[Yeelight] How to set rules
Hello, i have problem. I’ trying to set automatic light when (MotionSensor_MotionStatus.state == ON). I dont know how turn od yeelight and change Temperature to 30%. I hava:
Switch Yeelight_Kitchen_Status “Status” { channel=“yeelight:stripe:3:color” }
Color Yeelight_Kitchen_Color “Kolor” { channel=“yeelight:stripe:3:color” }
Dimmer Yeelight_Kitchen_Temperature “Temperatura” { channel=“yeelight:stripe:3:colorTemperature” }
And rules:
rule "Mijia & Aqara Motion Sensor"
    Item MotionSensor_MotionStatus changed
    if (MotionSensor_MotionStatus.state == ON)
    	Yeelight_Kitchen_Status.status(ON)
    	Yeelight_Kitchen_Temeprature.sendCommand(30)
That line doesn’t make much sense, just take that one out. Find openhab.log file to see error messages
Now work but i dont know how change brightness, now work only Status/Temperature
    Item MotionSensor_MotionStatus changed to ON
    Yeelight_Kitchen_Status.sendCommand(ON)
    Yeelight_Kitchen_Brightness.sendCommand(1)
    Yeelight_Kitchen_Temperature.sendCommand(50)
    Yeelight_Living_Room_Status.sendCommand(ON)
    Yeelight_Living_Room_Brightness.sendCommand(1)
    Yeelight_Living_Room_Temperature.sendCommand(50)
Switch Yeelight_Living_Room_Status “Status” { channel=“yeelight:stripe:2:color” }
Color Yeelight_Living_Room_Color “Kolor” { channel=“yeelight:stripe:2:color” }
Dimmer Yeelight_Living_Room_Temperature “Temperatura” { channel=“yeelight:stripe:2:colorTemperature” }
Dimmer Yeelight_Living_Room_Brightness “Temperatura” { channel=“yeelight:stripe:2:brightness” }
Dimmer Yeelight_Kitchen_Brightness “Temperatura” { channel=“yeelight:stripe:3:brightness” }
OpenHab dont see (Dimmer Yeelight_Living_Room_Brightness) , i dont have this Dimmer in Control too
look at the dokumentation.
brightness Dimmer This channel supports adjusting the brightness value, it is available on dolphin and ceiling .
Do you have a dolphin or a ceiling lamp?
For my Yeelights i take this AddOn.
Then only thing that you need is a token.
I’m trying Xiaomi Mi IO bot i don’t know how get “TOKEN”.
Here a link. Maybe to the solution.
