Hello everybody,
I am running openHAB 3.0.2 on a raspi with the Aeotec z-wave stick.
Since yesterday my Z-Wave commands (e.g. switch lights on/off on a FibaroDimmer) do not get processed or take longer that it used to be. NODE 19 is the light dimmer.
Output for Node 19
tail -f -n 1550 /var/log/openhab/openhab.log |grep "NODE 19"
2021-06-01 10:20:08.085 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Commands processed 1.
2021-06-01 10:20:08.086 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1f6651.
2021-06-01 10:20:11.225 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Command received zwave:device:099d457d:node19:switch_dimmer1 --> OFF [OnOffType]
2021-06-01 10:20:11.226 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 19: Creating new message for command SWITCH_MULTILEVEL_SET
2021-06-01 10:20:11.227 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Encapsulating message, instance / endpoint 1
2021-06-01 10:20:11.228 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 19: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2021-06-01 10:20:11.228 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2021-06-01 10:20:11.229 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2021-06-01 10:20:11.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Adding to device queue
2021-06-01 10:20:11.231 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Added 137 to queue - size 11
2021-06-01 10:20:11.233 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Polling initialised at 86400 seconds - start in 1500 milliseconds.
2021-06-01 10:20:12.733 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Polling...
2021-06-01 10:20:14.652 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 19: Sending REQUEST Message = 01 0E 00 13 13 07 60 0D 01 01 26 01 00 25 75 EC
2021-06-01 10:20:14.665 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 19: sentData successfully placed on stack.
2021-06-01 10:20:14.666 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: TID 137: Transaction not completed
2021-06-01 10:20:14.684 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 19: SendData Request. CallBack ID = 117, Status = Transmission complete and ACK received(0)
2021-06-01 10:20:14.685 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: resetResendCount initComplete=true isDead=false
2021-06-01 10:20:14.687 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Response processed after 33ms
2021-06-01 10:20:14.688 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: TID 137: Transaction completed
2021-06-01 10:20:14.688 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: notifyTransactionResponse TID:137 DONE
2021-06-01 10:20:14.690 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-06-01 10:20:14.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Application Command Request (ALIVE:DONE)
2021-06-01 10:20:14.994 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: resetResendCount initComplete=true isDead=false
2021-06-01 10:20:14.996 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-06-01 10:20:14.997 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2021-06-01 10:20:14.998 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2021-06-01 10:20:14.998 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 19: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2021-06-01 10:20:14.999 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 19: Switch Multi Level report, value = 0
2021-06-01 10:20:15.000 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2021-06-01 10:20:15.001 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=0
2021-06-01 10:20:15.002 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Updating channel state zwave:device:099d457d:node19:switch_dimmer1 to 0 [PercentType]
2021-06-01 10:20:15.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Commands processed 1.
2021-06-01 10:20:15.005 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@68cece.
2021-06-01 10:20:18.046 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Application Command Request (ALIVE:DONE)
2021-06-01 10:20:18.047 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: resetResendCount initComplete=true isDead=false
2021-06-01 10:20:18.048 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2021-06-01 10:20:18.049 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
2021-06-01 10:20:18.050 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 19: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2021-06-01 10:20:18.051 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 19: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
2021-06-01 10:20:18.052 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 19: Sensor Type = Power(4), Scale = 0
2021-06-01 10:20:18.053 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 19: Sensor Value = 0E+1
2021-06-01 10:20:18.054 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2021-06-01 10:20:18.055 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SENSOR_MULTILEVEL, value=0E+1
2021-06-01 10:20:18.056 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 19: Sensor conversion not performed for POWER.
2021-06-01 10:20:18.057 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Updating channel state zwave:device:099d457d:node19:sensor_power1 to 0 [DecimalType]
2021-06-01 10:20:18.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Commands processed 1.
2021-06-01 10:20:18.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 19: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@761012.
For some reason the zwave controller lost also randomly the serial port
/dev/ttyACM1
Any help would be appreciated.
regards,
philip
