Hi Team
New to OpenHAB. I have just got hold of a Raspberry pi 3, installed
OpenHab 2, have my Sones, HUE, Chromecast up and running (not yet presented in
a nice way – have to find more info about how OpenHAB works ;-)).
And now to the question. I would like to get all my windows
covered with sensors, so when I leave, I can see at a display, if all windows
are closed – that is 10 windows.
And I can see, that the easiest way would be to setup up z
wave windows sensors at all windows – but also the most expensive.
(z wave estimated price - RaspUnit: Aeon Stick Gen5: 50 Euro, Windows: 40 Euro each – 400 Euro,
Total 450 Euro.)
433Mhz solution looks to much cheaper
(433Mhz estimated price - RaspUnit: Rfxcom Transceiver USB :
110 Euro, Windows: 10 euro each – 100 Euro, Total: 220 Euro).
But it also sounds like, that not all 433 stuff works
together. You have to debug the signals and find out, what to send and receive.
“LightWaveRF” WiFi link (?)
looks like there is some kind of binding for this (https://github.com/openhab/openhab/wiki/LightwaveRF-Binding),
so this should also work with OpenHAB, and you should expect this works between
the components, since it is from same vendor.…
(LIghtWaveRF estimated price – Raspunit (via wifi) LightwaveRF JSJSLW930 Smartphone Wi-Fi Web
Link: 90 pund, Windows: 14 pund each – 140 pund, Total 230 pund – 270 euro).
So is the conclusion:
zWave – 450 euro, should be easy and almost guarantied will
work.
LightWaveRF Wifi Link – 270 Euro, Should also work since
from same company.
433Mhz – 220 euro, cheapest, but not sure if it works.
Regarding 433 Mhz – do we have experience with ‘set’ or
elements that works together, and should be okey to work with ?
Looking forward for your comments - and guidance
/Joern.
