Running OH 3.1.0.RC1
I have one Zooz ZEN71 switch that is not behaving. I noticed that it was not responding to any commands so I attempted:
- heal
- remove from controller, then Delete Thing.
After deletion I was able to immediately re-add it, but the following shows in the logs:
2021-06-27 16:22:21.426 [INFO ] [openhab.event.ThingAddedEvent ] - Thing 'zwave:device:c57535c9:node41' has been added.
2021-06-27 16:22:21.428 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'zwave:device:c57535c9:node41' updated: INITIALIZING
2021-06-27 16:22:21.428 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c57535c9:node41' changed from UNINITIALIZED to INITIALIZING
2021-06-27 16:22:21.431 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'zwave:device:c57535c9:node41' updated: OFFLINE (BRIDGE_OFFLINE): Controller is offline
2021-06-27 16:22:21.432 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c57535c9:node41' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2021-06-27 16:22:21.432 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'zwave:device:c57535c9:node41' updated: OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
2021-06-27 16:22:21.433 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:c57535c9:node41' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
2021-06-27 16:22:21.433 [INFO ] [openhab.event.ThingUpdatedEvent ] - Thing 'zwave:device:c57535c9:node41' has been updated.
2021-06-27 16:22:21.434 [INFO ] [openhab.event.ThingUpdatedEvent ] - Thing 'zwave:device:c57535c9:node41' has been updated.
2021-06-27 16:22:21.435 [INFO ] [openhab.event.ThingUpdatedEvent ] - Thing 'zwave:device:c57535c9:node41' has been updated.
The switch did work fine for a few weeks when first added to the network but now this is all I get.
