I’m trying to get my Aeotec z-stick Gen 5 to work with OpenHAB and I’m not having any success getting the devices I’ve paired to show up in HABmin.
I paired 2 of my Fibaro sensors to the z-wave stick. I verified the sensors successfully paired using the Aeotec IMA tool.
I determined that the z-wave stick is ttyACM0 when plugged into my RPi3.
I’ve edited the openhab.cfg z-wave Binding to zwave:port=/dev/ttyACM0
I ran sudo usermod -a -G dialout openhab in the terminal window.
I added the text below to my home.items file:
Number Movement “Movement: [%s]” { zwave=“3:command=sensor_binary” }
Number Alarm “Alarm: [%s]” { zwave=“3:command=sensor_alarm” }
Number Lux “Lux: [%.2f Lux]” { zwave=“3:command=sensor_multilevel,sensor_type=3” }
Number Bat “Battery: [%d %%]” { zwave=“3:command=battery” }
Number Temp “Temperature: [%.1f °C]” { zwave=“3:command=sensor_multilevel,sensor_type=1” }
I restarted openhab.
I open up HABmin (version 0.1.4), select “Configuration”, “Bindings”. I see 2 z-wave Bindings, one is version 1.8.0.201508211938 and the other is version 1.8.3.
Neither one of them has any values in “Devices”.
