Running: openHAB 5.2.0.RC1 (Milestone Build)
I’ve been using some transformations to get the weather data from the US NWS. In 5.2 RC1, just upgraded from 5.1, I see this ‘INFO’ message, but it’s not clear to me what it is asking me to do. Since it is an INFO, does it need any action?
[INFO ] [ml.internal.things.YamlThingProvider] - "http:url:NWSChelan:Period_1_Name": the value of the configuration TEXT parameter "stateTransformation" is not interpreted as a string and will be automatically converted. Enclose your value in double quotes to prevent conversion.
The YAML thing code is:
Period_1_Name:
type: string
label: Period 1 Name
stateTransformation:
- "JSONPATH:$.properties.periods[0].name"
What value needs to be enclosed in double quotes? And what is it automatically converted to?
