i do use the Everspring ST814 Temp/Humidity Z-Wave sensor in my openHAB installation.
The sensor does only once updating his state after the restart of openHAB. When the temperature is changing on the display of the sensor there is no update of the item’s value in openHAB,
In the logfile i only can identify one error but it refers to Node 6 which is a Danfoss LC13 thermostat (Node 5 is the sensor):
the error log of the Danfoss is pretty normal (I do have the same), as the mentioned command class simply isn’t (yet) supported by OpenHAB. The device is nevertheless functional.
When I take a look at the device database (www.cd-jackson.com) for the Everspring device, there is a configuration parameter 7 which indicates, if a temperature change is reported or not. And the default value is “disable”. So you could check if this is the reason?!
Furthermore you could set the log level to DEBUG and see what the device reports.
The defaults shown in the database should be from the manufacturer. The binding doesn’t currently update the configuration, other than to set the wakeup configuration, and association groups that are defined in the database.
This is something I’d like to add to the database, but it’s not quite so simple as there are often multiple ways to configure a device. My goal at some stage in future is to provide a kind of configuration set that can be used depending on the different ways a device can be used, but this will be a little while off…
In the meantime, you need to read the manual and configure the devices - sorry…
The other thing to look at is to make sure that associations are properly configured since this is often the cause of devices not reporting updates.
