Hi , I search on the forum and didn’t see any one with the same issue…
the service didn’t seems to work… If I start openhab manually it work !
this is the status off the service
openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Sun 2017-07-16 16:32:06 EDT; 2s ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 1950 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=1/FAILURE)
Main PID: 2117 (karaf)
CGroup: /system.slice/openhab2.service
├─2117 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
└─2268 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runt…
