duiffie
(Marco)
September 8, 2026, 2:26pm
1
I’d like to link 2 channel definitions to an item, one with an empty config and the other with a follow-profile. The reason is because I want a radiator valve to use the temperature measured by an external temperature sensor. I’m using yamlcomposer to create my items. My code:
${property}_T:
type: Number
label: Temperature
icon: temperature
groups: ${[equipment] + temperature.groups}
tags: [Measurement,Temperature]
format: '%.1f °'
channels:
mqtt:topic:${thingid}:temperature: {}
mqtt:topic:${thingid | replace("C", "R")}:external_temperature_input:
profile: system:follow
The first channel is completely missing in the composed yaml file. Is that because of the empty map ({}) and is it a bug then? Or am I doing something wrong?
jimtng
(jimtng)
September 8, 2026, 2:31pm
2
Can you paste the relevant parts of the composed yaml file?
duiffie
(Marco)
September 8, 2026, 3:00pm
3
The composed part is:
pFF_BE1_C_T:
type: Number
label: Temperature
icon: temperature
groups:
- eFF_BE1_C
- gPIDController_Temperatures
- gPersist_GraphInflux
- gPersist_RestoreOnStartup
tags:
- Measurement
- Temperature
format: '%.1f °'
channels:
mqtt:topic:tZB_FF_BE1_R:external_temperature_input:
while I expected it to be:
pFF_BE1_C_T:
type: Number
label: Temperature
icon: temperature
groups:
- eFF_BE1_C
tags:
- Measurement
- Temperature
format: '%.1f °'
channels:
mqtt:topic:tZB_FF_BE1_C:temperature: {}
jimtng
(jimtng)
September 8, 2026, 9:57pm
4
It’s strange. I cannot reproduce this issue on 5.2.1.
Here’s my test:
variables:
property: Test
thingid: ThingID_C
equipment: equipment
temperature:
groups: temp_group
items:
${property}_T:
type: Number
label: Temperature
icon: temperature
format: '%.1222f °'
channels:
The output:
# Generated by openHAB 5.2.1 (Release Build) YAML Composer, DO NOT EDIT
# Source: yamlcomposer/main.yaml
# Generated: 2026-09-09T07:54:47.140460642+10:00[Australia/Brisbane]
items:
Test_T:
type: Number
label: Temperature
icon: temperature
groups:
- equipment
- temp_group
tags:
- Measurement
- Temperature
format: '%.1222f °'
channels:
mqtt:topic:ThingID_C:temperature: {
mqtt:topic:ThingID_R:external_temperature_input:
Can you show the surroundings of the source yaml block? Is there a !remove involved?
duiffie
(Marco)
September 9, 2026, 6:43am
5
I don’t use !remove. The construction I use is as follows, I can reproduce it with these files:
<OH_PATH>/yamlcomposer/testcase.yaml:
version: 1
variables:
instance: myinstance
room: ${__FILE_NAME__}
shortname: TESTCASE
packages:
C: !include
file: $pkg/testcase.inc.yaml
vars:
temperature:
groups:
<OH_PATH>/yamlcomposer/pkg/testcase.inc.yaml:
variables:
thingid: tZB_${id | upper}
topic: ${id | lower | replace("_", "-")}
equipment: e${id}
property: p${id}
label: ${id | label}
etemperature: &DEFAULTS
default_groups: [gPersist_GraphInflux,gPersist_RestoreOnStartup]
humidity:
<<: *DEFAULTS
${property}_T:
type: Number
label: Temperatuur
icon: temperature
groups: ${[equipment] + temperature.groups + etemperature.default_groups}
format: '%.1f °'
channels:
This results in the following composed <OH_PATH>/yaml/composed/testcase.yaml:
# Source: yamlcomposer/testcase.yaml
# Generated: 2026-09-09T08:40:07.468242374+02:00[Europe/Amsterdam]
version: 1
items:
pTESTCASE_C_T:
type: Number
label: Temperatuur
icon: temperature
groups:
- eTESTCASE_C
tags:
- Measurement
- Temperature
format: '%.1f °'
channels:
mqtt:topic:tZB_TESTRASE_R:external_temperature_input:
jimtng
(jimtng)
September 9, 2026, 6:55am
6
I can confirm this appears to be a bug.
Current workaround:
channels:
profile: default
duiffie
(Marco)
September 9, 2026, 7:04am
7
Thanks, workaround seems to be doing the trick for now
jimtng
(jimtng)
September 9, 2026, 7:34am
8
main ← jimtng:yamlcomposer-package-preserve-emptymap
opened 07:29AM - 09 Sep 26 UTC
Issue reported in the forum
https://community.openhab.org/t/yamlcomposer-pass-em… pty-map-to-channels-definition-bug/170356
I’ve also created a backport patch: [yamlcomposer] Fix missing empty maps in the package output by jimtng · Pull Request #21636 · openhab/openhab-addons · GitHub
jimtng
(jimtng)
September 9, 2026, 7:38am
9
I originally wanted to clean up the package output so I deliberately stripped away empty maps and lists. However there’s obviously a need to preserve them in the case of item channels exactly in this situation.
So the fix simply removes the code that strips the empty maps and lists.
