YAML Widget formatting
Honestly, in my experience you could do everything with rows because you can override the default flex settings (for that matter you could do nearly everything with just f7-blocks too). But I think that using the alternating rows and cols if you’re actually building a grid of component is just slightly cleaner and easier code to read.
I do all my widget development in the MainUI editor. Nothing else that I’m aware of at the moment is going to give you the autocomplete ([ctrl] + [space]) feature that the editor gives you and it’s the only way to get the immediate preview.
My reference hierarchy is as follows: My first go-to is the autocomplete in the editor itself to see what’s available for a given component. If it’s not immediately clear what a particular property does then I’ll hop over to the the f7 vue docs to get the details. If it’s an oh- component, then it also helps sometimes to have a look at the autogenerated oh component docs but more often, I’ll check out the vue files on the webUI repository itself.
