i have a problem with my zstick (Black Aeon Labs USB Z-Stick, so not the last versione).
The sticks stop works correctly (doesn’t respond) then i need to disconnct and reconnect the usb stick; i have the same problem on 2 different computer with 2 different Windows operative system.
Reboot isn’t enough.
This is the zwave debug:
2016-01-24 02:46:55.372 [DEBUG] [.zwave.internal.ZWaveActivator:36 ]- Z-Wave binding started. Version 1.8.0.201508211938
2016-01-24 02:46:55.624 [DEBUG] [.z.internal.ZWaveActiveBinding:175 ]- ConverterHandler not initialised. Polling disabled.
2016-01-24 02:46:55.626 [INFO ] [.z.internal.ZWaveActiveBinding:325 ]- Update config, port = COM3
2016-01-24 02:46:55.626 [INFO ] [.z.internal.ZWaveActiveBinding:330 ]- Update config, healtime = 2
2016-01-24 02:46:55.626 [DEBUG] [.z.internal.ZWaveActiveBinding:282 ]- Initialising zwave binding
2016-01-24 02:46:55.655 [INFO ] [b.z.i.protocol.ZWaveController:146 ]- Starting Z-Wave controller
2016-01-24 02:46:55.655 [INFO ] [b.z.i.protocol.ZWaveController:154 ]- Z-Wave timeout is set to 5000ms. Soft reset is false.
2016-01-24 02:46:55.656 [INFO ] [b.z.i.protocol.ZWaveController:320 ]- Connecting to serial port COM3
2016-01-24 02:46:56.094 [INFO ] [b.z.i.protocol.ZWaveController:340 ]- Serial port is initialized
2016-01-24 02:46:56.124 [DEBUG] [eController$ZWaveReceiveThread:1373]- Starting Z-Wave thread: Receive
2016-01-24 02:46:56.125 [DEBUG] [b.z.i.protocol.ZWaveController:1114]- Starting Z-Wave thread: Input
2016-01-24 02:46:56.125 [DEBUG] [WaveController$ZWaveSendThread:1157]- Starting Z-Wave thread: Send
2016-01-24 02:46:59.096 [DEBUG] [veController$WatchDogTimerTask:176 ]- Initialising network
2016-01-24 02:46:59.105 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 255: Creating empty message of class = GetVersion (0x15), type = Request (0x00)
2016-01-24 02:46:59.105 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 1
2016-01-24 02:46:59.105 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 0
2016-01-24 02:46:59.106 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 255: Creating empty message of class = MemoryGetId (0x20), type = Request (0x00)
2016-01-24 02:46:59.107 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 1
2016-01-24 02:46:59.108 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 255: Creating empty message of class = SerialApiGetCapabilities (0x07), type = Request (0x00)
2016-01-24 02:46:59.108 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 2
2016-01-24 02:46:59.109 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 255: Creating empty message of class = SerialApiSetTimeouts (0x06), type = Request (0x00)
2016-01-24 02:46:59.109 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 3
2016-01-24 02:46:59.110 [DEBUG] [i.p.s.GetSucNodeIdMessageClass:30 ]- Get SUC NodeID
2016-01-24 02:46:59.111 [DEBUG] [o.b.z.i.protocol.SerialMessage:109 ]- NODE 255: Creating empty message of class = GetSucNodeId (0x56), type = Request (0x00)
2016-01-24 02:46:59.111 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 4
2016-01-24 02:46:59.106 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 15 E9
2016-01-24 02:46:59.114 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-01-24 02:47:00.631 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 4 - deferring network monitor functions.
2016-01-24 02:47:04.122 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-01-24 02:47:04.122 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 5
2016-01-24 02:47:04.123 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 4
2016-01-24 02:47:04.123 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 15 E9
2016-01-24 02:47:04.124 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-01-24 02:47:05.631 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 4 - deferring network monitor functions.
2016-01-24 02:47:09.125 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-01-24 02:47:09.125 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 5
2016-01-24 02:47:09.125 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 4
2016-01-24 02:47:09.126 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 15 E9
2016-01-24 02:47:09.127 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-01-24 02:47:10.632 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 4 - deferring network monitor functions.
2016-01-24 02:47:14.128 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-01-24 02:47:14.128 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 5
2016-01-24 02:47:14.128 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 4
2016-01-24 02:47:14.129 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 15 E9
2016-01-24 02:47:14.129 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-01-24 02:47:15.633 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 4 - deferring network monitor functions.
2016-01-24 02:47:19.131 [WARN ] [WaveController$ZWaveSendThread:1278]- NODE 255: Too many retries. Discarding message: Message: class = GetVersion (0x15), type = Request (0x00), payload =
2016-01-24 02:47:19.132 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 3
2016-01-24 02:47:19.132 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 20 DC
2016-01-24 02:47:19.133 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-01-24 02:47:20.634 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 3 - deferring network monitor functions.
2016-01-24 02:47:24.134 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-01-24 02:47:24.134 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 4
2016-01-24 02:47:24.134 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 3
2016-01-24 02:47:24.135 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 20 DC
2016-01-24 02:47:24.136 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-01-24 02:47:25.640 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 3 - deferring network monitor functions.
2016-01-24 02:47:29.138 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-01-24 02:47:29.138 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 4
2016-01-24 02:47:29.138 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 3
2016-01-24 02:47:29.139 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 20 DC
2016-01-24 02:47:29.139 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-01-24 02:47:30.641 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 3 - deferring network monitor functions.
2016-01-24 02:47:34.141 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-01-24 02:47:34.141 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 4
2016-01-24 02:47:34.141 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 3
2016-01-24 02:47:34.142 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 20 DC
2016-01-24 02:47:34.142 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-01-24 02:47:35.641 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 3 - deferring network monitor functions.
2016-01-24 02:47:39.144 [WARN ] [WaveController$ZWaveSendThread:1278]- NODE 255: Too many retries. Discarding message: Message: class = MemoryGetId (0x20), type = Request (0x00), payload =
2016-01-24 02:47:39.144 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 2
2016-01-24 02:47:39.145 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 07 FB
2016-01-24 02:47:39.146 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-01-24 02:47:40.641 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 2 - deferring network monitor functions.
2016-01-24 02:47:44.147 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-01-24 02:47:44.147 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 3
2016-01-24 02:47:44.147 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 2
2016-01-24 02:47:44.148 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 07 FB
2016-01-24 02:47:44.148 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-01-24 02:47:45.642 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 2 - deferring network monitor functions.
2016-01-24 02:47:49.151 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-01-24 02:47:49.151 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 3
2016-01-24 02:47:49.151 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 2
2016-01-24 02:47:49.152 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 07 FB
2016-01-24 02:47:49.152 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-01-24 02:47:50.643 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 2 - deferring network monitor functions.
2016-01-24 02:47:54.154 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-01-24 02:47:54.154 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 3
2016-01-24 02:47:54.154 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 2
2016-01-24 02:47:54.155 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 03 00 07 FB
2016-01-24 02:47:54.155 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-01-24 02:47:55.643 [DEBUG] [z.internal.ZWaveNetworkMonitor:315 ]- Network Monitor: Queue length is 2 - deferring network monitor functions.
2016-01-24 02:47:59.156 [WARN ] [WaveController$ZWaveSendThread:1278]- NODE 255: Too many retries. Discarding message: Message: class = SerialApiGetCapabilities (0x07), type = Request (0x00), payload =
2016-01-24 02:47:59.156 [DEBUG] [WaveController$ZWaveSendThread:1171]- Took message from queue for sending. Queue length = 1
2016-01-24 02:47:59.157 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 05 00 06 96 0F 65
2016-01-24 02:47:59.157 [DEBUG] [WaveController$ZWaveSendThread:1228]- NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2016-01-24 02:48:04.159 [ERROR] [WaveController$ZWaveSendThread:1269]- NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-01-24 02:48:04.159 [DEBUG] [b.z.i.protocol.ZWaveController:580 ]- Enqueueing message. Queue length = 2
Thanks in advance
