Hello
after I could install the astro binding successful with your help, I have another problem.
In initial startup I have chosen Standard instead of expert.
Now I want to install Z-Wave Functions and I need the expert modus with HAB admin function.
How can I start in the expert modus instead of standard?
Thank you
Bernd Langgner
Standard just specifies what initial addons get installed for you. There is not separate mode. To use HABmin you need to install it. It is listed under UIs in PaperUI’s addons menu. Once installed, when you browse to http://openhabserver:8080 it will be listed alongside PaperUI and the other UIs you have installed (probably BasicUI).
