I have node that continuously logs the following:
18:08:35.559 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415181 to 415182
18:08:35.579 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415182 to 415183
18:08:35.590 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:43f84cf2:node19’ has been updated.
18:08:36.416 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415183 to 415184
18:08:36.475 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:43f84cf2:node19’ has been updated.
18:08:37.414 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415184 to 415185
18:08:37.429 [WARN ] [org.jline ] - Failed to save history
java.nio.file.AccessDeniedException: /home/openhab
at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) [?:?]
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) [?:?]
at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) [?:?]
at sun.nio.fs.UnixFileSystemProvider.createDirectory(UnixFileSystemProvider.java:384) [?:?]
at java.nio.file.Files.createDirectory(Files.java:674) [?:?]
at java.nio.file.Files.createAndCheckIsDirectory(Files.java:781) [?:?]
at java.nio.file.Files.createDirectories(Files.java:767) [?:?]
at org.jline.reader.impl.history.DefaultHistory.save(DefaultHistory.java:124) [14:org.jline:3.6.0]
at org.jline.reader.impl.history.DefaultHistory.add(DefaultHistory.java:253) [14:org.jline:3.6.0]
at org.jline.reader.impl.LineReaderImpl.finishBuffer(LineReaderImpl.java:887) [14:org.jline:3.6.0]
at org.jline.reader.impl.LineReaderImpl.readLine(LineReaderImpl.java:566) [14:org.jline:3.6.0]
at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.run(ConsoleSessionImpl.java:343) [12:org.apache.karaf.shell.core:4.1.5]
18:08:37.431 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:43f84cf2:node19’ has been updated.
18:08:38.421 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415185 to 415186
18:08:38.450 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_ack changed from 98314 to 98315
18:08:38.483 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:43f84cf2:node19’ has been updated.
18:08:38.509 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415186 to 415187
18:08:38.536 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415187 to 415188
18:08:39.417 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415188 to 415189
18:08:39.463 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:43f84cf2:node19’ has been updated.
18:08:40.411 [INFO ] [smarthome.event.ItemStateChangedEvent] - zwave_serial_zstick_43f84cf2_serial_sof changed from 415189 to 415190
The battery eventually runs out because it never gets updated?
Any ideas where to start troubleshooting?
