
Are there any news about this problem or can i support with any logfiles / further data?
Thank you very much
@martiniman Thanks for the feedback. As my things/Items were created via the UI, let me check it what it gives when creating them via files. @chris3 How did you created bridge/items? And it might be related to what @martiniman explained.
Anyway, for my project for work, I reached first milestone. Hopefully this should give me some room to pick this up again. The Pull Request for OH3 has also been paused for a while now.
First try should be to create a separate branch for audio sink and perhaps the problem with OH3
Hi @BeanzBE,
Yes i tested to create things as @martiniman explained, but i did not work for me.
As i already mentioned, my openhab instance did not discover the addon (v0.81). So itâs not possible for me to create Things or the Bridge Form the webfrontend.
With v0.79 itâs shown in the console with bundle:list, with 0.81 nothing is shown.
Is it right, that v0.81 has only a size of ~20kb and v0.79 ~40kb?
I can recommend to switch to OH3, iâm really happy with it
Yesterday i was trying to use the new channel âmclinkStatusâ to activate / deactive Musiccast, but it seems not to work correctly yet. If I set any value (âstandaloneâ, âserverâ or âclientâ), itâs reset to the current state from the device. Furthermore âstandaloneâ is represented by ââ or NULL.
Snippet from the OH3 console:
11:54:56.351 [INFO ] [openhab.event.ItemCommandEvent ] - Item âYamahaMusiccast20_StatusMusicCastâ received command server
11:54:56.354 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item âYamahaMusiccast20_StatusMusicCastâ predicted to become server
11:54:56.356 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âYamahaMusiccast20_StatusMusicCastâ changed from to server
11:54:56.368 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âYamahaMusiccast20_StatusMusicCastâ changed from server to
âŠ
âŠ
11:55:09.801 [INFO ] [openhab.event.ItemCommandEvent ] - Item âYamahaMusiccast20_StatusMusicCastâ received command standalone
11:55:09.803 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item âYamahaMusiccast20_StatusMusicCastâ predicted to become standalone
11:55:09.805 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âYamahaMusiccast20_StatusMusicCastâ changed from to standalone
11:55:09.818 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âYamahaMusiccast20_StatusMusicCastâ changed from standalone to
Hi Chris, yes, it is not fully functional.
The API is not really behaving as expected. I need to find a workaround for it.
If I do the same via the app, I get the same result back in OH. Thatâs why I need the workaround or Iâm missing something completely.
Hopefully soon.
I thought It maybe reloaded the addons folder on restart, but the binding will not showup under budnle:list or bundle:start, when I add things via .things file it says it has validation error as below
2021-05-14 09:44:16.562 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model âmusiccast.thingsâ, using it anyway:
Provide a thing type ID and a thing ID in this format:
Good morning,
I tried to switch from Yamahareceiver to musiccast binding yesterday, got it runing finally, it doesnt show up in the bindings list but with bundle:list you see that it is loaded. In the begining I made the mistake to copy it from github with Save as⊠in the context menu, there I received a 104KB file. After pressing download I received a file with 44KB and that worked after copying it to addons.
What I also did was renaming the bridge to yamahamusiccast:bridge:d1c39b2466 in the things file.
I also get the error message from the things file but the things show up at the configuration page as online.
But then my issues start, I am using a items file with 9 Musiccast devices which worked fine in OH2.5 with musiccast binding. So I adapted it to the new syntax, but most of the items donât work.
It starts with the power item, i can power on my device but not power of and when I check the visibility in my sitemap it thows lots of errors in the log.
Cannot retrieve visibility item Yamaha_LivingRoom_Power for widget org.openhab.core.model.sitemap.sitemap.Selection
The mute button works fine, also the preset DLNA, Radio, Net changes.
Iâve added volumecontrol and power control, now working on selectpreset I have my radiostations preset in all my musiccast units, WXAD10 streaming device. Just need to figure out wath to send to the string item, It do no list anything there.
I was just having a bad persitance hence switching from squeelite server to musiccast listed my squeezebox favorites. To the string just send the number in of your favorite to play 1 or 2 or 3 et.c Binding yet working as a charm for like 30 minutes now. I will report progress when Iâm more experienced.
What are using as frontend: sitemaps or the new UI?
In the last days I created a new fork of OH3 addons as my previous was messed up. There are a lot of enhancements regarding development. So Iâm kinda doubting to switch to OH3 for DEV and port it backwards to OH2.5.
Which also means for me to start working with OH3
