I have been using the Yamaha RX-S601D for quite some time with openhab and as far as I know I always had the 2.4.-Binding which worked pretty stable. Lately I upgraded to OH 2.5. and since then the bridge became unstable. I originally had a static things file and I thought the issue might have come from that, so I moved to autodiscovery but both reveal the same symptom.
It discovered the following things that went online. I am usually even able to communicate with the device once (i.e. powering it off via OH) but then it goes offline as it seems it is getting a communication error afterwards.
later
- I then applied the latest receiver firmware but that did not change the behaviour.
- What I am also sometimes seeing is that from time to time the binding goes online again and goes back to offline…
Does anyone have an idea what the reason could be why the binding’s connection is so unstable?
Thanks in advance
Stefan
2020-02-08 23:06:00.243 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to ONLINE
2020-02-08 23:06:00.304 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLConnection.postMessage(XMLConnection.java:83) ~[bundleFile:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLConnection.sendReceive(XMLConnection.java:121) ~[bundleFile:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLProtocolService.getResponse(XMLProtocolService.java:82) ~[bundleFile:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLProtocolService.getZoneResponse(XMLProtocolService.java:68) ~[bundleFile:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.ZoneControlXML.applyModelVariations(ZoneControlXML.java:135) [bundleFile:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.ZoneControlXML.<init>(ZoneControlXML.java:94) [bundleFile:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLProtocolFactory.ZoneControl(XMLProtocolFactory.java:101) [bundleFile:?]
at org.openhab.binding.yamahareceiver.internal.handler.YamahaZoneThingHandler.bridgeStatusChanged(YamahaZoneThingHandler.java:213) [bundleFile:?]
2020-02-08 23:06:00.342 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:06:00.423 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:06:00.451 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:06:00.472 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:06:00.766 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:06:33.263 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:06:34.353 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to ONLINE
2020-02-08 23:06:51.305 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:07:00.382 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to OFFLINE (CONFIGURATION_ERROR): connect timed out
2020-02-08 23:07:00.419 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:07:05.351 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (CONFIGURATION_ERROR): connect timed out to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:07:13.742 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to ONLINE
2020-02-08 23:07:47.959 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:08:00.378 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:08:00.381 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:08:00.383 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:09:00.416 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to ONLINE
2020-02-08 23:09:00.454 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:09:00.469 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): connect timed out
2020-02-08 23:09:00.472 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (CONFIGURATION_ERROR): connect timed out to ONLINE
2020-02-08 23:09:00.530 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLConnection.postMessage(XMLConnection.java:83) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLConnection.sendReceive(XMLConnection.java:121) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLProtocolService.getResponse(XMLProtocolService.java:82) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLProtocolService.getZoneResponse(XMLProtocolService.java:68) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.ZoneControlXML.applyModelVariations(ZoneControlXML.java:135) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.ZoneControlXML.<init>(ZoneControlXML.java:94) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.protocol.xml.XMLProtocolFactory.ZoneControl(XMLProtocolFactory.java:101) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.handler.YamahaZoneThingHandler.bridgeStatusChanged(YamahaZoneThingHandler.java:213) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.handler.YamahaBridgeHandler.updateAllZoneInformation(YamahaBridgeHandler.java:261) ~[?:?]
at org.openhab.binding.yamahareceiver.internal.handler.YamahaBridgeHandler.lambda$0(YamahaBridgeHandler.java:217) ~[?:?]
2020-02-08 23:09:00.568 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:09:00.577 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:09:00.602 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:09:27.018 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' has been updated.
2020-02-08 23:09:27.023 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from ONLINE to OFFLINE (CONFIGURATION_PENDING): Waiting for connection with Yamaha device
2020-02-08 23:09:27.028 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:09:27.032 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:09:27.043 [WARN ] [internal.handler.YamahaBridgeHandler] - Communication error. Please review your Yamaha thing configuration.
2020-02-08 23:09:27.044 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from OFFLINE (CONFIGURATION_PENDING): Waiting for connection with Yamaha device to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:09:27.076 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' has been updated.
2020-02-08 23:09:27.604 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' has been updated.
2020-02-08 23:09:27.689 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to ONLINE
2020-02-08 23:09:27.733 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:09:27.779 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:09:27.809 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): connect timed out
2020-02-08 23:09:27.845 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:09:27.849 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:09:27.852 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from OFFLINE (CONFIGURATION_ERROR): connect timed out to ONLINE
2020-02-08 23:09:28.021 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:10:27.122 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:10:27.126 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:10:27.129 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:14:27.193 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to ONLINE
2020-02-08 23:14:27.290 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:14:27.332 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:14:27.354 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): connect timed out
2020-02-08 23:14:27.369 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): connect timed out
2020-02-08 23:14:27.372 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:14:27.382 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from OFFLINE (CONFIGURATION_ERROR): connect timed out to ONLINE
2020-02-08 23:14:27.391 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (CONFIGURATION_ERROR): connect timed out to ONLINE
2020-02-08 23:14:27.407 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:14:27.585 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:15:27.384 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:15:27.391 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:40:31.753 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from UNINITIALIZED to INITIALIZING
2020-02-08 23:40:31.859 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): Waiting for connection with Yamaha device
2020-02-08 23:40:31.847 [WARN ] [internal.handler.YamahaBridgeHandler] - Communication error. Please review your Yamaha thing configuration.
2020-02-08 23:40:31.875 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from OFFLINE (CONFIGURATION_PENDING): Waiting for connection with Yamaha device to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:40:32.068 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from UNINITIALIZED to INITIALIZING
2020-02-08 23:40:32.103 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from UNINITIALIZED to INITIALIZING
2020-02-08 23:40:32.518 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:40:32.521 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:40:33.003 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from OFFLINE (COMMUNICATION_ERROR): connect timed out to ONLINE
2020-02-08 23:40:33.109 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:40:33.144 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-02-08 23:40:33.149 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): connect timed out
2020-02-08 23:40:33.164 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (CONFIGURATION_ERROR): connect timed out to ONLINE
2020-02-08 23:40:33.371 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:40:33.592 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:40:33.664 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:41:33.181 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): connect timed out
2020-02-08 23:41:33.543 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:41:33.545 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:42:33.168 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:42:33.175 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:42:33.190 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from OFFLINE (CONFIGURATION_ERROR): connect timed out to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:54:59.437 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' has been updated.
2020-02-08 23:54:59.452 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:54:59.626 [me.event.ThingUpdatedEvent] - Thing 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' has been updated.
2020-02-08 23:55:59.251 [hingStatusInfoChangedEvent] - 'yamahareceiver:yamahaAV:9ab0c000_f668_11de_9976_00a0defd1401' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): connect timed out
2020-02-08 23:55:59.256 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Zone_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-02-08 23:55:59.260 [hingStatusInfoChangedEvent] - 'yamahareceiver:zone:9ab0c000_f668_11de_9976_00a0defd1401:Main_Zone' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
