I’ve just switched to a new installation with text files on my RPi3.
The Z-Wave-Binding for oH2.4 works fine so far but I’m wondering how to resolve this log entry:
[INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'zwave.things', using it anyway:
Provide a thing type ID and a thing ID in this format:
<thingTypeId> <thingId>
Do you use .thing files for your zwave things? I’ve been told it’s not really possible with the latest stuff, best to allow paper / habmin to create them. I still use .items files for the zwave channels which makes it easy to update if you ever bump a node.
It is possible but has a big disadvantage: you can’t change any device parameters through the GUI anymore. You have to include those into your manual text file.
Yes - you can set thing parameters (ie configuration of openHAB as per your example), but you can’t change device parameters (ie configuration of the Z-Wave device).
