This may be more an issue with the z-wave protocol, but the other night I was playing with some siren groups. Fortrezz SSA-01 sirens which appear as a dimmer and only flash their LEDs when set to 20%. I turned the group on - everything worked as expected. I turned the group off - everything worked as expected. I then went to turn on my lamp installed on a GE lamp dimmer (#45602). The light turned on, but so did the siren. I quickly unplugged the siren as it was late (11PM). Logs show nothing was commanded by OpenHAB for the Siren, so it must be a problem with the z-wave protocol somewhere. Anyone ever see such behavior before?
Logs below show the behavior. Node 31 was the powered siren. Nodes 27 and 28 are other sirens not currently powered up. I restarted OpenHAB after this incident.
events.log:
2016-01-29 23:06:01 - gSirens received command 20
2016-01-29 23:06:01 - Siren1 received command 20
2016-01-29 23:06:01 - Siren2 received command 20
2016-01-29 23:06:01 - Siren3 received command 20
2016-01-29 23:06:01 - Siren1 state updated to 20
2016-01-29 23:06:01 - Siren2 state updated to 20
2016-01-29 23:06:01 - Siren3 state updated to 20
2016-01-29 23:06:05 - gSirens received command 0
2016-01-29 23:06:05 - Siren1 received command 0
2016-01-29 23:06:05 - Siren2 received command 0
2016-01-29 23:06:05 - Siren3 received command 0
2016-01-29 23:06:05 - Siren1 state updated to 0
2016-01-29 23:06:05 - Siren2 state updated to 0
2016-01-29 23:06:05 - Siren3 state updated to 0
2016-01-29 23:06:14 - Dimmer_Lamp received command 100
2016-01-29 23:06:14 - Dimmer_Lamp state updated to 100
2016-01-29 23:06:28 - Dimmer_Lamp received command 87
2016-01-29 23:06:28 - Dimmer_Lamp state updated to 87
2016-01-29 23:06:28 - Dimmer_Lamp received command 100
2016-01-29 23:06:28 - Dimmer_Lamp state updated to 100
Openhab.log:
2016-01-29 23:02:03.682 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 28: Node is DEAD. Dropping message.
2016-01-29 23:06:08.081 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 27: Node is DEAD. Dropping message.
2016-01-29 23:06:08.601 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 28: Node is DEAD. Dropping message.
2016-01-29 23:06:08.837 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 31: Got an error while sending data. Resending message.
2016-01-29 23:06:12.984 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 27: Node is DEAD. Dropping message.
2016-01-29 23:06:17.889 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 28: Node is DEAD. Dropping message.
2016-01-29 23:06:17.990 [ERROR] [b.z.i.p.s.SendDataMessageClass] - NODE 31: Got an error while sending data. Resending message.
2016-01-29 23:15:56.904 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.0).
2016-01-29 23:15:57.312 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-01-29 23:15:57.377 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
