Not sure if it warranted an issue on GitHub since it might be an issue with my setup.
I was just trying a custom-built Z-Wave binding with the latest 3.0.0-SNAPSHOT (#1861) and I’m having problems with it - it works for 5-10 seconds, the controller and nodes are online and operational, then suddenly the controller becomes offline, saying that the serial port doesn’t exist (anymore).
The first suspicious message I see in the debug logs for the Z-Wave binding is “Stopping ZWave network” all of a sudden:
So I suppose it’s called by:
I was working fine with an old distribution so after tweaking features to downgrade nrjavaserial to mvn:org.openhab/nrjavaserial/3.15.0.OH2, everything works reliably again, so I suppose something in the upgraded version causes the problem.
My question is: do you know if there’s a way to get some logging for nrjavaserial and figure out why this happens? I tried increasing the log level with the Karaf console but it doesn’t look like the bundle is logging anything.
There have been working bindings with OH3 for months. I think it’s still best to only use it for testing and making it more stable. The text based configuration still works fine and the new UI is also included.
