i try to include a qubino flush dimmer but it is included as unkonown. I am a litte confused because another one is working fine and is fully included.
The only differences I can find ist the labeling on the devices:
Working one: Qubino, Flush Dimmer, ZMNHDD1 H1S3P5
Not Working One: Qubino, Flush Dimmer, ZMNHDD1 H1S4P5
Do I need to update the z-wave Database because my device is a new version and is it still not in the Database?
i can change the Database on the Webpage: https://www.cd-jackson.com and I need a log in and after that an access to the Database. that´s what i´ve understood so far.
And for my understanding: does the Z-wave binding use an online Database? so will I need access to the www for including a new device because of the fact that the including Process does use an online Database?
and which information do I need to update the Flush Dimmer in the Database, I have only the Information out oft the XML File. But I think I need other information.
Working one:
homeid 0xe2cce480
nodeId 7
version 4
manufacture 0x159
deviceId 0x51
devicetype 0x1
Not working one:
homeid 0xe2cce480
nodeId 10
version 4
manufacture 0x7fffffff
deviceId 0x7fffffff
devicetype 0x7fffffff
how does the z-wave binding syndicate the information oft the device and the Database.
And where do I get the infomation for including the new version into the Database
No, the database is compiled into the zwave binding jar file.
You need the xml file and the device manual.
It’s not a new version, it is just not yet recognized.
means the device did not send any data (or the controller did not receive any data).
Maybe that is a range issue or you did not include the device properly.
As soon as you have valid data for manufacturer, device type and device id and it is still unknown you need to check the database it the device is present.
As you can see the device does not work, it gets timeouts, probably because:
that won’t work: if the device is not sending data and no xml file is generated after inclusion/initialization, you are out of luck.
Also please make sure you are on a recent 2.5 zwave snapshot binding.
From the short log I see above, the device is simply not responding - there are NO responses from the device at all.
Either there is a range issue (you say not), or maybe the device has not included properly - either way, it is not communicating and it should be reset (ie excluded) and reincluded.
