hi,
i am new to OH2. Currently, trying out to replace my vera but i had encounter some issues.
I am running OH2 on RPI2 with aeon labs z-stick s2. I had already finish the inclusion for fibaro FGS-221 to the z-stick.
However, in the paperui, its status show
OFFLINE - COMMUNICATION_ERROR Node is not communicating with controller
But when i tried turning on the lights, Its show online
2017-01-22 20:50:58.367 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 06 07 60 0D 02 02 25 03 FF 43
2017-01-22 20:50:58.370 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:58.373 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 04 00 06 07 60 0D 02 02 25 03 FF 43
2017-01-22 20:50:58.376 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 00 06 07 60 0D 02 02 25 03 FF 43
2017-01-22 20:50:58.379 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 07 60 0D 02 02 25 03 FF
2017-01-22 20:50:58.380 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Application Command Request (DEAD:DYNAMIC_VALUES)
2017-01-22 20:50:58.382 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Node is ALIVE. Init stage is DYNAMIC_VALUES.
2017-01-22 20:50:58.383 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
2017-01-22 20:50:58.384 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node Status event during initialisation - Node is ALIVE
2017-01-22 20:50:58.386 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: queue length(2), free to send(false)
2017-01-22 20:50:58.387 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Initialisation retry timer started 10000
2017-01-22 20:50:58.388 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - queued packet. Queue length is 2
2017-01-22 20:50:58.390 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-01-22 20:50:58.390 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-01-22 20:50:58.391 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2017-01-22 20:50:58.392 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 06 02 73 02 25 39 8C
2017-01-22 20:50:58.393 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Setting ONLINE
2017-01-22 20:50:58.394 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 09 00 13 06 02 73 02 25 39 8C
2017-01-22 20:50:58.398 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 6: Node Status event - Node is ALIVE
2017-01-22 20:50:58.400 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Incoming command class MULTI_INSTANCE
2017-01-22 20:50:58.402 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Received MULTI_INSTANCE command V2
2017-01-22 20:50:58.404 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Requested Command Class = SWITCH_BINARY (0x25)
2017-01-22 20:50:58.406 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Endpoint = 2, calling handleApplicationCommandRequest.
2017-01-22 20:50:58.407 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - Received Switch Binary Request for Node ID = 6
2017-01-22 20:50:58.408 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Switch Binary report, value = 255
2017-01-22 20:50:58.410 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-01-22 20:50:58.411 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-01-22 20:50:58.413 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint = 2, command class = SWITCH_BINARY, value = 255
2017-01-22 20:50:58.415 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Updating channel state zwave:device:8c194533:node6:switch_binary2 to ON [OnOffType]
2017-01-22 20:50:58.416 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 8: Transaction not completed: node address inconsistent. lastSent=8, incoming=255
2017-01-22 20:50:58.423 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-01-22 20:50:58.425 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:58.427 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-01-22 20:50:58.429 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-01-22 20:50:58.431 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-01-22 20:50:58.433 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: Sent Data successfully placed on stack.
2017-01-22 20:50:58.702 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 06 07 60 0D 02 02 25 03 00 BC
2017-01-22 20:50:58.705 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:58.706 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 04 00 06 07 60 0D 02 02 25 03 00 BC
2017-01-22 20:50:58.708 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0D 00 04 00 06 07 60 0D 02 02 25 03 00 BC
2017-01-22 20:50:58.709 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 07 60 0D 02 02 25 03 00
2017-01-22 20:50:58.710 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Application Command Request (ALIVE:DYNAMIC_VALUES)
2017-01-22 20:50:58.711 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 6: Incoming command class MULTI_INSTANCE
2017-01-22 20:50:58.712 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Received MULTI_INSTANCE command V2
2017-01-22 20:50:58.713 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Requested Command Class = SWITCH_BINARY (0x25)
2017-01-22 20:50:58.714 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Endpoint = 2, calling handleApplicationCommandRequest.
2017-01-22 20:50:58.715 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - Received Switch Binary Request for Node ID = 6
2017-01-22 20:50:58.716 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Switch Binary report, value = 0
2017-01-22 20:50:58.717 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-01-22 20:50:58.718 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-01-22 20:50:58.719 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint = 2, command class = SWITCH_BINARY, value = 0
2017-01-22 20:50:58.720 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Updating channel state zwave:device:8c194533:node6:switch_binary2 to OFF [OnOffType]
2017-01-22 20:50:58.722 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=6, callback=57, payload=06 02 73 02
2017-01-22 20:50:58.724 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 06 07 60 0D 02 02 25 03 00
2017-01-22 20:50:58.725 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=57, expected=ApplicationCommandHandler, cancelled=false transaction complete!
2017-01-22 20:50:58.726 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-01-22 20:50:58.727 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(true)
2017-01-22 20:50:58.727 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - checking initialisation queue. Queue size 2.
2017-01-22 20:50:58.728 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - message removed from queue. Queue size 1.
2017-01-22 20:50:58.729 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: queue length(1), free to send(true)
2017-01-22 20:50:58.729 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Initialisation retry timer started 10000
2017-01-22 20:50:58.730 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - queued packet. Queue length is 1
2017-01-22 20:50:58.731 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-01-22 20:50:58.732 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-01-22 20:50:58.733 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Response processed after 338ms/542ms.
2017-01-22 20:50:58.733 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-01-22 20:50:58.735 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 06 06 60 0D 01 01 25 02 25 3A B4
2017-01-22 20:50:58.736 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0D 00 13 06 06 60 0D 01 01 25 02 25 3A B4
2017-01-22 20:50:58.764 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-01-22 20:50:58.766 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:58.767 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-01-22 20:50:58.768 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-01-22 20:50:58.769 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-01-22 20:50:58.770 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: Sent Data successfully placed on stack.
2017-01-22 20:50:58.873 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 3A 01 D2
2017-01-22 20:50:58.875 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:58.876 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 13 3A 01 00 00 D0
2017-01-22 20:50:58.877 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 13 3A 01 00 00 D0
2017-01-22 20:50:58.878 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3A 01
2017-01-22 20:50:58.879 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 58, Status = Transmission complete, no ACK received(1)
2017-01-22 20:50:58.880 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2017-01-22 20:50:58.880 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-01-22 20:50:58.881 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-01-22 20:50:58.882 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(false)
2017-01-22 20:50:58.882 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-01-22 20:50:58.883 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Response processed after 145ms/542ms.
2017-01-22 20:50:58.884 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-01-22 20:50:58.886 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 06 06 60 0D 01 01 25 02 25 3B B5
2017-01-22 20:50:58.887 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0D 00 13 06 06 60 0D 01 01 25 02 25 3B B5
2017-01-22 20:50:58.915 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-01-22 20:50:58.917 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:58.918 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-01-22 20:50:58.919 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-01-22 20:50:58.920 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-01-22 20:50:58.921 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: Sent Data successfully placed on stack.
2017-01-22 20:50:59.221 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 3B 01 D3
2017-01-22 20:50:59.223 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:59.225 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 13 3B 01 00 00 D1
2017-01-22 20:50:59.226 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 13 3B 01 00 00 D1
2017-01-22 20:50:59.227 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3B 01
2017-01-22 20:50:59.228 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 59, Status = Transmission complete, no ACK received(1)
2017-01-22 20:50:59.229 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2017-01-22 20:50:59.229 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-01-22 20:50:59.230 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-01-22 20:50:59.241 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(false)
2017-01-22 20:50:59.244 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-01-22 20:50:59.245 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Response processed after 356ms/542ms.
2017-01-22 20:50:59.245 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-01-22 20:50:59.247 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 06 06 60 0D 01 01 25 02 25 3C B2
2017-01-22 20:50:59.248 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0D 00 13 06 06 60 0D 01 01 25 02 25 3C B2
2017-01-22 20:50:59.276 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-01-22 20:50:59.277 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:59.279 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-01-22 20:50:59.280 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-01-22 20:50:59.281 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-01-22 20:50:59.282 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: Sent Data successfully placed on stack.
2017-01-22 20:50:59.489 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 3C 01 D4
2017-01-22 20:50:59.490 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:59.492 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 13 3C 01 00 00 D6
2017-01-22 20:50:59.493 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 13 3C 01 00 00 D6
2017-01-22 20:50:59.495 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3C 01
2017-01-22 20:50:59.495 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 60, Status = Transmission complete, no ACK received(1)
2017-01-22 20:50:59.497 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Node is DEAD.
2017-01-22 20:50:59.497 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
2017-01-22 20:50:59.498 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node Status event during initialisation - Node is DEAD
2017-01-22 20:50:59.499 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2017-01-22 20:50:59.499 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Setting OFFLINE
2017-01-22 20:50:59.503 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 6: Node Status event - Node is DEAD
2017-01-22 20:50:59.504 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-01-22 20:50:59.505 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-01-22 20:50:59.506 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(false)
2017-01-22 20:50:59.506 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-01-22 20:50:59.507 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Response processed after 258ms/542ms.
2017-01-22 20:50:59.919 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 3C 01 D4
2017-01-22 20:50:59.921 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:50:59.923 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 13 3C 01 00 00 D6
2017-01-22 20:50:59.925 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 13 3C 01 00 00 D6
2017-01-22 20:50:59.928 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3C 01
2017-01-22 20:50:59.929 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 60, Status = Transmission complete, no ACK received(1)
2017-01-22 20:50:59.930 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-01-22 20:50:59.931 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-01-22 20:50:59.932 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(false)
2017-01-22 20:50:59.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-01-22 20:51:08.729 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Stage DYNAMIC_VALUES. Initialisation retry timer triggered. Increased to 20000
2017-01-22 20:51:08.730 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: queue length(0), free to send(false)
2017-01-22 20:51:08.731 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Initialisation retry timer started 20000
2017-01-22 20:51:08.732 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: loop - DYNAMIC_VALUES try 2: stageAdvanced(false)
2017-01-22 20:51:08.733 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
2017-01-22 20:51:08.734 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking FIRMWARE_UPDATE_MD
2017-01-22 20:51:08.734 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_ALL
2017-01-22 20:51:08.735 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION
2017-01-22 20:51:08.736 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking MULTI_INSTANCE_ASSOCIATION
2017-01-22 20:51:08.736 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
2017-01-22 20:51:08.737 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking BASIC
2017-01-22 20:51:08.738 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
2017-01-22 20:51:08.738 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking POWERLEVEL
2017-01-22 20:51:08.739 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found POWERLEVEL
2017-01-22 20:51:08.739 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Found 1 instances of POWERLEVEL
2017-01-22 20:51:08.740 [DEBUG] [andclass.ZWavePowerLevelCommandClass] - NODE 6: Creating new message for application command POWERLEVEL_GET
2017-01-22 20:51:08.741 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - queued packet. Queue length is 1
2017-01-22 20:51:08.742 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-01-22 20:51:08.742 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-01-22 20:51:08.743 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking MULTI_INSTANCE
2017-01-22 20:51:08.744 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 1
2017-01-22 20:51:08.744 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 06 02 73 02 25 3D 88
2017-01-22 20:51:08.745 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY for endpoint 1
2017-01-22 20:51:08.745 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
2017-01-22 20:51:08.746 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 09 00 13 06 02 73 02 25 3D 88
2017-01-22 20:51:08.746 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Creating new message for application command SWITCH_BINARY_GET
2017-01-22 20:51:08.747 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Encapsulating message, instance / endpoint 1
2017-01-22 20:51:08.748 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2017-01-22 20:51:08.749 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 2
2017-01-22 20:51:08.750 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY for endpoint 2
2017-01-22 20:51:08.751 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
2017-01-22 20:51:08.752 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY
2017-01-22 20:51:08.753 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
2017-01-22 20:51:08.754 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Found 1 instances of SWITCH_BINARY
2017-01-22 20:51:08.755 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking VERSION
2017-01-22 20:51:08.756 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - queued 2 frames
2017-01-22 20:51:08.774 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-01-22 20:51:08.777 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:51:08.778 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2017-01-22 20:51:08.779 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2017-01-22 20:51:08.780 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2017-01-22 20:51:08.782 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: Sent Data successfully placed on stack.
2017-01-22 20:51:09.242 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 3D 01 D5
2017-01-22 20:51:09.245 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-01-22 20:51:09.246 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 13 3D 01 00 00 D7
2017-01-22 20:51:09.248 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 13 3D 01 00 00 D7
2017-01-22 20:51:09.249 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=3D 01
2017-01-22 20:51:09.250 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 61, Status = Transmission complete, no ACK received(1)
2017-01-22 20:51:09.251 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Node is DEAD. Dropping message.
2017-01-22 20:51:09.251 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-01-22 20:51:09.252 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: Transaction complete (SendData:Request) success(false)
2017-01-22 20:51:09.253 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-01-22 20:51:09.254 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Response processed after 507ms/542ms.
2017-01-22 20:51:28.731 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Stage DYNAMIC_VALUES. Initialisation retry timer triggered. Increased to 40000
2017-01-22 20:51:28.734 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - DYNAMIC_VALUES: queue length(0), free to send(false)
2017-01-22 20:51:28.735 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Initialisation retry timer started 40000
2017-01-22 20:51:28.735 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: loop - DYNAMIC_VALUES try 3: stageAdvanced(false)
2017-01-22 20:51:28.736 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking CONFIGURATION
2017-01-22 20:51:28.737 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking FIRMWARE_UPDATE_MD
2017-01-22 20:51:28.738 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_ALL
2017-01-22 20:51:28.739 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking ASSOCIATION
2017-01-22 20:51:28.740 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking MULTI_INSTANCE_ASSOCIATION
2017-01-22 20:51:28.740 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking NO_OPERATION
2017-01-22 20:51:28.741 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking BASIC
2017-01-22 20:51:28.742 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking MANUFACTURER_SPECIFIC
2017-01-22 20:51:28.743 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking POWERLEVEL
2017-01-22 20:51:28.743 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found POWERLEVEL
2017-01-22 20:51:28.744 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Found 1 instances of POWERLEVEL
2017-01-22 20:51:28.745 [DEBUG] [andclass.ZWavePowerLevelCommandClass] - NODE 6: Creating new message for application command POWERLEVEL_GET
2017-01-22 20:51:28.746 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer - queued packet. Queue length is 1
2017-01-22 20:51:28.748 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2017-01-22 20:51:28.748 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2017-01-22 20:51:28.748 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking MULTI_INSTANCE
2017-01-22 20:51:28.749 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 1
2017-01-22 20:51:28.750 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 06 02 73 02 25 3E 8B
2017-01-22 20:51:28.750 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY for endpoint 1
2017-01-22 20:51:28.751 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
2017-01-22 20:51:28.751 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 09 00 13 06 02 73 02 25 3E 8B
2017-01-22 20:51:28.752 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 6: Creating new message for application command SWITCH_BINARY_GET
2017-01-22 20:51:28.754 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 6: Encapsulating message, instance / endpoint 1
2017-01-22 20:51:28.755 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 6: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2017-01-22 20:51:28.756 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking BASIC for endpoint 2
2017-01-22 20:51:28.756 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY for endpoint 2
2017-01-22 20:51:28.757 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
2017-01-22 20:51:28.757 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking SWITCH_BINARY
2017-01-22 20:51:28.758 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - found SWITCH_BINARY
2017-01-22 20:51:28.759 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Found 1 instances of SWITCH_BINARY
2017-01-22 20:51:28.760 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - checking VERSION
2017-01-22 20:51:28.760 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 6: Node advancer: DYNAMIC_VALUES - queued 2 frames
2017-01-22 20:51:28.781 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2017-01-22 20:51:28.783 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
