At the moment I prepare The New OH2 installation for my New house.
This includes about 100 z-Wave devices.
I’ve read that is not recommended to configure z-Wave devices with an items-File. Because its more comfortable and easier, I prefer file-based configuration. So I’d like to know The background of this recommendation .
Can anyone explain it for me?
This only applies to textual thing configuration. Textual items file work well.
It’s just not implemented in the binding
There was a short notice from Chris a while ago (can’t find it) that he is working on it, but I wouldn’t wait for that
Edit: if you want to use the existing rules (and therefore existing item names) from openHAB1, the easiest way to migrate to openHAB2 for me was:
in HABmin let discover the “Things” automatically, you will get a thing name like zwave:device:158b44ebf65:node23, unfortunately the easiest way to find out that name is PaperUI:
then define you items and channel links like:
Switch FibUniSens1_1 "Motion Hallway down [%s]" <motion> channel="zwave:device:158b44ebf65:node23:sensor_binary1"}
Unfortunately, this did not work for my Fibaro rollershutter devices, because I needed the extra option “invert percentage” where I did not find a way to add that to the config via text file.
In this case I used automatic thing discovery, linked the channels via HABmin to my items and used the “old” item names before hitting the “save” button.
