Z-Wave binding de-activating and re-activating spontaneously
Hi all,
I dove in again to re-install my OH system fresh, then restored backups.
OH 2.5.2 release build, Raspberry Pi 3B+, running off of SSD (no microSD)
I did a fresh install, then restored my OH backup, then restored my influxdb backup.
Much looks to be working correctly, however I’m having issues with zwave.
I’ve tried a variety of approaches - using the stock 2.5.2 zwave binding, removing it and manually adding the 2.5.0 snapshot (Nov 16 2019) that I had been using when the backup was made, removing it and going back to the stock 2.5.2 binding. I deleted and re-added my z-wave controller (RaZberry hat)
Watching the logs after doing this the last time revealed the controller revealed that it was successfully getting updates when it suddenly was deactivated. It seems to my simplistic look that a scheduler shutdown the zwave service. I can’t figure out why, and would appreciate suggestions on where to look. The relevant log is below.
2020-03-02 23:23:37.302 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 39 to 40
2020-03-02 23:23:37.371 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 44
2020-03-02 23:23:37.372 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 43 to 44
2020-03-02 23:23:37.930 [INFO ] [org.quartz.core.QuartzScheduler     ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
2020-03-02 23:23:40.470 [INFO ] [internal.service.FeaturesServiceImpl] - No deployment change.
2020-03-02 23:23:40.474 [INFO ] [internal.service.FeaturesServiceImpl] - Stopping bundles:
2020-03-02 23:23:40.477 [INFO ] [internal.service.FeaturesServiceImpl] -   org.openhab.core.config.serial/2.5.0
2020-03-02 23:23:40.500 [INFO ] [internal.service.FeaturesServiceImpl] -   org.openhab.binding.zwave/2.5.2
2020-03-02 23:23:40.609 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from ONLINE to UNINITIALIZED
2020-03-02 23:23:40.784 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
My zwave client devices seem to come online when the controller is up and receiving updates per the log, then the statuses all go to UNINITIALIZED-HANDLER MISSING .
A bigger grab from the logs of all of my logs, filtered for the controller name, is:
2020-03-02 23:55:28.121 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 58 to 59
2020-03-02 23:55:28.149 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from ONLINE: Node initialising: REQUEST_NIF to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
2020-03-02 23:55:28.177 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 47 to 48
2020-03-02 23:55:28.246 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 59 to 60
2020-03-02 23:55:32.934 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 60 to 61
2020-03-02 23:55:32.961 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 48 to 49
2020-03-02 23:55:33.031 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 61 to 62
2020-03-02 23:55:35.657 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:55:35.744 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:35.749 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to UNINITIALIZED
2020-03-02 23:55:35.812 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:35.816 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:55:35.870 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:35.874 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:55:35.927 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:35.931 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:55:35.980 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:35.982 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node32' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:55:36.031 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node32' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:36.034 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:55:36.080 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:36.082 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node12' changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to UNINITIALIZED
2020-03-02 23:55:36.133 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node12' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:36.135 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node20' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:55:36.181 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node20' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:36.184 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to UNINITIALIZED
2020-03-02 23:55:36.761 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:55:36.801 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:36.803 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from ONLINE to UNINITIALIZED
2020-03-02 23:55:37.005 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:55:49.020 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.041 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.095 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node9' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.118 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node9' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.179 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.186 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.190 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node29' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.202 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.206 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node37' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.214 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.219 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.237 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node12' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.246 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node19' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.250 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node29' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.260 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.269 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node37' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.282 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node12' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.303 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node19' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.307 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node20' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.310 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.317 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.321 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node20' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.336 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.347 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.375 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node22' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.389 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node11' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.392 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.396 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node31' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.399 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node32' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.417 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node11' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.430 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.435 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node22' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.489 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node31' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.499 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node36' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.502 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node32' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.511 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.515 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node21' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.520 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node23' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.525 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node36' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.543 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node23' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.547 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.550 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node21' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.554 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.558 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.563 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-02 23:55:49.577 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.590 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:49.597 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-02 23:55:54.130 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 62 to 0
2020-03-02 23:55:54.139 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 49 to 0
2020-03-02 23:55:57.259 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 0 to 1
2020-03-02 23:55:57.267 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 0 to 1
2020-03-02 23:55:57.352 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 1 to 2
2020-03-02 23:55:57.354 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 1 to 2
2020-03-02 23:55:57.423 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 2 to 3
2020-03-02 23:55:57.425 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 2 to 3
2020-03-02 23:55:57.489 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 3 to 4
2020-03-02 23:55:57.491 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 3 to 4
2020-03-02 23:55:57.551 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 4 to 5
2020-03-02 23:55:57.553 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 4 to 5
2020-03-02 23:55:57.607 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 5 to 6
2020-03-02 23:55:57.667 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 5 to 6
2020-03-02 23:55:58.042 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 6 to 7
2020-03-02 23:55:58.047 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 6 to 7
2020-03-02 23:55:58.899 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 7 to 8
2020-03-02 23:55:58.903 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 7 to 8
2020-03-02 23:55:58.973 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 8 to 9
2020-03-02 23:55:58.984 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 8 to 9
2020-03-02 23:55:59.035 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 9 to 10
2020-03-02 23:55:59.280 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 9 to 10
2020-03-02 23:56:04.356 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 10 to 11
2020-03-02 23:56:04.392 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 10 to 11
2020-03-02 23:56:04.640 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 11 to 12
2020-03-02 23:56:08.133 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.140 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.155 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node29' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.163 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.170 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.178 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node9' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.186 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from NULL to 12
2020-03-02 23:56:08.200 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from NULL to 11
2020-03-02 23:56:08.221 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_nak changed from NULL to 0
2020-03-02 23:56:08.245 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_can changed from NULL to 0
2020-03-02 23:56:08.271 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node37' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.279 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node12' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.294 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node19' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.303 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node20' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.314 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.321 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.326 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node22' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.333 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.340 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node32' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.343 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_oof changed from NULL to 0
2020-03-02 23:56:08.346 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node21' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.352 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node23' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.358 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node36' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.363 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.372 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.377 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node11' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.380 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node31' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.383 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.389 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-03-02 23:56:08.415 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_cse changed from NULL to 0
2020-03-02 23:56:08.418 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:6fa78702' has been updated.
2020-03-02 23:56:09.724 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 12 to 13
2020-03-02 23:56:09.753 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 11 to 12
2020-03-02 23:56:09.770 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 13 to 14
2020-03-02 23:56:09.844 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 12 to 13
2020-03-02 23:56:09.849 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 14 to 15
2020-03-02 23:56:09.856 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node31' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:09.904 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node19' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:09.943 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 13 to 14
2020-03-02 23:56:09.949 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 15 to 16
2020-03-02 23:56:09.975 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node32' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:09.996 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 14 to 15
2020-03-02 23:56:09.999 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 16 to 17
2020-03-02 23:56:10.053 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node36' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:10.093 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 15 to 16
2020-03-02 23:56:10.095 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 17 to 18
2020-03-02 23:56:10.154 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 16 to 17
2020-03-02 23:56:10.156 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node22' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:10.183 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 18 to 19
2020-03-02 23:56:10.227 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:10.247 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 17 to 18
2020-03-02 23:56:10.249 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 19 to 20
2020-03-02 23:56:10.304 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node23' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:10.317 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 18 to 19
2020-03-02 23:56:10.327 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 20 to 21
2020-03-02 23:56:10.377 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:10.426 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 19 to 20
2020-03-02 23:56:10.431 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 21 to 22
2020-03-02 23:56:10.487 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:10.511 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 20 to 21
2020-03-02 23:56:10.536 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 22 to 23
2020-03-02 23:56:10.562 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:10.602 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 21 to 22
2020-03-02 23:56:10.609 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 23 to 24
2020-03-02 23:56:10.706 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 22 to 23
2020-03-02 23:56:10.710 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 24 to 25
2020-03-02 23:56:10.729 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 23 to 24
2020-03-02 23:56:10.731 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 25 to 26
2020-03-02 23:56:10.750 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:10.787 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 24 to 25
2020-03-02 23:56:10.809 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 26 to 27
2020-03-02 23:56:11.012 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 25 to 26
2020-03-02 23:56:11.022 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:11.043 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 27 to 28
2020-03-02 23:56:11.053 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:11.086 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 26 to 27
2020-03-02 23:56:11.088 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 28 to 29
2020-03-02 23:56:11.109 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node29' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:11.119 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 27 to 28
2020-03-02 23:56:11.126 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 29 to 30
2020-03-02 23:56:11.174 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:11.181 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 28 to 29
2020-03-02 23:56:11.183 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 30 to 31
2020-03-02 23:56:11.237 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node20' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:11.250 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 29 to 30
2020-03-02 23:56:11.260 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 31 to 32
2020-03-02 23:56:11.284 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node12' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:11.346 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 30 to 31
2020-03-02 23:56:11.387 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 32 to 33
2020-03-02 23:56:11.404 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:11.413 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 31 to 32
2020-03-02 23:56:11.419 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 33 to 34
2020-03-02 23:56:11.450 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node21' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:11.592 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 32 to 33
2020-03-02 23:56:11.649 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node9' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:11.658 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 34 to 35
2020-03-02 23:56:11.670 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 33 to 34
2020-03-02 23:56:11.694 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 35 to 36
2020-03-02 23:56:11.704 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node11' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:11.769 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-03-02 23:56:11.773 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 34 to 35
2020-03-02 23:56:11.780 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 36 to 37
2020-03-02 23:56:11.785 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 35 to 36
2020-03-02 23:56:11.821 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 37 to 38
2020-03-02 23:56:11.824 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 36 to 37
2020-03-02 23:56:11.832 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 38 to 39
2020-03-02 23:56:11.899 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 37 to 38
2020-03-02 23:56:11.901 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node37' changed from ONLINE to ONLINE: Node initialising: PING
2020-03-02 23:56:12.117 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 39 to 40
2020-03-02 23:56:17.199 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 40 to 41
2020-03-02 23:56:17.254 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 38 to 39
2020-03-02 23:56:17.322 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 41 to 42
2020-03-02 23:56:21.976 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 42 to 43
2020-03-02 23:56:22.011 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 39 to 40
2020-03-02 23:56:22.139 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 43 to 44
2020-03-02 23:56:26.812 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 44 to 45
2020-03-02 23:56:26.849 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 40 to 41
2020-03-02 23:56:26.918 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 45 to 46
2020-03-02 23:56:31.746 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 46 to 47
2020-03-02 23:56:31.766 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node19' changed from ONLINE: Node initialising: REQUEST_NIF to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
2020-03-02 23:56:31.792 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 41 to 42
2020-03-02 23:56:31.854 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 47 to 48
2020-03-02 23:56:36.119 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 48 to 49
2020-03-02 23:56:36.152 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 42 to 43
2020-03-02 23:56:36.221 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 49 to 50
2020-03-02 23:56:37.161 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:56:37.221 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node14' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.228 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:56:37.269 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node16' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.273 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.324 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node30' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.329 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node21' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.369 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node21' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.374 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node23' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:56:37.415 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node23' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.419 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.459 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.463 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node19' changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to UNINITIALIZED
2020-03-02 23:56:37.502 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node19' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.506 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:56:37.545 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node33' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.549 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.605 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.611 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.678 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node35' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.682 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.723 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node29' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.726 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.771 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node29' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.775 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node37' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.820 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node37' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.826 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:56:37.865 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node18' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.870 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-02 23:56:37.910 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-02 23:56:37.913 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node22' changed from ONLINE: Node initialising: REQUEST_NIF to UNINITIALIZED
2020-03-02 23:56:38.053 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node22' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
[snip]
Any suggestsion on where to go from here?
I’ve done a few reboots (nicely shutting down OH first), as well as some cache clears (with permission resetting)
Thanks!
Edit:
With a bit more looking, I think I was able to get a glimpse of some relevant details for this from the logs. I just don’t fully know how to interpret it. (the mail error is known - I couldn’t recall how I had the mail service set up before, so I’ve shelved getting it working for now)
2020-03-03 00:06:37.583 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node24' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-03 00:06:37.586 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node36' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-03 00:06:37.631 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node36' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-03 00:06:37.638 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-03 00:06:37.673 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node10' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-03 00:06:37.676 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-03 00:06:37.713 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node34' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-03 00:06:37.717 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from ONLINE: Node initialising: PING to UNINITIALIZED
2020-03-03 00:06:37.759 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-03 00:06:37.763 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from ONLINE to UNINITIALIZED
2020-03-03 00:06:37.973 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-03-03 00:06:40.371 [INFO ] [internal.service.FeaturesServiceImpl] -   org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0
2020-03-03 00:06:40.444 [INFO ] [internal.service.FeaturesServiceImpl] -   org.openhab.core.io.transport.serial/2.5.0
2020-03-03 00:06:40.557 [INFO ] [internal.service.FeaturesServiceImpl] -   org.openhab.core.io.transport.serial.rxtx/2.5.0
2020-03-03 00:06:40.685 [INFO ] [internal.service.FeaturesServiceImpl] - Refreshing bundles:
2020-03-03 00:06:40.688 [INFO ] [internal.service.FeaturesServiceImpl] -     org.openhab.binding.zwave/2.5.2 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.binding.zwave/2.5.2] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)"))
2020-03-03 00:06:40.690 [INFO ] [internal.service.FeaturesServiceImpl] -     org.openhab.core.config.serial/2.5.0 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.core.config.serial/2.5.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)(version>=2.5.0)(!(version>=3.0.0)))"))
2020-03-03 00:06:40.692 [INFO ] [internal.service.FeaturesServiceImpl] -     org.openhab.core.io.transport.serial/2.5.0 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.core.io.transport.serial/2.5.0] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)"))
2020-03-03 00:06:40.695 [INFO ] [internal.service.FeaturesServiceImpl] -     org.openhab.core.io.transport.serial.rxtx/2.5.0 (Wired to org.openhab.core.io.transport.serial/2.5.0 which is being refreshed)
2020-03-03 00:06:40.697 [INFO ] [internal.service.FeaturesServiceImpl] -     org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0 (Wired to org.openhab.core.io.transport.serial/2.5.0 which is being refreshed)
2020-03-03 00:06:41.027 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_102_latency changed from 187.0 to 226.0
2020-03-03 00:06:41.030 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 226.0
2020-03-03 00:06:41.367 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_102_lastseen changed from 2020-03-03T00:05:40.764-0800 to 2020-03-03T00:06:41.344-0800
2020-03-03 00:06:41.368 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583222801344
2020-03-03 00:06:41.450 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
2020-03-03 00:06:41.458 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-action-mail'
2020-03-03 00:06:45.153 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_112_latency changed from 20.0 to 21.0
2020-03-03 00:06:45.156 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 21.0
2020-03-03 00:06:45.620 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583222805604
2020-03-03 00:06:45.626 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_112_lastseen changed from 2020-03-03T00:05:45.104-0800 to 2020-03-03T00:06:45.604-0800
2020-03-03 00:06:50.199 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-03-03 00:06:50.397 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-03-03 00:06:50.415 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:6fa78702' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-03 00:06:50.489 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node29' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
[snip for length]
2020-03-03 00:06:50.982 [hingStatusInfoChangedEvent] - 'zwave:device:6fa78702:node6' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-03-03 00:06:54.603 [vent.ItemStateChangedEvent] - network_pingdevice_04df95fd_online changed from ON to OFF
2020-03-03 00:06:54.606 [vent.ItemStateChangedEvent] - network_pingdevice_04df95fd_latency changed from 1621.0 to UNDEF
2020-03-03 00:06:54.609 [DEBUG] [.internal.InfluxDBPersistenceService] - got OnOffType value 0
2020-03-03 00:06:55.469 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_sof changed from 70 to 0
2020-03-03 00:06:55.471 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 0
2020-03-03 00:06:55.479 [vent.ItemStateChangedEvent] - zwave_serial_zstick_6fa78702_serial_ack changed from 53 to 0
2020-03-03 00:06:55.484 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 0
2020-03-03 00:06:55.531 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-03-03 00:06:55.533 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-03-03 00:06:58.625 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1
You likely have an invalid addon defined in addons.config down in the userdata tree. restdocs is a common culprit since it move in 2.5 from misc to ui. Shit down OH before editing the file though.
An invalid addon causes all addons to be reloaded every minute in an attempt to load the invalid one.
Yep!
This is likely the cause of the problem. You need to remove this addon.
OK, I’ve done this, and removed the mail line in addons.config. (I had been inadvertently looking in addons.cfg for a bit).
I no longer get this error.
I’ve cleared the cache/restarted a few times.
My z-wave devices were acting odd, so I wanted to start fresh. I have been unable to delete the zwave things in paperui. It took a couple attempts, and eventually I discovered that while I couldn’t delete them from paperui, I could delete them from habmin. I deleted the z-wave controller and all the things (but didn’t exclude them). I cleared the cache again, then added the controller back, and added a single thing (the closest item to the z-wave controller) - a dimmer, node35.
The thing seemed to be added correctly, and dispays as online. Adjusting this value, however, doesn’t change the state of the switch, and changing the state of the switch doesn’t result in a changed value in paperui or the logs.
I did have a prolonged period of time (several weeks) with no active controller on this network, and am wondering if this may play a role (end devices forgetting the controller, etc). I really don’t want to have to exclude and re-include all my z-wave devices, so would like some input before trying this.
I assume the reason OpenHab 2.52 was able to discover the z-wave devices after deleting them all was that they were stored on the RaZberry hat controller - meaning it wasn’t an indication that the physical switch was again discovered. The fact that it displayed as online, however, makes it seem that there was a response from the switch.
A snip from my logs starts with me changing the dimmer (node35) to 100% in paperui. I then change it to zero, and go to the actual switch, turn it on and off, then set it to apprx 50%. This switch toggling isn’t seen in the logs at all.
2020-03-04 13:53:54.792 [ome.event.ItemCommandEvent] - Item 'zwave_device_9a619d6d_node35_switch_dimmer' received command 100
2020-03-04 13:53:54.794 [nt.ItemStatePredictedEvent] - zwave_device_9a619d6d_node35_switch_dimmer predicted to become 100
2020-03-04 13:53:54.813 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 100
2020-03-04 13:53:54.815 [vent.ItemStateChangedEvent] - zwave_device_9a619d6d_node35_switch_dimmer changed from 0.0 to 100
2020-03-04 13:53:54.826 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1259 to 1260
2020-03-04 13:53:54.828 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1260
2020-03-04 13:53:55.198 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1770
2020-03-04 13:53:55.198 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1769 to 1770
2020-03-04 13:54:00.228 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1260 to 1261
2020-03-04 13:54:00.229 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1261
2020-03-04 13:54:01.926 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1770 to 1771
2020-03-04 13:54:01.929 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1771
2020-03-04 13:54:01.988 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1262
2020-03-04 13:54:01.991 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1261 to 1262
2020-03-04 13:54:02.289 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1771 to 1772
2020-03-04 13:54:02.290 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1772
2020-03-04 13:54:05.923 [vent.ItemStateChangedEvent] - network_servicedevice_192_168_0_132_80_latency changed from 80.0 to 4.0
2020-03-04 13:54:05.928 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 4.0
2020-03-04 13:54:05.948 [vent.ItemStateChangedEvent] - network_servicedevice_192_168_0_132_80_lastseen changed from 2020-03-04T13:53:05.898-0800 to 2020-03-04T13:54:05.910-0800
2020-03-04 13:54:05.951 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583358845910
2020-03-04 13:54:06.284 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 31.0
2020-03-04 13:54:06.288 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_112_latency changed from 12.0 to 31.0
2020-03-04 13:54:06.687 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583358846661
2020-03-04 13:54:06.691 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_112_lastseen changed from 2020-03-04T13:53:06.225-0800 to 2020-03-04T13:54:06.661-0800
2020-03-04 13:54:07.317 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1262 to 1263
2020-03-04 13:54:07.317 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1263
2020-03-04 13:54:09.102 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1773
2020-03-04 13:54:09.107 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1772 to 1773
2020-03-04 13:54:09.138 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1263 to 1264
2020-03-04 13:54:09.140 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1264
2020-03-04 13:54:09.442 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1773 to 1774
2020-03-04 13:54:09.443 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1774
2020-03-04 13:54:14.470 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1264 to 1265
2020-03-04 13:54:14.473 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1265
2020-03-04 13:54:16.223 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1775
2020-03-04 13:54:16.223 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1774 to 1775
2020-03-04 13:54:16.268 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1266
2020-03-04 13:54:16.269 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1265 to 1266
2020-03-04 13:54:16.575 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1775 to 1776
2020-03-04 13:54:16.576 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1776
2020-03-04 13:54:21.613 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1266 to 1267
2020-03-04 13:54:21.617 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1267
2020-03-04 13:54:23.287 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1777
2020-03-04 13:54:23.292 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1776 to 1777
2020-03-04 13:54:23.338 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1267 to 1268
2020-03-04 13:54:23.346 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1268
2020-03-04 13:54:23.644 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1777 to 1778
2020-03-04 13:54:23.646 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1778
2020-03-04 13:54:28.681 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1268 to 1269
2020-03-04 13:54:28.683 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1269
2020-03-04 13:54:30.425 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1778 to 1779
2020-03-04 13:54:30.428 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1779
2020-03-04 13:54:30.482 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1269 to 1270
2020-03-04 13:54:30.485 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1270
2020-03-04 13:54:30.787 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1779 to 1780
2020-03-04 13:54:30.791 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1780
2020-03-04 13:54:35.819 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1270 to 1271
2020-03-04 13:54:35.821 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1271
2020-03-04 13:54:37.533 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1780 to 1781
2020-03-04 13:54:37.536 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1781
2020-03-04 13:54:37.598 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1272
2020-03-04 13:54:37.599 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1271 to 1272
2020-03-04 13:54:37.899 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1781 to 1782
2020-03-04 13:54:37.899 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1782
2020-03-04 13:54:42.226 [vent.ItemStateChangedEvent] - network_pingdevice_04df95fd_latency changed from 498.0 to 4579.0
2020-03-04 13:54:42.229 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 4579.0
2020-03-04 13:54:42.634 [vent.ItemStateChangedEvent] - network_pingdevice_04df95fd_lastseen changed from 2020-03-04T13:53:33.091-0800 to 2020-03-04T13:54:42.211-0800
2020-03-04 13:54:42.640 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583358882211
2020-03-04 13:54:42.930 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1272 to 1273
2020-03-04 13:54:42.976 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1273
2020-03-04 13:54:44.677 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1783
2020-03-04 13:54:44.680 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1782 to 1783
2020-03-04 13:54:44.711 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1273 to 1274
2020-03-04 13:54:44.714 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1274
2020-03-04 13:54:45.022 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1783 to 1784
2020-03-04 13:54:45.027 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1784
2020-03-04 13:54:46.571 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_102_latency changed from 833.0 to 223.0
2020-03-04 13:54:46.575 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 223.0
2020-03-04 13:54:46.930 [vent.ItemStateChangedEvent] - network_pingdevice_192_168_0_102_lastseen changed from 2020-03-04T13:53:42.062-0800 to 2020-03-04T13:54:46.901-0800
2020-03-04 13:54:46.937 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583358886901
2020-03-04 13:54:49.036 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 2.0
2020-03-04 13:54:49.040 [vent.ItemStateChangedEvent] - network_servicedevice_192_168_0_1_80_latency changed from 1.0 to 2.0
2020-03-04 13:54:49.046 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583358889028
2020-03-04 13:54:49.049 [vent.ItemStateChangedEvent] - network_servicedevice_192_168_0_1_80_lastseen changed from 2020-03-04T13:53:49.002-0800 to 2020-03-04T13:54:49.028-0800
2020-03-04 13:54:49.342 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 7.0
2020-03-04 13:54:49.342 [vent.ItemStateChangedEvent] - network_servicedevice_192_168_0_186_80_latency changed from 2.0 to 7.0
2020-03-04 13:54:49.347 [vent.ItemStateChangedEvent] - network_servicedevice_192_168_0_186_80_lastseen changed from 2020-03-04T13:53:49.310-0800 to 2020-03-04T13:54:49.330-0800
2020-03-04 13:54:49.356 [DEBUG] [.internal.InfluxDBPersistenceService] - got DateTimeType value 1583358889330
2020-03-04 13:54:50.054 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1275
2020-03-04 13:54:50.058 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1274 to 1275
2020-03-04 13:54:51.828 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1784 to 1785
2020-03-04 13:54:51.830 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1785
2020-03-04 13:54:51.860 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1275 to 1276
2020-03-04 13:54:51.862 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1276
2020-03-04 13:54:52.169 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1785 to 1786
2020-03-04 13:54:52.169 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1786
2020-03-04 13:54:57.202 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1276 to 1277
2020-03-04 13:54:57.205 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1277
2020-03-04 13:54:58.934 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1786 to 1787
2020-03-04 13:54:58.935 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1787
2020-03-04 13:54:58.976 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_ack changed from 1277 to 1278
2020-03-04 13:54:58.981 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1278
2020-03-04 13:54:59.288 [vent.ItemStateChangedEvent] - zwave_serial_zstick_9a619d6d_serial_sof changed from 1787 to 1788
2020-03-04 13:54:59.291 [DEBUG] [.internal.InfluxDBPersistenceService] - got DecimalType value 1788
Any thoughts on how to further deug or fix this?
Do I need to bite the bullet and exclude/include all the devices? (which I think involves adding the devices again via openhab paperui/habmin, then excluding each one via habmin and the exclusion instructions for each device while holding a battery-powered pi close to the device, then resetting the end device per manufacterers instructions, then re-including them)
