I’ve been seeing this on startup:
2019-05-22 13:42:39.006 [hingStatusInfoChangedEvent] - ‘zwave:device:42822b8b:node18’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-05-22 13:42:39.014 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred during notification about bridge status change on thing ‘zwave:device:42822b8b:node18’: 1
java.lang.ArrayIndexOutOfBoundsException: 1
at org.openhab.binding.zwave.handler.ZWaveThingHandler.initialiseNode(ZWaveThingHandler.java:222) ~[?:?]
at org.openhab.binding.zwave.handler.ZWaveThingHandler.bridgeStatusChanged(ZWaveThingHandler.java:508) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$4.run(ThingManagerImpl.java:901) [109:org.eclipse.smarthome.core.thing:0.11.0.oh250M1]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Node 18 is a ZD2102-5 Door Window Sensor.
I haven’t done much testing on the node since 2.5.0.M1 was installed.
