my dimmer setup does not work the way I would expect. I am not sure whether it is a binding issue.
Setup:
// Standleuchte
Dimmer EG_WZ_SL_Helligkeit "Standleuchte [%2.0f]" ["Lighting"] {channel="zwave:device:312486fb:node5:switch_dimmer"}
Number EG_WZ_SL_Leistung "Leistung [%f Watt]" {channel="zwave:device:312486fb:node5:meter_watts"}
Number EG_WZ_SL_Verbrauch "Verbrauch [%.2f kWh]" {channel="zwave:device:312486fb:node5:meter_kwh"}
sitemap EG_WZ label="Standleuchte Test"
Frame label="Wohnzimmer Standleuchte" {
Switch item=EG_WZ_SL_Helligkeit label="AN / AUS [%2.0f]"
Slider item=EG_WZ_SL_Helligkeit label="Helligkeit [%2.0f]"
Text item=EG_WZ_SL_Leistung label="aktuelle Leistung [%2.0f Watt]" icon="light"
Text item=EG_WZ_SL_Verbrauch label="Verbrauch [%2.2f kWh]" icon="light"
Steps:
- switch on dimmer using slider element of sitemap, e.g. 20% -> works as expected, labels are set to 20%, lamp is dimmed to 20% brightness
- switch off dimmer using switch element of sitemap -> works as expected, label are set to 0%, lamp is out
- switch on dimmer using switch element of sitemap -> labels are updated to 100%, slider is set to 100%, but lamp is not set to 100% brightness. It is set to the previous value of slider element, here 20%
Here are the debugging logs doing step 3) after that I am using the slider to set brightness to 99% while
slider already shows 100%,
You can see that the meter value is 10 watt when brightness level is 100% using the switch element and then inreases to 78 watt when brightness is set to 99% using the slide element.
openhab> log:tail
21:13:37.119 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EG_WZ_SL_Helligkeit' received command ON
21:13:37.121 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Command received zwave:device:312486fb:node5:switch_dimmer --> ON
21:13:37.123 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Creating new message for command SWITCH_MULTILEVEL_SET
21:13:37.125 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
21:13:37.125 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
21:13:37.127 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 05 03 26 01 FF 25 0C 11
21:13:37.127 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0A 00 13 05 03 26 01 FF 25 0C 11
21:13:37.133 [INFO ] [marthome.event.ItemStateChangedEvent] - EG_WZ_SL_Helligkeit changed from 0 to 100
21:13:37.139 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
21:13:37.145 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:37.146 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
21:13:37.147 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
21:13:37.148 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
21:13:37.149 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
21:13:37.197 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 0C 00 00 06 E1
21:13:37.203 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:37.204 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 0C 00 00 06 00 00 EF
21:13:37.205 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 0C 00 00 06 00 00 EF
21:13:37.207 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=0C 00 00 06
21:13:37.209 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 12, Status = Transmission complete and ACK received(0)
21:13:37.211 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
21:13:37.212 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@16804b4 already registered
21:13:37.213 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=12, payload=05 03 26 01 FF
21:13:37.215 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=0C 00 00 06
21:13:37.216 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=12, expected=SendData, cancelled=false transaction complete!
21:13:37.216 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
21:13:37.217 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
21:13:37.220 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 92ms/5002ms.
21:13:39.584 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 74 00 00 27 ED 00 00 00 00 00 00 4B
21:13:39.590 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:39.591 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 05 0E 32 02 21 74 00 00 27 ED 00 00 00 00 00 00 4B
21:13:39.593 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 05 0E 32 02 21 74 00 00 27 ED 00 00 00 00 00 00 4B
21:13:39.595 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 00 27 ED 00 00 00 00 00 00
21:13:39.596 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
21:13:39.597 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
21:13:39.597 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@16804b4 already registered
21:13:39.609 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
21:13:39.610 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received METER command V3
21:13:39.611 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=10.221
21:13:39.613 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
21:13:39.614 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMeterValueEvent
21:13:39.617 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 10.221
21:13:39.620 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_KWh <> E_W
21:13:39.623 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:312486fb:node5:meter_watts to 10.221 [DecimalType]
21:13:39.629 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=12, payload=05 03 26 01 FF
21:13:39.635 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 00 27 ED 00 00 00 00 00 00
21:13:39.636 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=12, expected=SendData, cancelled=false MISMATCH
21:13:39.644 [INFO ] [marthome.event.ItemStateChangedEvent] - EG_WZ_SL_Leistung changed from 0 to 10.221
21:13:50.185 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EG_WZ_SL_Helligkeit' received command 99
21:13:50.188 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Command received zwave:device:312486fb:node5:switch_dimmer --> 99
21:13:50.191 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Creating new message for command SWITCH_MULTILEVEL_SET
21:13:50.192 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
21:13:50.192 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
21:13:50.193 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 05 03 26 01 63 25 0D 8C
21:13:50.194 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 0A 00 13 05 03 26 01 63 25 0D 8C
21:13:50.205 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
21:13:50.208 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:50.209 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
21:13:50.210 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
21:13:50.210 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
21:13:50.210 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
21:13:50.239 [INFO ] [marthome.event.ItemStateChangedEvent] - EG_WZ_SL_Helligkeit changed from 100 to 99
21:13:50.268 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 0D 00 00 05 E3
21:13:50.294 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:50.295 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 0D 00 00 05 00 00 ED
21:13:50.301 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 0D 00 00 05 00 00 ED
21:13:50.310 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=0D 00 00 05
21:13:50.311 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 13, Status = Transmission complete and ACK received(0)
21:13:50.312 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
21:13:50.313 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@16804b4 already registered
21:13:50.314 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=13, payload=05 03 26 01 63
21:13:50.315 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=0D 00 00 05
21:13:50.316 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=13, expected=SendData, cancelled=false transaction complete!
21:13:50.329 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
21:13:50.337 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
21:13:50.338 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 143ms/5002ms.
21:13:52.588 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 74 00 00 B2 EA 00 00 00 00 00 00 D9
21:13:52.591 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:52.592 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 05 0E 32 02 21 74 00 00 B2 EA 00 00 00 00 00 00 D9
21:13:52.594 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 05 0E 32 02 21 74 00 00 B2 EA 00 00 00 00 00 00 D9
21:13:52.595 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 00 B2 EA 00 00 00 00 00 00
21:13:52.596 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
21:13:52.597 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
21:13:52.598 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@16804b4 already registered
21:13:52.598 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
21:13:52.599 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received METER command V3
21:13:52.608 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=45.802
21:13:52.609 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
21:13:52.610 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMeterValueEvent
21:13:52.611 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 45.802
21:13:52.612 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_KWh <> E_W
21:13:52.613 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:312486fb:node5:meter_watts to 45.802 [DecimalType]
21:13:52.616 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=13, payload=05 03 26 01 63
21:13:52.618 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 00 B2 EA 00 00 00 00 00 00
21:13:52.619 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=13, expected=SendData, cancelled=false MISMATCH
21:13:52.623 [INFO ] [marthome.event.ItemStateChangedEvent] - EG_WZ_SL_Leistung changed from 10.221 to 45.802
21:13:53.631 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 74 00 01 25 4F 00 00 00 00 00 00 EA
21:13:53.635 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:53.637 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 05 0E 32 02 21 74 00 01 25 4F 00 00 00 00 00 00 EA
21:13:53.638 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 05 0E 32 02 21 74 00 01 25 4F 00 00 00 00 00 00 EA
21:13:53.640 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 01 25 4F 00 00 00 00 00 00
21:13:53.641 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
21:13:53.641 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
21:13:53.642 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@16804b4 already registered
21:13:53.642 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
21:13:53.643 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received METER command V3
21:13:53.644 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=75.087
21:13:53.645 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
21:13:53.646 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMeterValueEvent
21:13:53.646 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 75.087
21:13:53.647 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_KWh <> E_W
21:13:53.648 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:312486fb:node5:meter_watts to 75.087 [DecimalType]
21:13:53.651 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=13, payload=05 03 26 01 63
21:13:53.653 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 01 25 4F 00 00 00 00 00 00
21:13:53.654 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=13, expected=SendData, cancelled=false MISMATCH
21:13:53.666 [INFO ] [marthome.event.ItemStateChangedEvent] - EG_WZ_SL_Leistung changed from 45.802 to 75.087
21:13:54.584 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 05 0E 32 02 21 74 00 01 31 F3 00 00 00 00 00 00 42
21:13:54.587 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
21:13:54.589 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 14 00 04 00 05 0E 32 02 21 74 00 01 31 F3 00 00 00 00 00 00 42
21:13:54.590 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 14 00 04 00 05 0E 32 02 21 74 00 01 31 F3 00 00 00 00 00 00 42
21:13:54.592 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 01 31 F3 00 00 00 00 00 00
21:13:54.592 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
21:13:54.593 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from DONE
21:13:54.594 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@16804b4 already registered
21:13:54.595 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
21:13:54.595 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received METER command V3
21:13:54.597 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=W(2), Value=78.323
21:13:54.598 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
21:13:54.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveMeterValueEvent
21:13:54.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 78.323
21:13:54.600 [DEBUG] [ternal.converter.ZWaveMeterConverter] - Not the right scale E_KWh <> E_W
21:13:54.601 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Updating channel state zwave:device:312486fb:node5:meter_watts to 78.323 [DecimalType]
21:13:54.604 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=5, callback=13, payload=05 03 26 01 63
21:13:54.606 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 0E 32 02 21 74 00 01 31 F3 00 00 00 00 00 00
21:13:54.607 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=13, expected=SendData, cancelled=false MISMATCH
21:13:54.619 [INFO ] [marthome.event.ItemStateChangedEvent] - EG_WZ_SL_Leistung changed from 75.087 to 78.323
I am using openHAB 2.1.0
Any hints from the experts what I am doing wrong.
Any help is appreciated.
best,
ypoosn
