Hy guys,
since the Yamaha Receiver Binding did not report the current selected preset (in my case it’s 0 every time I change the input) yet, I’ve written a small rule to handle this.
Items file:
Number Yamaha_Preset "Preset [%d]" <video> { channel="yamahareceiver:zone:receiver:main:playback_channels#preset"}
Rules file:
rule "Yamaha Receiver - Get Tuner Preset"
Item Get_Yamaha_Preset changed
logInfo("Rules.YamahaReceiver.InputChange", "Set input settings for {}.", Yamaha_Input.state)
// Get current preset information
logDebug("Rules.YamahaReceiver.InputChange", "Get {} preset", Yamaha_Input.state)
val String urlString = "http://xxx.xxx.xxx.xxx:80/YamahaRemoteControl/ctrl"
val String contentType = "text/xml"
val String contentString = "<?xml version=\"1.0\" encoding=\"utf-8\"?><YAMAHA_AV cmd=\"GET\"><Tuner><Play_Info>GetParam</Play_Info></Tuner></YAMAHA_AV>"
val String result = sendHttpPostRequest(urlString, contentType, contentString)
// Extract current preset from response string
val Number startIndex = result.indexOf("<Preset_Sel>")
val Number endIndex = result.indexOf("</Preset_Sel>")
startIndex = startIndex + 12
// Post current preset to item
val Number presetNumber = new Integer( result.substring(startIndex.intValue, endIndex.intValue) ) as Integer
logDebug("Rules.YamahaReceiver.InputChange", "Post update for {} preset: {}", Yamaha_Input.state, presetNumber)
Yamaha_Preset.postUpdate(presetNumber)
I hope this will serve you well until it’s taken over to the official binding.
Best regards
Stephan
