To help get this comfortable working alle Informations I could get together:
After Including came following channels:
Electric meter (volts)
meter_voltage
OK, shows Voltage N L of Device Input
Electric meter (kWh)
meter_kwh
OK, seems to show Usage of Device
Electric meter (watts)
meter_watts
Thermostat mode
thermostat_mode
OK, can set Off, Eco, Heat and Cooling, all tested
Setpoint (cooling)
thermostat_setpoint_cooling
OK, shows Setpoint für Cooling-Mode
IMPORTANT/WISH: Channel to Change Cooling-Setpoint (Parameter 11)
Setpoint (furnace)
thermostat_setpoint_furnace
NaN / null after days! Not need it when noch used by device
Setpoint (heating)
thermostat_setpoint_heating
OK, shows Setpoint für Heating-Mode or Eco Mode, depends on Mode!
IMPORTANT/WISH: Two Input-Channel to Change Heating-Setpoints (Eco: Parameter 10, Heating Parameter 9)
Thermostat mode 1
thermostat_mode1
Works, but double of thermostat_mode
Setpoint (cooling) 1
thermostat_setpoint_cooling1
Works, but double of thermostat_setpoint_cooling
Setpoint (furnace) 1
thermostat_setpoint_furnace1
Double and Allways NaN/null like thermostat_setpoint_furnace
Setpoint (heating) 1
thermostat_setpoint_heating1
Works, but double of setpoint_heating
External sensor
sensor_temperature2
Ok, works fine
Floor sensor
sensor_temperature3
Ok, works fine
Switch 4
switch_binary4
without function, without sense, Can’t find anything happens when Switch Status changed, Could do with device everything and switch don’t changes
Electric meter (volts) 4
meter_voltage4
No Value after hours! (NaN / null), maybe should show output Voltage?, could be useful, but didn’t work. not needed as a copy of meter_voltage, but think this should be outgoing voltage. Could not see the Database, but looks like Value should be here is send in meter_kwh4
Electric meter (kWh) 4
meter_kwh4
Gots Values like 240,3 when economy heating went on, goes back to 0,0, then 237, and so else. Seems like Two different values were given to this field:
2019-01-26 00:56:14.736 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242 to 0
2019-01-26 00:56:20.308 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242
2019-01-26 00:56:35.417 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242 to 242.1
2019-01-26 00:56:35.566 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.1 to 0
2019-01-26 00:57:20.950 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.2
2019-01-26 00:58:06.461 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.2 to 242.5
2019-01-26 00:58:06.609 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.5 to 0
2019-01-26 00:58:21.592 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.4
2019-01-26 00:58:24.621 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.4 to 0
2019-01-26 00:58:44.551 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.4
2019-01-26 00:58:44.699 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.4 to 0
2019-01-26 00:59:04.146 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.4
2019-01-26 00:59:04.294 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.4 to 0
2019-01-26 00:59:21.495 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.4
2019-01-26 00:59:21.644 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.4 to 0
2019-01-26 00:59:23.825 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.4
2019-01-26 01:00:23.768 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.4 to 0
2019-01-26 01:00:23.909 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.2
2019-01-26 01:01:23.920 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 242.2 to 0
2019-01-26 01:01:24.130 [vent.ItemStateChangedEvent] - ZWaveNode003ZTRM2fxFloorThermostat_ElectricMeterKWh4 changed from 0 to 242.3
Electric meter (watts) 4
meter_watts4
Could be useful if switched device / Heating Usage. While testing I had no electric user behind Thermostat, not needed as a double, but great if for Heating Usage.
Two other things would be great: Dimmed State (Param15/17) and active brighness (16/18) for Parameter To Switch off Lights in Childrens room by night, something like that.
I now it’s a lot of Work for you to read, to support and to code. Hope this analyses helps you.
