https://www.dropbox.com/s/lmugkyne8fzc2wp/10.0.1.22-YamahaRemoteControl-desc.xml.pdf?dl=0
I see that the HTR-xxx will require more changes to be supported by the binding. Somehow Yamaha did it differently from the other models. After quick analysis based on the provided XML:
- The
Zone_2
is actually calledZone_B
. The weird thing is that it sits underMain_Zone
element and has specific command (Zone_B_Power
). This is way different than accounted in the binding - will require changes and some feature detection. -
Zone_2
seems to only allow changing of power, mute, volume (input, surround not supported).
Given the above, I suggest to raise a feature request on github (or separate community topic) about adding support for HTR-xxxx to the binding. I am not sure this was ever working with this model family. I could help with the changes, but it will require you to test new JAR releases since I donât have this modelâŠ
EDIT:
Jaco created an issue here:
Hi David,
thank you for the additional documentation but I still have questions and problems with using some channels of this binding.
I am new to openhab and wanted to use the Yamaha binding with my RX-V673 to learn some basics.
I am using OH 2.2.0-1 installed as openhabian on raspi 3 and I installed the yamaha binding from dropbox as explained here
I have been reading and searching through the documentation and the community but still can not find proper examples for my usecase.
Basic control is working like switching power and source(somehow working), volume and player stuff but I am struggling with menu navigation and presets.
Main question is now about item types for the definition and values for commands in my rules.
Items(just those with issue):
Right types used for navigation items? Could not find info on usage of UpDown Type.
Number Yamaha_Preset "Preset [%d]" <video>
String Yamaha_Tuner_Band "Band [%s]" <video>
//String Yamaha_Input_Ex
String navigation_menu "Menu [%s]" <video> //Select or display the full or relative path to an item.
Number navigation_current_item "Current [%s]" <video> //Get the current item of the current menu.
Number navigation_total_items "Total [%s]" <video> //Get the total count items in the current menu.
Number navigation_level "Level [%s]" <video> //Get the current menu level.
Number navigation //for rule setting
String navigation_updown //Move the cursor up or down.
String navigation_leftright //Move the cursor to the left or right.
String navigation_select //Select the current item.
String navigation_back //Navigate to the parent menu.
String navigation_backtoroot //Navigate back to the root menu.
Sitemap:
For the Navigation part I am using stuff I found in the forum. I wonder why the Number type item navigation is filled with a string but it seems to work as the rule is triggered and commands send.
sitemap yamaha label="Yamaha RX-V673"
Frame label="Steuerung" {
Switch item=Yamaha_Power
Switch item=Yamaha_Mute
Slider item=Yamaha_Volume
Selection item=Yamaha_Input mappings=[HDMI1="BlueRay",HDMI2="Wii-u",HDMI3="XBOX ONE",AV1="Bluetooth",AV4="TV",TUNER="Tuner","NET RADIO"="NET RADIO"]
Text item=Yamaha_Tuner_Band visibility=[Yamaha_Input=="TUNER"]
Selection item=Yamaha_Surround mappings=["2ch Stereo"="2ch Stereo","7ch Stereo"="7ch Stereo","Surround Decoder"="Surround Decoder","Standard"="Standard","Straight"="Straight"]
Frame label="Wiedergabe" {
Default item=Yamaha_Playback visibility=[Yamaha_Input=="BlueRay",Yamaha_Input=="Bluetooth",Yamaha_Input=="NET RADIO"]
Selection item=Yamaha_Preset mappings=[1="NDR 2 (HH)",6="N-JOY"] visibility=[Yamaha_Input=="NET RADIO"]
Selection item=Yamaha_Preset mappings=[1="NDR Info",5="Radio HH"] visibility=[Yamaha_Input=="TUNER"]
Text item=Yamaha_Playback_Station visibility=[Yamaha_Input=="NET RADIO",Yamaha_Input=="TUNER"]
Text item=Yamaha_Playback_Artist
Text item=Yamaha_Playback_Album
Text item=Yamaha_Playback_Song
//Image item=Yamaha_Playback_Song_Image visibility=[Yamaha_Input=="Spotify"]
Frame label="Menu" {
Text item=navigation_menu
Text item=navigation_current_item
Text item=navigation_total_items
Text item=navigation_level
Frame label="Navigation" {
Switch item=navigation mappings=["1"="_BACK_","2"="___âŹ___","3"="_HOME_"]
Switch item=navigation mappings=["4"="__âŹ
__","5"="__OK__","6"="___âš___"]
Switch item=navigation mappings=["7"="_____","8"="___âŹ___","9"="______"]
Rule:
I get warning message when saving (Configuration model âyamaha.rulesâ is either empty or cannot be parsed correctly!) it but it seems to work. Tried without the double quotes eg. navigation_back.sendCommand(ON) with same results in log.
Commands are send but probably with wrong content and get ignored by the receiver.
rule "Yamaha Control"
Item navigation received command
switch (receivedCommand) {
case 1: navigation_back.sendCommand("ON")
case 2: navigation_updown.sendCommand("UP")
case 3: navigation_backtoroot.sendCommand("ON")
case 4: navigation_leftright.sendCommand("UP")
case 5: navigation_select.sendCommand("ON")
case 6: navigation_leftright.sendCommand("DOWN")
case 8: navigation_updown.sendCommand("DOWN")
Any support would be appreciated.
Thanks,
Jean
rem: I am not sure where is the best place for my question as there are several threads around this binding and the navigation. If different place is better let me know.
Hi!
Thank you for this nice binding. I use it everyday. But I miss out two features: Party mode (swith) (same music in all zones) and Scene for the different zones. Would that be possible to add to the binding?
BR,
Joakim
Hi, Yes it is surely possible. I suggest to create a GitHub issue with a feature request. Put in as much details as you can. Someone will take a look.
Cheers
I missed the party mode and the scenes also.
(In the morning-alarm-clock and as global announcements from openhab itself )
As workaround I used the http-binding.
Here the *.items file
// overall zones
Switch Yamaha_PartyMode_On "Yamaha Partymode Ein" <receiver> (gYamahaHTTP) { http=">[ON:POST:http://192.168.xxx.xxx/YamahaRemoteControl/ctrl:<YAMAHA_AV cmd=\"PUT\"><System><Party_Mode><Mode>On</Mode></Party_Mode></System></YAMAHA_AV>]", expire="2s,command=OFF"}
Switch Yamaha_PartyMode_Off "Yamaha Partymode Aus" <receiver> (gYamahaHTTP) { http=">[OFF:POST:http://192.168.xxx.xxx/YamahaRemoteControl/ctrl:<YAMAHA_AV cmd=\"PUT\"><System><Party_Mode><Mode>Off</Mode></Party_Mode></System></YAMAHA_AV>]", expire="2s,command=OFF"}
// load scenes on zone main
Switch Yamaha_MainScene_1 "Yamaha Szene 1" <receiver> (gYamahaHTTP) { http=">[ON:POST:http://192.168.xxx.xxx/YamahaRemoteControl/ctrl:<YAMAHA_AV cmd=\"PUT\"><Main_Zone><Scene><Scene_Load>Scene 1</Scene_Load></Scene></Main_Zone></YAMAHA_AV>]", expire="2s,command=OFF"}
Switch Yamaha_MainScene_2 "Yamaha Szene 2" <receiver> (gYamahaHTTP) { http=">[ON:POST:http://192.168.xxx.xxx/YamahaRemoteControl/ctrl:<YAMAHA_AV cmd=\"PUT\"><Main_Zone><Scene><Scene_Load>Scene 2</Scene_Load></Scene></Main_Zone></YAMAHA_AV>]", expire="2s,command=OFF"}
Switch Yamaha_MainScene_3 "Yamaha Szene 3" <receiver> (gYamahaHTTP) { http=">[ON:POST:http://192.168.xxx.xxx/YamahaRemoteControl/ctrl:<YAMAHA_AV cmd=\"PUT\"><Main_Zone><Scene><Scene_Load>Scene 3</Scene_Load></Scene></Main_Zone></YAMAHA_AV>]", expire="2s,command=OFF"}
Switch Yamaha_MainScene_4 "Yamaha Szene 4" <receiver> (gYamahaHTTP) { http=">[ON:POST:http://192.168.xxx.xxx/YamahaRemoteControl/ctrl:<YAMAHA_AV cmd=\"PUT\"><Main_Zone><Scene><Scene_Load>Scene 4</Scene_Load></Scene></Main_Zone></YAMAHA_AV>]", expire="2s,command=OFF"}
So far I didnât manage to get feedback about the actual state - should be possible.
rule "SetPartyModeON"
Item AV_WF_Yamaha_Party received command
if (receivedCommand == ON) {
xml="<YAMAHA_AV cmd=\"PUT\"><System><Party_Mode><Mode>On</Mode></Party_Mode></System></YAMAHA_AV>"
data = sendHttpPostRequest('http://your_ip/YamahaRemoteControl/ctrl', 'text/xml', xml);
AV_WF_Yamaha_Party.postUpdate(ON);
else {
xml="<YAMAHA_AV cmd=\"PUT\"><System><Party_Mode><Mode>Off</Mode></Party_Mode></System></YAMAHA_AV>"
AV_WF_Yamaha_Party.postUpdate(OFF);
Hi!
Thankâs for the help
How should the variabled be declared? Should âdataâ be sent using a command?
BR,
Joakim
the variable gets the response :
Hi everybody,
Only in this thread find only just like of my issue, so I hope its not offtopic
I have a Yamaha htr-4066 AVR and everything working but one thing.
When I try Increase the volume works:
Item âYamaha_Volumeâ received command INCREASE
Yamaha_Volume changed from 17 to 18
But when try to Decrease, nothing happen:
Item âYamaha_Volumeâ received command DECREASE
Something happen, because the AVR screen change to volume, but show only the current value, not change.
Did you meet some king of issue, like this?
BR,
O.
Hi for me both increase and decrease volume works for this PR version: https://github.com/openhab/openhab2-addons/pull/3264 (it requires OH 2.3.0 snapshot). As far as I remember it also worked on previous version. It is weird why the decrease would not work if the increase works for you. You could post your sitemap/items fragment.
Thank you for your answer
item:
Dimmer Yamaha_Volume âAVR Volume [%d %%]â [âSwitchableâ] {channel=âyamahareceiver:zone:5f9ec1b3_ed59_1900_4530_00a0dea2b976:Main_Zone:zone_channels#volumeâ }
Sitemap:
Switch item=Yamaha_Volume label=âVolumeâ mappings=[DECREASE="-", INCREASE="+"]
O.
Hi @Gudszent_Otto,
My setup is 2.3.0-SNAPSHOT from the pull request I cited above and this works.
Switch item=Yamaha_Volume mappings=[DECREASE="-", INCREASE="+"]
Normally, I use a slider:
Here is my item:
Dimmer Yamaha_Volume "Volume [%.1f %%]" <soundvolume> (Cinema) { channel="yamahareceiver:zone:db18edf8:Main_Zone:zone_channels#volume" }
I think this should also work on previous addon version. Which version do you use?
Another thing to check - go to your yamaha thing setting (in PaperUI) and ensure the volume relative change factor is greater than zero.
Cheers,
I will try the 2.3.0 version, but currently my openhabian-config not offer me the update, so I have to wait
After the update, I will notice U
O.
Anyone interested in testing the party mode and scene support please join: https://github.com/openhab/openhab2-addons/issues/3393
CC: @teqnet, @AV_HomeAuto, @BigMountainSki
EDIT:
I ought to mention that after the upgrade you also need to adjust your thing settings because they are are now stored under a different name (see more info here). Because of that you need to set the IP/host address of your Yamaha on the Yamaha thing and assign the zone setting on each of the zone things.
If you configued via PaperUI go to > Configuration > Things > Yamaha Receiver > edit (pencil) > Address, and also Configuration > Things > Yamaha Main Zone > edit > Zone (set to âMain_Zoneâ). If you configured via the .thing
file see the updated documentation here - note the host
and zone
are now all lower case.
In case you still have issues enable detailed logging and get back to me please.
Pull request can be found here
Hello dear community.
Could you put in the Yamaha Binding a delay after sending the ON / OFF command to delay the receiverâs response a little? My receiver RX-V575 seems to be a little sluggish.
After sending the ON command the answer is given but the status is still OFF. Felt 0.5 - 1 second later, the reciver returns the correct status. I have already created an issue on Github. Many thanks for your help.
Please see me comment on the issue.
